Old Apr 07, 2012, 11:52 PM
CTvxl is offline
Find More Posts by CTvxl
United States, TX, Mansfield
Joined Jan 2012
Originally Posted by TwoHeadsBrewing View Post
I just flew my Skywalker this evening and was noticing an interesting behavior: When going from powered flight into a glide, the nose of the aircraft tips up about 30 degrees, almost goes into a stall, then the nose points down and finally levels out.
At first I thought this was a CoG issue, but it balances right at 25mm behind the servo wires. Based on other people's setups, this seems to be pretty close to normal. And the behavior of the plane in general is good and stable.
The other thought I had was that it might be the angle of the motor. If there is too much downthrust with the motor on, when the motor powers off that would cause the nose to go up. It is curious though that the plane doesn't exhibit any dipping down when the throttle is applied.
Sounds to me (and this is a completely off-the-cuff guess) like perhaps your tail (horiz stab) is perhaps VERY VERY SLIGHTLY pointing down (neg. attack)
I would check for that. might not be it, but could be...
CTvxl is offline Find More Posts by CTvxl
Old Apr 08, 2012, 01:47 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by PMRfly View Post
by the way rcmonster99, thats a funky looking plane on your profile page.. is it a combination of crashed and hanger rashed plane parts?
Nope... It was a scratchbuild creation that came from a confused mind. I cannot find the villages mentioned above either in Nigeria or Botswana in google Earth
rcmonster99 is offline Find More Posts by rcmonster99
Old Apr 08, 2012, 02:02 AM
PMRfly is offline
Find More Posts by PMRfly
Joined Mar 2011
Lol, yeah they are new towns.. ;-)
PMRfly is offline Find More Posts by PMRfly
Reply With Quote  (Disabled)
Old Apr 08, 2012, 02:18 AM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
I think you mean positive AoA. Negative AoA on the stab would mean
when the motor is turned on the added airspeed from the prop wash would
pull the tail down and the nose up. Positive AoA would lead to the nose
pitching down when the motor is turned on, and when turned off, and the
additional airspeed is subtracted, the nose pitches up.
But it's not just the AoA that matters. If you have a lot of up trim this is the
same thing as increasing the AoA and would have the same undesirable
pitching effect during changes of airflow speed. This is the reason why its
important to have a near-perfect CoG to decrease the trims.
Do you have a lot of trim or is your horizontal stab not level?
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Apr 08, 2012, 06:18 AM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
This is a CG issue, move your CG up to about 10mm behind the servo wire channel. Your SW will fly like a glider.
thekubiaks is offline Find More Posts by thekubiaks
Old Apr 08, 2012, 09:19 AM
Grips is offline
Find More Posts by Grips
Eat-Sleep-Work-Fly-Repeat
Grips's Avatar
Canada, NL, Division No. 9
Joined Mar 2011
What is the story on the lowpricerc 168 Skywalker with the "steel" tube in the wing. Has anyone tried this? Is it ridiculously heavy?
Grips is offline Find More Posts by Grips
Old Apr 08, 2012, 10:25 AM
TwoHeadsBrewing is offline
Find More Posts by TwoHeadsBrewing
Moderately Dangerous
TwoHeadsBrewing's Avatar
United States, CA, Chico
Joined Apr 2011
I'll give this a shot. I just have to figure out how to get the weight forward. As it is right now I have a 4S 5000mah(flight batt) and a 3S 2200(video tx) shoved all the way forward in the nose. Aside from moving the video transmitter, I'm not sure how else to accomplish this balance.
TwoHeadsBrewing is offline Find More Posts by TwoHeadsBrewing
Old Apr 08, 2012, 11:43 AM
Joined Aug 2010
I have the same two batteries and have the 5000mah all the way forward but the 2200 about half way back. But, I have a 690TVL on the nose and a Go Pro right behind that. I use two canopies, one with Go Pro, and one without. On the canopy without the GoPro, I hot glued in about 6 oz of lead in the hollow underside of the canopy. I can post pictures if you'd like.
Old Apr 08, 2012, 03:46 PM
Joined Apr 2011
OK, I'll give that a shot. I have a Drift HD camera that I've been meaning to test out, so maybe I'll mount that up rather than having just dead weight up there.
Old Apr 08, 2012, 05:10 PM
PMRfly is offline
Joined Mar 2011
i've had the steel tube version and no it doesnt add unecessary weight, its fine. anything above v3 is fine. infact v3 was good too.
there is a slight misalignment with the wings (1mm) but it makes absolutely no difference to performance and you can barely notice. at 75 clams, its a steal... pardon the pun...
Old Apr 08, 2012, 05:13 PM
Joined Aug 2010
V4 wing is the best, anyone want to sell me a V4 wing or trade for a V5 wing??
Old Apr 08, 2012, 05:24 PM
PMRfly is offline
Joined Mar 2011
but if u reinforce, it makes no difference?
Old Apr 08, 2012, 07:59 PM
Joined Aug 2010
True, I fly mellow FPV cruising so I have never had an issue with wing strength.
Old Apr 09, 2012, 11:17 AM
Joined Apr 2011
How is everyone attaching the rubber bands on their Skywalker? It doesn't seem like I can get mine on very tight and there is some slight play when I try to move the wing by hand.
Old Apr 09, 2012, 11:28 AM
Joined Aug 2010
This is how you want to do it.
Skywalker rubber band installation. (1 min 29 sec)
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
