Old Oct 04, 2011, 07:33 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by subsonic View Post
Yep, I think that's how I want to set mine up. Do you have a pic of your rx installation?
Cheers
Subsonic
This is how its mounted , just velcroed it top aft.
octane81 is offline Find More Posts by octane81
Old Oct 04, 2011, 07:39 AM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
HAHA - yours looks nastier than mine
UndCon is offline Find More Posts by UndCon
Old Oct 04, 2011, 08:01 AM
octane81 is offline
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Im nasty
Old Oct 04, 2011, 08:24 AM
heinduplessis is online now
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
I also have cloverleaf for my 800mW 1280...outstanding performance
Mine is mounted on top of the stabilizer and the VTX is on the shelf behind motor
//UndCon
UndCon, what would a fancy Vtx antenna help if you're flying regular spektrum 2.4ghz range +/- 1km?
heinduplessis is online now Find More Posts by heinduplessis
Old Oct 04, 2011, 08:27 AM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
It helps alot actually. The cloverleaf is circular polarized which cuts down on multipathing big time, and doesnt care how the planes attitude is. So, within that 1km range of your 2.4g rc signal, you can expect a very clear and useable video signal, regardless of proximity to cars, buildings, or other objects that cause a linear polarized antenna to reduce signal quality.
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Oct 04, 2011, 08:35 AM
Foam Snow
Joined Aug 2011
Originally Posted by Daemon View Post
You're going to have to show a picture of that, because it doesn't make any more
sense this time, than it did the last time you said it.
ian
Ian, see below. Picture one is without the ring, so you can see my horrible attempt at drilling. There's some play for the shaft in the one direction. The second picture has just the ring added. The nut / spinner goes on the opposite side, so, as I have it, the more the nut is tightened, the more "straight" the shaft is pulled in proportion to the prop.
Pic 3 has the other bits, where you can see the spinner forces the ring-side (right hand side) flat against the washer.
Old Oct 04, 2011, 08:56 AM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
Your prop was designed to handle different shaft sizes. That is why the hole itself is over-sized and why it was supplied with a variety of insert washers. If you like, you can change to a collet that will fit your prop exactly. This should not be necessary however. The supplied washers should give you the proper fit.
cliffkot is offline Find More Posts by cliffkot
Old Oct 04, 2011, 09:40 AM
Foam Snow
Joined Aug 2011
Thanks Cliff.
Old Oct 04, 2011, 09:43 AM
Foam Snow
Joined Aug 2011
Originally Posted by Crist Rigotti View Post
You don't need to do anything but drill a hole in the firewall to clear the shaft and collar.
Thanks again Crist for that link to the HK deal of the day for the Scorpion. This is one MEAN motor. I'm actually scared of it.
Old Oct 04, 2011, 10:38 AM
slarys is offline
Find More Posts by slarys
The Netherlands
Joined Jul 2011
I am planning to buy v5 SW and I was looking for a viable motor. Would this be a good match for it?
And also this propeller is in my mind but not sure. Any suggestions?
Thanks.
slarys is offline Find More Posts by slarys
Old Oct 04, 2011, 10:41 AM
Foam Snow
Joined Aug 2011
Thanks.
http://www.hobbyking.com/hobbyking/s...dProduct=17353
Old Oct 04, 2011, 10:48 AM
Foam Snow
Joined Aug 2011
I'm closing up my Skywalker, any last suggestions?
I've done:
1. Embedded a straw to accommodate later cabling from canopy to shelf
2. Opened a channel to accommodate the esc wires coming down to the battery
3. Opened a channel to accommodate GPS placement etc.
Any other suggestions?
Old Oct 04, 2011, 10:51 AM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Thanks.
If you are planning to run on a 2S pack it seems by the specs that the chosen motor and prop would work.
On 3S you may have to prop down to a 9x4E or even 8x6E.
Only real world experimenting will tell.
I am surprised at how lightweight the motor is. For a 3536 weight is usually around 120g.
Looks like this motor would be able to handle a 9" prop on 3S and even on 4S.
Someone is selling this combo which would be a prime option for 4S. Ask heinduplessis .
henkvdw is offline Find More Posts by henkvdw
Old Oct 04, 2011, 11:14 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Of course I'll balance the prop afterwords.
That does not completely solve the problem if the hole is imprecise. Take a closer look at the geometry and tracking issues. Also you can balance blade to blade, but if the hole is off 90 degrees to the blades, it is very difficult to get enough weight on the hub to counteract both blades' slight offset in the same direction.
Care and precision is always best when dealing with a mass rotating at many thousands of rpm's. It's always best to do it right.
erkq is online now Find More Posts by erkq
Old Oct 04, 2011, 11:53 AM
rob38 is offline
Find More Posts by rob38
rob38's Avatar
Noord Holland
Joined Oct 2007
hi guys
i,m happy whit this elastics
did someone order them to????
http://www.ebay.com/itm/250881237349
rob
rob38 is offline Find More Posts by rob38
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
