Old Oct 03, 2011, 06:51 PM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by mudlark View Post
Where can the iformation on the cloverleaf be found?
30k is great I could realy do with an antena like that.
Where is the VTX mounted?
Under the wing
octane81 is offline Find More Posts by octane81
Old Oct 03, 2011, 07:55 PM
mudlark is offline
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, High Wycombe
Joined Mar 2001
Originally Posted by pdiddyg40 View Post
In the cloverleaf thread, silly
I was hoping for a link like this one
http://www.rcgroups.com/forums/showt...ght=cloverleaf
mudlark is offline Find More Posts by mudlark
Old Oct 03, 2011, 08:03 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
HAHA, WHOOPS! I didn't mean to sound like an ass there. I actually did find the thread for you and copied the link, but apparently I forgot to paste it in my post. Sorry I made you do extra work there. I didn't mean anything bad by that.
It's a GREAT antenna, though. I made 2 by myself. They turned out really well, but my takeoff angles are all outta whack. The antenna works really well and is tolerant to build mistakes. You'll love 'em!
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Oct 03, 2011, 08:36 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
yeah i just built the cloverleaf and the angels are all off but it still works great
chatch15117 is offline Find More Posts by chatch15117
Reply With Quote  (Disabled)
Old Oct 04, 2011, 01:58 AM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I also have cloverleaf for my 800mW 1280...outstanding performance
Mine is mounted on top of the stabilizer and the VTX is on the shelf behind motor
//UndCon
UndCon is offline Find More Posts by UndCon
Old Oct 04, 2011, 03:00 AM
heinduplessis is offline
Find More Posts by heinduplessis
Foam Snow
South Africa, WC, Cape Town
Joined Aug 2011
Originally Posted by erkq View Post
The center hole's accuracy is critical to proper balance.
Of course I'll balance the prop afterwords.
heinduplessis is offline Find More Posts by heinduplessis
Old Oct 04, 2011, 03:10 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Doesn't matter how balanced the prop is, if you can't ensure it sits centered on the shaft
which is why the hole matters.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 04, 2011, 03:18 AM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
For those running Dragon Link, what length of receiver extension will I need if I want to place the receiver in the fuselage, and have the antenna elements on the vertical stabiliser? My options are:
18"
24"
30"
36"
cheers,
Sub.
subsonic is online now Find More Posts by subsonic
Old Oct 04, 2011, 03:20 AM
Foam Snow
Joined Aug 2011
ian
The shaft does not touch the inner hole on my prop, the adapter presses against the outside rim.
Old Oct 04, 2011, 03:29 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
You're going to have to show a picture of that, because it doesn't make any more
sense this time, than it did the last time you said it. If there's no contact with
the shaft, then any time you tighten the adapter nut/spinner down the prop
could be offset in any direction and there's no way to balance that.
APC supplies adapter rings to make the hole smaller so it fits the shaft.
If your prop doesn't have that and the hole is too big for the shaft,
then it's not suitable to your application.
ian
Old Oct 04, 2011, 05:39 AM
Foam Snow
Joined Aug 2011
ian
Ok maybe I'm being dumb again. I'll take a picture a little later thanks for the help.
Old Oct 04, 2011, 05:55 AM
pdiddyg40's Avatar
Joined Jul 2008
//UndCon
I was considering doing exactly what you did... or I was going to just have my antenna on the tail boom to avoid the run on coax. You aren't concerned about any of the cable loss? Just curious if you feel that the benefit of having it on the tail outweighs the drawback of the length of coax
Old Oct 04, 2011, 06:39 AM
octane81 is offline
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
18"
24"
30"
36"
cheers,
Sub.
24" workes fine for me , look at my pics on the previous page
Old Oct 04, 2011, 07:20 AM
UndCon is offline
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
The VTX is mounted flat on the area behind prop. The antenna is taped along the entire length of tail boom to avoid snagging and it is taped in front of the vertical fin all way up to the antenna.
The antenna itself is taped to top surface of elevator.
Lots of tape to hold it in place and I have hit branches with the antenna without any damages at all.
Any bad performance due to ~50cm cable??
Not as far as I have noticed - no glitches, no harmonics, no nothing
(VTX @1280mhz and Spektrum DX7 radio)
Old Oct 04, 2011, 07:45 AM
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Yep, I think that's how I want to set mine up. Do you have a pic of your rx installation?
Cheers
Subsonic
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
