Old Apr 22, 2010, 04:29 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Still no build progress, and anyone getting the 'EPO' version?
Cralis is offline Find More Posts by Cralis
Old Apr 23, 2010, 07:35 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Does the plane come with pushrods and all that?
Old Apr 24, 2010, 12:42 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Fergus ?.???? Oooo Feeeeerguuuuus..... Any progress ? I hope things are ok with you
rcmonster99 is offline Find More Posts by rcmonster99
Old Apr 24, 2010, 04:40 AM
Fergus is offline
Find More Posts by Fergus
Fergus's Avatar
Ireland
Joined Apr 2005
Haha. I'm still waiting on a tower hobbies order for my servos. I can't put the fuse together till I get them.
Once they arrive things should go together quickly. I have the wings finished. That was the biggest job because they were very fragile.
Cralis,
pushrods are included as are horns for the control surfaces (not enough for flaps though). The horns do not put the pivot point over the centre of the hinge line which will cause unequal throw. Something I may need to look at when setting up the ailerons as I only have one channel available due to the limitations of the co-pilot.
Question:
What would you guys suggest for fixing the plywood motor mount to the eps foam. Will glueing to the foam be enough.
Fergus is offline Find More Posts by Fergus
Old Apr 24, 2010, 04:42 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Hotglu may work?
Old Apr 24, 2010, 05:07 AM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
I was going to glue a dowel into the foam and put a self tapper through the plywood disc backed up by glue. The dowel should give a greater surface area for glue to adhere to.
This foam (eps version) is extremely fragile. It's taking alot of work to get a reasonably strong plane. If i'd known the epo version was coming I would have held out for it and alot of this work going into the eps version would not have been necessary.
Guys I still have no idea of the correct CG. If anyone has flown this plane or perhaps have seen the numbers quoted somewhere please post a link. Thanks.
Regards
Fergus.
Old Apr 24, 2010, 05:09 AM
Houba ! Houba !!
Joined Sep 2003
Originally Posted by Fergus View Post
Question:
I would personally use 5 min epoxy... The other thing to do to avoid ripping the foam, is to spread the load by glueing a plate (very thin plywood ) to the horn area and then glue the horn to the ply
Old Apr 24, 2010, 02:42 PM
FPVistanbul is offline
Find More Posts by FPVistanbul
FPVistanbul's Avatar
Istanbul / Turkey
Joined Oct 2007
Hi Fergus
Sorry for my late response.
CG is 3 inches (7.5 cm) from the LE of the wing.
We are waiting for your videos, I will send to you servos
Best regards
Adnan.
FPVistanbul is offline Find More Posts by FPVistanbul
Old Apr 25, 2010, 12:42 PM
CageHound is offline
Find More Posts by CageHound
CageHound's Avatar
Southwest Chicago
Joined Jul 2006
Quick question on the glassing of foam. Can I use the ol' ladies used brown panty hose or should they be a special type? Serious question
And another question, can servo troughs etc be cut out if glassed over, or should one take care not to glass over these areas? I have a spare EZ* I'm going to practice on before ordering Skywalker. And like most, am waiting to see how Fergus makes out.
CageHound is offline Find More Posts by CageHound
Old Apr 25, 2010, 02:59 PM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
The regular old type of stockings are exactly what to use. Some things i've learned from doing this.
1. Make sure you stretch the nylon so it is a tight, well strectched fit over the foam without excess material on the surface. Use pins or clamps to secure the excess material.
2. Keep the polyurethane coat light. This is just to adhere the stockings to the foam.
3. Use spakle mixed with water to then fill the seems.
4. Sand with 200grit.
5. Spakle again then sand finishing with wetodry sand paper.
You can cover servo holes etc with the nylons. The polyurethane drys leaving the fabric much more rigid and its easy to cut with an x-acto. Same applies on the edges of the wings. Get plenty of polyurethane on the excess as it makes it very easy to cut away.Dont worry about adding too much water to the spakle (pollyfilla in Ireland). The excess water evaporates as the filler dries. Adding water makes it easier to apply.
You won't get a brilliant white finish without adding several extra coats of spakle. So on a serious note if you are particular about how the finished product will look try getting white stockings. The ones I used were the regular tan colour and its left the wing an off white colour . It can be painted but thats just more weight. I just wanted it to be flexible and strong. As it is now after glassing this way I can bend the wing without it snapping. Not as flexible as epo but not nearly as brittle as it was before I started.
For a large wing this method of reinforcing is great. With the curves of the fuselage I'm not sure it would be so easy. The nylon lifts if pulled over a concave curve. If you try to cut it to fit the elasticity causes it to just bunch up. I used regular fiberglass inside the fuselage and will reinforce the outside with reinforced tape.
Regards
Fergus
Old Apr 25, 2010, 07:59 PM
CageHound's Avatar
Southwest Chicago
Joined Jul 2006
Great info - thank you.
Old Apr 25, 2010, 11:18 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
I assume the stockings won't be required with the EPO version?
Old Apr 26, 2010, 02:11 AM
Houba ! Houba !!
Joined Sep 2003
nope.... only for kicks
Old Apr 26, 2010, 09:42 AM
Hooks is offline
Find More Posts by Hooks
Hooks's Avatar
Joined Jun 2009
EPO Skywalker FPV plane back in stock on FPVflying.com
Hooks is offline Find More Posts by Hooks
Old Apr 26, 2010, 11:20 AM
(KNO3) is offline
Find More Posts by (KNO3)
Joined Apr 2010
I have just found this one:
http://www.lowpricerc.com/product_in...roducts_id=981
Looks cheaper.
(KNO3) is offline Find More Posts by (KNO3)
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
