http://www.rcgroups.com/forums/showthread.php?t=1494373 |
Happy Days. |
1 x 5100 3S is 385g. I can see the weight part, but I have a raptor e550 that uses 6S so I know the heli guys do it. Just think there is more to it than that, think it has to do with increasing volts instead of amps creates less heat? Someone with electrical engineering can step in. |
ITALY
Joined Aug 2006
which holes on the horns should i choose for a perfect control?? the highest??
i assembled a new skw 168 and i'm trying it with a fy31ap... not happy at moment... better the fy21... but i had to do some test about CG... anyway i saw that my tail is not straight with the body... i saw the elevator surface is a little curved with respect to the wings.. does it cause something? |
Australia, VIC, Melbourne
Joined Mar 2010
Mine was the same, I had to do some trimming so the elevator surface was level with the wings. The vertical rudder section is not 90 degrees to the horizontal. Once I modified it to make it level, I was worried it would be out of trim, but I maidened it this weekend and it was perfect! I don't notice any adverse effects. I feel its more important to make the surfaces level.
http://www.goodwinds.com/ |
Ya, Goodwinds bought Avia Sport Composites. They sell every size tube you should ever need.
I buy my oversized spar tubes (0.5" OD) from them as well. For carbon ribbons (aka carbon flats) I buy from http://www.canuckengineering.com/new...carbon-ribbons because he sells it up to 72" long with no minimum order. ian |
Latest blog entry: My 2012 FPV year in Review
Naturally, if you increase the system voltage, the current drops in direct proportion to provide the same power. I think we’re at risk though of overstating the benefits that a high voltage system would provide on this type of plane My Skywalker spends most of it’s time consuming about 7A at cruise on 3S . To drop that to 3.5A in cruise on 6S you would see only a very small benefit, because the electrical system is sized for max power, or about 50A. I’d say any benefit of lowering the current even further would be unmeasurable. Of course it’s easier to go to very high voltages with heli’s because you can easily change the gear ration (pinion size) to effectively lower the KV of the motor. Not so easy with a skywalker, as to turn a 6x4 prop on 6S, you’d need a KV in the range of 700 or so. Is such a motor available? In this way the Skywalker is not at all analogous to the heli example, where you could see a real benefit of a higher voltage sysetm. Heli’s spend much more time at high current levels, hence 4-5 minute flight times. |
| Thread Tools | |
| Question Best plane for FPV while on vacation? | patricklupo | Video Piloting (FPV/RPV) | 23 | Aug 08, 2010 06:27 AM |
| Cool FPV plane rescue with an FPV truck :-) | AnthonyRC | Video Piloting (FPV/RPV) | 17 | Feb 24, 2008 10:45 PM |
| For Sale Skywalker plane and a bunch of extras | moody07747 | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 19, 2006 09:34 PM |
| Discussion Aviator Skywalker RC plane given to me | moody07747 | Electric Plane Talk | 46 | Sep 12, 2006 11:45 AM |
