Old Apr 06, 2010, 11:20 PM
4567 is offline
Find More Posts by 4567
4567's Avatar
Joined Mar 2009
Sig Kadet MKII: Which motor? How to mount?
Hello! I received a Sig Kadet MKII kit for christmas this year, and would like to convert it to electric. I would like to purchase a motor that would be able to use a regular, full-size spinner, so it can blend into the cowl as would be the case with a glow engine. While I was looking at the Exceed RC motors, I noticed that the spinner that it came with was rather small, and blue. People wrote in the comments section of the web page that there was no accessories available. One that had a spinner that was not small and blue would be much better, and preferably with accessories available.
Also, I dont need a really high end motor. I was actually looking for something cheap, like one of the motors from hobbyking.
Any suggestions would be great
Matt
4567 is offline Find More Posts by 4567
Old Apr 07, 2010, 09:39 AM
wellington53 is offline
Find More Posts by wellington53
Glenn
wellington53's Avatar
United States, WI, Oconto Falls
Joined Jan 2004
Here's a popular way to do it with nylon/standoff spacers from true value and the like.
wellington53 is offline Find More Posts by wellington53
Old Apr 07, 2010, 10:16 AM
4567 is offline
4567's Avatar
Joined Mar 2009
What are the nylon standoff/spacers attached to at the firewall? Is that another back plate motor mount?
Also which motor do you think would work well?
Old Apr 07, 2010, 11:31 AM
kingdom802 is offline
Find More Posts by kingdom802
Joined Sep 2003
I have converted an old Eagle 63 to electric to do some photography for a local company.
I used the Alpha 32 from Hobbypartz.com 22.90 the stand off's are from Home depot and com in sizes 1/4 to 1 inch. Use a good sized bolt and a blind nut on the back side and it will work well. I am not sure what the bracket on the back of the previous picture is.
kingdom802 is offline Find More Posts by kingdom802
Old Apr 07, 2010, 11:59 AM
4567 is offline
4567's Avatar
Joined Mar 2009
I don't know very much about these motors. Can you get adapters so you can use any spinner that you would use on a glow engine or no?
Old Apr 07, 2010, 02:37 PM
Glenn
Joined Jan 2004
Here's a popular motor for your plane,
http://www.hobbycity.com/hobbycity/s...less_Outrunner
Old Apr 07, 2010, 02:39 PM
Glenn
Joined Jan 2004
Thats just a spare motor mount I used but was not nessary.
Old Apr 07, 2010, 02:42 PM
Glenn
Joined Jan 2004
Like kingdom says about using blindnuts on the backside of the firewall,
All these items (blindnuts, bolts, standoffs etc can be found at most good hardware stores.
Old Apr 07, 2010, 03:15 PM
4567 is offline
4567's Avatar
Joined Mar 2009
Okay, but can I mount a big nylon spinner like you would with a glow engine onto it? And also what ESC and battery should I use? Sorry about all these questions, I'm a noob.
Old Apr 07, 2010, 03:35 PM
Glenn
Joined Jan 2004
Yes you can use a big plastic spinner like you would with a glow engine, Use a 60a esc, A 5S4100 LiPo will give good flight time too.
Old Apr 07, 2010, 04:33 PM
DrEvil is offline
Find More Posts by DrEvil
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Hi.
I'm using this motor : http://www.hobbycity.com/hobbycity/s..._750Kv_/_600W#
And this motor mount : http://www.hobbycity.com/hobbycity/s...ount_(110/45mm)
With a 12x6 propp on a 4cell lipo, works great !!
Kai
DrEvil is offline Find More Posts by DrEvil
Old Apr 07, 2010, 05:32 PM
4567 is offline
4567's Avatar
Joined Mar 2009
What ESC are you using? Where did you buy your battery? Do you put the nylon spinner on in between the plate and the little metal spinner that comes with the motor? Can you use a wooden prop like you would with a glow engine?
Old Apr 07, 2010, 06:45 PM
mt_100 is online now
Find More Posts by mt_100
I have no friends
United States, MI, Holland
Joined Dec 1996
I am using the same motor as DrEvil on the front of a PT-40 ARF with a 12x8 prop and 4S 3700 battery and it flies great. I don't have a spinner on it at all actually. Guess I could put one on but never did as the motor stays very cool for the 11 minute flights I get on it.
mt_100 is online now Find More Posts by mt_100
Old Apr 07, 2010, 07:44 PM
4567 is offline
4567's Avatar
Joined Mar 2009
Yes, now I see now. In the photo in pose number 2 I see the spinner backplate.
I have another question though, what kind of holes should I cut in the cowl for airflow to the motor.
And should I put the ESC on the same side of the firewall as the motor so it gets airflow too?
Also, is this charger okay for a 5S 4000 mAh Lipo?http://www.hobbycity.com/hobbycity/s...rger_1-6_Cells
Old Apr 07, 2010, 08:47 PM
Joined Sep 2003
Believe it or not I am running a 3c 2200 pack with a 40 amp speed control.
My watt meter shows 29 amps at full throttle.
13X6 prop
I normally get get about 8 to 10 min flights.
I tried to upload a video but was unable.
I could add a spinner but didn't need the weight.
I put two vents on mine after the first flight but saw no
diffrence with them or without.
Looks like you are getting some good feedback.
Sold SIg Kadet MKII and a Goldberg Cub Dallas101 Aircraft - Fuel - Airplanes (FS/W) 1 Apr 01, 2010 08:50 PM
For Sale SIg Kadet MKII and a Goldberg Cub Dallas101 Aircraft - Fuel - Airplanes (FS/W) 2 Mar 29, 2010 12:25 PM
For Sale New Sig Kits Citabria and Kadet MKII Dallas101 Aircraft - Fuel - Airplanes (FS/W) 6 Feb 28, 2010 10:06 AM
For Sale Sig Kadet MKII forsale Dallas101 Aircraft - Fuel - Airplanes (FS/W) 0 Feb 27, 2010 08:22 AM
Sold Sig Kadet MKII Kit bah7566 Aircraft - Fuel - Airplanes (FS/W) 1 Dec 05, 2009 11:58 PM
