Old Apr 07, 2010, 06:01 AM
khaled_abobakr is offline
Find More Posts by khaled_abobakr
There's magic in those wings !
khaled_abobakr's Avatar
Joined Nov 2006
Which 2S ESC would you choose ..need some feed back ??
Hi
I have the following ESC candidates for powering a hobby grade Ornithopter, running on 2S, and won't pull more than 20A , and I really need the following programming features (brake, startup speed, signal loss protection)
I really appreciate some feed back on the following ESCs
The cheaper the better, but flawless performance is what I really need
1-TURNIGY Plush 30amp Speed Controller (16 USD) + prog card (7 USD)
http://www.hobbycity.com/hobbyking/s...eed_Controller
2-Hobby Wing Pentium 30A (19 USD)+ prog card (7 USD)
http://www.hobbythunder.com/index.ph...&more=&lang=en
3-Turnigy Super Brain 20A Brushless ESC (30 USD)+ prog card (7 USD)
http://www.hobbycity.com/hobbyking/s..._Brushless_ESC
4- Waypoint 25 A (38 USD) + programming card (10 USD)
http://www.aircraft-world.com/shopexd.asp?id=4370
5-Hyperion ATLAS Series Brushless 25A (50 USD)
Including programming IR TX/RX
http://www.aircraft-world.com/shopexd.asp?id=6825
Thanks a lot for taking the time to provide some feedback
Khaled
khaled_abobakr is offline Find More Posts by khaled_abobakr
Old Apr 07, 2010, 01:30 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Since you're asking specifically about an orni application I sent you a PM rather than posting here.
Tres Wright is offline Find More Posts by Tres Wright
Old Apr 08, 2010, 11:03 AM
BPD is offline
BPD
Find More Posts by BPD
BPD
DHMO kills!
Silver Creek, MN
Joined Feb 2007
I like the Mystery blue or ZTW (one in the same)
Excerpt from vendor:
Features of the ZTW Line of Esc's:
Support High RPM motors, are fully programmable, incorporate power arming protection: (prevents the motor from accidentally running when switched ON), Lost Throttle signal protection: The ESC will automatically reduces output power to the motor when it detects a lost of throttle signal for 1 second. A subsequent loss of throttle signal beyond 3 seconds will cause the ESC automatically to cut power to the motor, Automatic safety thermal over-load protection: (Automatically reduce output power to half when the temperature reaches 110℃, restore output power when the temperature is below 110℃.), Acceleration: Provides quick acceleration start ups with a linear throttle response, Governor Mode: Helicopter application with latest software design, especially for all types of brushless motor.
Program Functions: (programed with ZTW Program Card), Brake: on/off (Factory default setting: off)
Battery type: LiPo /NiMh/NiCad (Factory default setting: 3Li-Poly)
Low voltage cutoff: (Factory default setting: Reduce power) Reduce power: Reduce motor speed to half throttle, Cut off: Stop motor immediately. Ignore: Motor won’t stop until battery totally gone, Not suggested for lipos)
Soft start (Acceleration): Factory default setting: Soft start: Enable
Timing: (Factory default setting: Automatic) Automatic: (7-30 degree) ~~ Soft: (7 -22 degree) ~~ Hard: ( 22-30 degree)
Frequency : 8KHz/ 16 KHz, Factory default setting: 8KHz
Hobbycity has them for $11, Dealextreme has tehm for $14.44 w/ free shipping.
I have several of these ESCs in diferent sizes and highly recommend them.
BPD
BPD is offline Find More Posts by BPD
Old Apr 08, 2010, 03:27 PM
Joined Nov 2006
BPD
Will they work well on 2S lipo with Futaba 2.4 Ghz RX ... ??
Also how do you program it .. using yout TX or a prog card ??
Thanks a lot BPD
Khaled
Old Apr 08, 2010, 05:13 PM
BPD is offline
BPD
BPD
DHMO kills!
Silver Creek, MN
Joined Feb 2007
The transmitter does not matter, as long as the receiver sends out the standard servo signals. The 20 Amp version will run on 2-3 cells for Lipo. You can program it using the transmitter throttle stick or you can purchase a programming card. I do not have a programming card but have seen them for sale. milehighrc.com sold them.
I am using the 12amp version with a 2 cell Lipo and it is working very well. The 20 amp version has the same linear BEC so you want to be carful not to run to many servos (should be good for 3 mini servos).
BPD
Old Apr 08, 2010, 05:33 PM
Joined Nov 2006
Thanks a lot BPD
Khaled
Old Apr 08, 2010, 06:12 PM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
BPD
My favorite at the moment. They have a really slow and controlled start too.
Eagleburger is offline Find More Posts by Eagleburger
Old Apr 09, 2010, 05:14 PM
Joined Nov 2006
but you can have this controlled start with hard start too right ??
Thanks a lot
Khaled
Poll 8FG, SD-10G or A9 what would you choose? erazz Radios 293 Mar 03, 2012 10:27 AM
Discussion The helicopter you would you choose? ridgewalker Micro Helis 22 Mar 09, 2010 09:28 PM
Discussion What would you choose? airmcn_3 Composites Fabrication 23 Dec 31, 2009 07:28 PM
Discussion What would you choose if you had 100$? coMix Nitro and Glow Power Cars 3 Oct 09, 2009 01:03 AM
Question I need some feed back on this darthdrk Vendor Talk 0 Jul 05, 2007 10:08 AM
