Old Apr 07, 2010, 03:18 PM
larryjmoore is offline
Find More Posts by larryjmoore
Southern Idaho
Joined Jul 2008
Cool video of smoke being pulled through a propellor
I am in an instrumentation class at college. We used a high speed camera to take this video. We poured dry ice smoke over the wing then turned the propeller on. The propeller broke a light beam and started the video recording. It's interesting to look at the air being pulled through the propeller.
Smoke on Wing.avi (0 min 56 sec)
It is my 32 inch speed wing with a 400DF motor, 5.7x3 prop, 4 cell lipo, clocked at 120 MPH. In the video, the throttle was close to the lowest setting. I forget how many frames per second the video was recorded at.
larryjmoore is offline Find More Posts by larryjmoore
Old Apr 07, 2010, 09:09 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
Great video but you should have been using that lesser known variation of "Smoke On The Water" titled "Smoke Thru The Prop". Deep Purple passed on the less suitable lyrics but I understand that Weird Al Yankovic was supposed to be doing a version of the prop song....
It's interesting to see how the smoke is drawn in from a fairly wide venturi shaped segment of upstream air and how the prop stream doesn't really seem to suffer from tip vortices at all.
BMatthews is online now Find More Posts by BMatthews
Old Apr 08, 2010, 06:10 AM
Iboxx83 is offline
Find More Posts by Iboxx83
Joined Mar 2010
Nice video indeed, how come you didn't try with higher throttle settings?
Iboxx83 is offline Find More Posts by Iboxx83
Old Apr 08, 2010, 07:18 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Nice video, proves what I always thought.
Planes 'suck' themselves through the air.
eflightray is offline Find More Posts by eflightray
Old Apr 08, 2010, 09:48 AM
Southern Idaho
Joined Jul 2008
We did try it with close to full throttle, but it wasn't as interesting because all the smoke was pulled out so quick and then our dry ice couldn't produce enough to keep up. I suppose we could have sped up the camera, but then you run into lighting issues with the higher shutter speeds. The plane was already under a large halogen lamp and was very warm even after the short run.
Old Apr 08, 2010, 10:29 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
Notice how the smoke upstream prior to the prop was fairly undisturbed and obviously quite disturbed afterwards?
So if you're building a wind tunnel for airfoil/aerodynamic testing make sure your project goes upstream! :-)
Curtis
www.Tailwindgliders.com
Curtis Suter is online now Find More Posts by Curtis Suter
Old Apr 08, 2010, 05:09 PM
Brandano is offline
Find More Posts by Brandano
Also, it's a nice demonstration that when measuring the static thrust of a prop, the prop is "automagically" pulling through a column of moving air at near the best angle of attack. If the air column kept relatively still, a high pitched prop would probably be just stalled, but you can measure fairly high static thrust even on coarse props.I wonder if it would be possible to design a prop where reflexed blades angle themselves relative to the airflow a bit like flying wings, or like the freewing concept.
Brandano is offline Find More Posts by Brandano
Old Apr 08, 2010, 05:59 PM
Iboxx83 is offline
Joined Mar 2010
What is travelling at 120 mph? The blade tips?
Old Apr 09, 2010, 01:05 AM
Southern Idaho
Joined Jul 2008
The whole plane, but obviously not in the video
Discussion Cool video of smoke being pulled through a propellor larryjmoore Power Systems 0 Apr 06, 2010 10:39 PM
Discussion DX7se vs. X9303 - seeing through the smoke born2rc Radios 9 Dec 26, 2009 12:01 PM
Discussion Balance plug wires pulled -- charge through Deans OK? slappySF Batteries and Chargers 15 Oct 01, 2009 12:16 AM
Are the amps being pulled through these wires the same? EddieNewYork Power Systems 11 Nov 09, 2005 10:19 PM
