Old Jun 21, 2012, 04:51 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, leverage is the problem. The best boom repair is described above.
Glue the foam back together with thick CA, and then cut slits in the sides and top of the boom
spanning the break for several inches each way and install carbon ribbons edgewise making
sure the boom is straight as you go. Use thin CA after ribbons are installed, or thick CA
as you go while installing each one fairly quickly. It'll be stiffer than new, and weighs very very little.
ian
Daemon is offline Find More Posts by Daemon
Old Jun 22, 2012, 01:21 AM
digitalCAM is online now
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
Originally Posted by miknce View Post
So would that be counter clockwise viewed from back of plane?
Miknce, don't worry about which way your motor is turning, It is different for different people/props. -- First thing is to put your prop on with writing facing forward. Now start you motor and see which way the wind is blowing. Naturally it has to be blowing toward the tail. If it is blowing toward the nose, then reverse the hookup of any two of the three wires coming from the motor to the speed controller. Now the wind will be blowing toward the tail. Now you will fly. -- Good Luck, JOHN
digitalCAM is online now Find More Posts by digitalCAM
Old Jun 22, 2012, 03:07 AM
slarys is offline
Find More Posts by slarys
The Netherlands
Joined Jul 2011
Originally Posted by gent96 View Post
Where can I buy just the wings? Tnx!
Gent
bevrc.com sells the wings apart from whole kit.
slarys is offline Find More Posts by slarys
Old Jun 22, 2012, 04:48 AM
joel0407 is offline
Find More Posts by joel0407
joel0407's Avatar
Australia, NT, Lyons
Joined Oct 2010
My Scorpion 3014-1040kv was ordered yesterday as was my Castle Pheonix ICE 50. The ESC arrived today. Just the motor to go and then the rest is up to me.
I already have 2 x 4s-5000mha Batteries, 3 x HiTec HS65KB servoz and 1 x Align servo, FY30A-pro.
My DOSD is in for repair but I believe it will be back soon.
joel0407 is offline Find More Posts by joel0407
Old Jun 22, 2012, 06:20 AM
harfordhawk is offline
Find More Posts by harfordhawk
harfordhawk's Avatar
United States, NC, Wilmington
Joined Oct 2010
Originally Posted by surf1punk View Post
I spent some time tonight trying to start the repairs on my crashed Skywalker.
I've read a few tips on straightening the foam with hot water, which I did, and it helped a little but I'm still having issues with the nose being a bit crooked.
Is there anything else I can do to straighten this out? Would it be ok to fly with a nose like that? Thanks for the help.
Just to answer your question about flying with a slightly bent nose.. Yes you can fly with a bent nose. Mine went thru a few bad crashed early and I never did get the nose straight but she flies fine.. Wings and tail need good alignment though.
harfordhawk is offline Find More Posts by harfordhawk
Old Jun 22, 2012, 09:02 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
I plan to glue the two halves together since they broke cleanly, and then reinforce it with 4 strips of cf ribbons embedded in the foam along the tail, 1 every 90 degrees. Then possibly wrap some fiber tape as well. May add some weight, but I think it should be ok. I'll post a follow up once I give it a try.
Just make 100% sure it's straight - the slightest bend translates in a large rudder effect on the vert stab.
heinduplessis is offline Find More Posts by heinduplessis
Old Jun 22, 2012, 12:29 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Dang ! There is a slight bent in mine since its glued back, hope it will be flyable.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Jun 22, 2012, 02:47 PM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
did you put the ribbons on ? if not, use the ribbons to correct the bend.
rcmonster99 is offline Find More Posts by rcmonster99
Old Jun 22, 2012, 03:08 PM
mikenc is offline
Find More Posts by mikenc
Joined Jan 2012
I Just had to switch prop turn writing forward. Made big difference in air flow. I think it just might fly now. Want get a chance to test though, until next week. Will post how it turns out.
Still haven't installed any FPV gear. That will come after i fly that bird for awhile and get use to how she flyes. FPV gear to expensive to crash test.lol.
Thanks to everyone for help!!!
mikenc is offline Find More Posts by mikenc
Old Jun 22, 2012, 04:43 PM
Quebec, Canada
Joined Sep 2006
Would it work with the boom beeing glued with GG and the CF rod inside also beeing glued with GG ?
Old Jun 22, 2012, 04:57 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
so nobody answered this yet, but how are your tails looking? Mine is a bit wobbly even after reinforcing, etc...
flyandi is offline Find More Posts by flyandi
Old Jun 22, 2012, 05:06 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
As long as you properly glued the carbon tube into the boom, the tail will be fine in the air.
ian
Old Jun 23, 2012, 12:48 AM
Houba ! Houba !!
Joined Sep 2003
if you can bend it by hand then you should be able to
Old Jun 23, 2012, 06:15 PM
joel0407 is offline
joel0407's Avatar
Joined Oct 2010
Originally Posted by bakchos View Post
ALL RIGHT !!!!
Hope its the last time we talk about the rubber bands,
Watch the video, if a picture is worth a 1000 words, i guess a video is worth a 1000000 pictures !
Enjoy the bonus of my workbench at the end... its a mess !
http://www.youtube.com/watch?v=TgTAffKvylk
I just wanted to quote this video to bring it back to the top. I have read through 700 pages before I found this. It should be added to the first post.
And I'm still reading.
Old Jun 23, 2012, 07:07 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
That method doesn't provide enough tension for me, so I double mine over. Especially when the bands get a bit older, I like to have enough tension so that if one band breaks during flight, the remaining bands are still strong enough.
Sub.
subsonic is offline Find More Posts by subsonic
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
