Old Jun 23, 2010, 01:35 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
Raptor, I'll bet you'll get double the flight time if you use a camera that isnt like a barn door
ashdec87 is offline Find More Posts by ashdec87
Old Jun 23, 2010, 03:05 PM
RaptorAP is offline
Find More Posts by RaptorAP
Gainesville, FL
Joined Nov 2005
It was for testing purposes, I needed about 6 oz of weight AND an onboard camera. All my planes shove air!
RaptorAP is offline Find More Posts by RaptorAP
Old Jun 23, 2010, 04:54 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
I put my CF strips in... cut the holes nice... dry fit was great.. I then removed the strip.. ran come CA ofer the strip, and quickly tried to slide the CF strips back in. They went in NEARLY enough... They seemed to bond very quick... so there is maybe 1mm.. maybe half a mm sticking out. So, of you tun your finger across the CF strip, you can feel it standing out a small amount..
Under the wing is the high pressure (lift) side.. Would it be OK to leave it? Only other option would be to maybe put some tape over the strips, so that it's not a 90 degree ange to the wind, but rather a more gradual lift?
Cralis is offline Find More Posts by Cralis
Old Jun 23, 2010, 04:55 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I sanded mine down where they protruded slightly because of the dihedral.
techspy is offline Find More Posts by techspy
Old Jun 23, 2010, 05:29 PM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Oh my, did I not cover that in detail? Put CF strip in, then drop CA into the slot with the CF already in! I outlined the procedure from start to finish
I use 8x1mm CF strip, and cut slots in the wing, sand the CF and whipe any grease or dirt off with some alcohol and then insert the strip in the slots.
If you cut deep enough (no, not *through* the wing) you can still keep the dihedral as the wing is much thicker than the CF strip. Glue in place with thin CA (I use ZAP Thin CA) by dropping a few drops in and rocking the wing so the thin glue is evenly distributed (wipe off any excess with aceton).
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Jun 23, 2010, 05:34 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Might try that.. but... don't want to mess with CF dust. Must just tape it over. Ta.
I read it that you cut the slits and insert. New sentance... Glue in with CA by dropping a few drops...
I did that.. except, I didn't read the part where you said to glue while they're in. Fair enough, just didn't understand.
So.. hows yours flying by the way? Seem you've had the worst results?
I have 4 x 500mm long strips left over... Wonder if I should use them on some other bits?
Old Jun 23, 2010, 05:42 PM
simonjardine is offline
Find More Posts by simonjardine
MultiRotor Jedi
simonjardine's Avatar
Australia
Joined Apr 2008
Originally Posted by RaptorAP View Post
Test flew the dump truck known as the Skywalker.. Love it! Flies like a dream.
Had to balance with 2 x 3s 2650mah packs (5300mah) and Canon SD900 digital camera. Over 6 min flight only consumed 600mah from the packs. Turnigy 3530-1400kv with an APC 9X6.
http://www.youtube.com/watch?v=rkvg9YuEx3I
Cool,
I use those motors for my FPV 6ft wings. They are really good, however sometimes they do have bearing problems. I would suggest you go up to a 4cell, you will draw less amps have %25 more power and stay in the air longer
Sweet movie.
Simon
simonjardine is offline Find More Posts by simonjardine
ssassen is offline
Joined Jul 2004
Well, I guess I expected more, has nothing to do with the way I built it by the way, just the way the model behaves itself. It needs a longer nose to balance out with just a single LiPo in the nose.
Cheers,
Sander.
Old Jun 23, 2010, 05:43 PM
TaSaJaRa is offline
Find More Posts by TaSaJaRa
More props are better than One
TaSaJaRa's Avatar
United States, AL
Joined Nov 2004
Originally Posted by iw28 View Post
I have many pictures that I took from the fpv skywalker but cant upload them, can anyone help?
Here ya go... iw28's FPV SkyWalker
TaSaJaRa is offline Find More Posts by TaSaJaRa
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Yeah, I asked BEVRC if he could maybe make and sell a nose addon... but no answer. Would be easy for a foam person to make.. Not so easy for us plebs.
I'm sure it would sell...
BEVRC?
Old Jun 23, 2010, 06:30 PM
iw28 is offline
Find More Posts by iw28
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
Thank you so much for the help!!!
I couldnt do it by my self
iw28 is offline Find More Posts by iw28
Old Jun 23, 2010, 07:22 PM
Thumb_number is offline
Find More Posts by Thumb_number
I think my wheels fell off.
Thumb_number's Avatar
Perth
Joined Oct 2009
Work has started on my SW build. I'm trying to be neat...........
It is being built as a dedicated platform for the GoPro. And I have two wing selections for it, the stock wing for banging around, and I have a 2m sailplane crunchy wing for extended 'floaty' flights that will be R E only.
Specs I'm planning to run with:
2 x 2200mha
E-Flite Power 10 running 9x8 ( Vopt is through the roof, not as efficient as would like, about 74%, but.......just to be different )
Usual ET spaghetti but trying old school static lines
FY20A (Just 'cause I want to try one)
Run of the mill Vtx, cx161,
GoPro in case right up front to get CoG
Thanks all for your build logs, they have been helpful.
Thumb_number is offline Find More Posts by Thumb_number
Old Jun 23, 2010, 08:32 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Looking good Thumb .
Kev.au is offline Find More Posts by Kev.au
Old Jun 24, 2010, 01:48 AM
ssassen is offline
Joined Jul 2004
Oh nooo .. wire spaghetti
Cheers,
Sander.
Old Jun 24, 2010, 01:52 AM
BlueAngel2000 is offline
Find More Posts by BlueAngel2000
Flying like an Angel.
BlueAngel2000's Avatar
Austria
Joined Sep 2007
Cheers,
Sander.
but, RTH.
the Skywalker will be definitely my next FPV plane. Maybe there will be a longer nose version soon, so i don't need to mod it myself.
BlueAngel2000 is offline Find More Posts by BlueAngel2000
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
