Old Apr 27, 2012, 12:21 AM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Originally Posted by c172jeff View Post
Hi all,
I finally finished reading this thread from the start. I am now ready to build my Skywalker v5.1.
9) I plan to add flaps --- (I will have to research what king – this time .. search only and looks at pics via thread tools?)
Thanks for any help
Jeff
Flaps:
http://www.rcgroups.com/forums/showp...postcount=2092
henkvdw is offline Find More Posts by henkvdw
Old Apr 27, 2012, 12:50 AM
Stone1295 is online now
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
#8 The CoG should be 30mm not 30cm. Also, I thought there was some discussion on this with the 5.1? I fly the V4 wings so I have mine set at 30mm and it flies fine but I thought that there were other folks flying the newer wings and setting it closer to the servo wiring?
-Mike
Stone1295 is online now Find More Posts by Stone1295
Old Apr 27, 2012, 03:09 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by texasdrifters View Post
I am experimenting with longer flight times.
Has any 168 Skywalker users tried 2 5000 MAH flight batteries? I currently use one and I am thinking of adding a second battery for longer flight time mounted in the plane at the same time?
Thanks in advance for you assistance.
Hector
Hi Hector
I've done about 20 flights with 2 x 5Ah 3s batteries, I can reach a total of 40km. I've received 2 x 5Ah 4s this week, but was going to try it on my 1900 setup, but I'm waiting on a missing right wing. I'll probably run out of patience and try it on my 1680. No special mods but I think I should CF strip my wings.
heinduplessis is offline Find More Posts by heinduplessis
Old Apr 27, 2012, 04:35 AM
Mictronics is offline
Find More Posts by Mictronics
Joined Dec 2009
Mictronics is offline Find More Posts by Mictronics
Old Apr 27, 2012, 05:23 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
Hector
Hey that works fine, I was using 4 2200mah and about 4 months I start to use 2 5000mah, just make sure that are 15c that is more then enouth and low weight, with that you will have 10000mah and less weight to fly. Hope it work for you, it does for me.
mauromassari is offline Find More Posts by mauromassari
Old Apr 27, 2012, 08:11 AM
c172jeff is offline
Find More Posts by c172jeff
United States, CT, Glastonbury
Joined Feb 2012
-Mike
Thanke Mike,
I did read that. I will probably set it about 15mm back on the first try.
Jeff
c172jeff is offline Find More Posts by c172jeff
Old Apr 28, 2012, 03:34 AM
zach.h is offline
Find More Posts by zach.h
Needs more cowbell...
Australia, QLD, Brisbane
Joined Jul 2011
Hi Jeff
I take it you want to have the I-beams from the wingtips inwards? Have you considered using another I-beam in the middle of the wing instead of the extra spar? Unless you make up some kind of jig, it would be pretty hard to get everything perfectly straight. If you have a good eye you should be fine having putting the extra spar in, but it seems that going that way is harder and has more that can go wrong than using extra I-beams. The only major advantage I can see to using the second 10mm spar is that you can keep the wing halves separate, and as your already going to glue the wings together, I'd just use the I-beam. Between the tape, I-beams and whatever else you plan on doing, your wing should be plenty strong.
My 0.02
Zach
zach.h is offline Find More Posts by zach.h
Old Apr 28, 2012, 06:30 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Do you use 2x 4s 5000mAh or 2x 3s 5000mAh ?
I have 1x 4s 5000mAh but would like to add one more, but I also have a RVOSD inside my plane, so I'm not sure how to fit 2x 4s 5000mAh inside my plane, without removing the RVOSD.
- Kim -
SpookiePower is offline Find More Posts by SpookiePower
Old Apr 28, 2012, 06:42 AM
Joined Jun 2011
- Kim -
I use 2 X 3s 5000mAh not 4s, and it is working pretty good.
Mauro
Old Apr 28, 2012, 07:49 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
So what's the verdict on the version 5 CoG? I'm flying mine about 12mm back from the servo wire channel and it still drops its bum in turns, I'm thinking of trying a bit further back.
Teamsherman is offline Find More Posts by Teamsherman
Old Apr 28, 2012, 10:43 AM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
Think about that... that would indicate to me that the CG is too far aft....
thekubiaks is offline Find More Posts by thekubiaks
Old Apr 28, 2012, 01:07 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The attitude that the plane flies at, has more to do with wing incidence, and very little
to do with CG. However, a severely nose heavy plane would need to fly
at a higher angle of attack (inefficiently) and tail would be lower.
However it's normal for the Skywalker to fly with a bit of a nose down stance.
It flies fine that way, so no need to obsess about it.
What really matters when trying to dial in the CG, is how the pitch changes
across a wide speed range, and how efficient it is in a glide.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 28, 2012, 07:51 PM
texasdrifters is offline
Find More Posts by texasdrifters
Joined Apr 2011
Skywalker Container
Somewhere in the 900 plus pages of the Skywalker thread, I saw a plastic shipping/storage container the the Skywalker fit into. Could someone help with finding the picture of the container.
Hector
texasdrifters is offline Find More Posts by texasdrifters
Old Apr 28, 2012, 08:12 PM
Member #1
Joined Aug 2011
Don't you mean fore? If I move the CG aft it will become less tail heavy won't it? Or am I confused?
Old Apr 28, 2012, 08:25 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You're both confused.
ian
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
