Old Sep 28, 2011, 05:56 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Would anyone consider it necessary to reinforce the elevator on their SW? I'm getting closer to completing this plane (I build pretty slow )
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Sep 28, 2011, 06:21 PM
mudlark is online now
Find More Posts by mudlark
Happy Days
mudlark's Avatar
United Kingdom, London
Joined Mar 2001
just started building my V5 version.
The elevator has a carbonstrip in it ready to be glued in, if that is of help
I've started with the wings, going to add the flaps.
mudlark is online now Find More Posts by mudlark
Old Sep 28, 2011, 06:24 PM
pdiddyg40's Avatar
Joined Jul 2008
The elevator does? My horizontal stab does, right before the hinge line. And I added another CF strip further up. But does the actual elevator need reinforcement?
Old Sep 28, 2011, 06:39 PM
pdiddyg40's Avatar
Joined Jul 2008
Oh, and second question. Would it be considered safe to just Gorilla Glue my H-Stab to the V-stab? I don't think there's a problem wiht it, but would anyone else object?
Old Sep 28, 2011, 07:46 PM
beaverlover is offline
Find More Posts by beaverlover
United States, NC, Mooresville
Joined Jun 2008
Definitely put a ribbon of carbon in your ACTUAL elevator. TEST: Hold the control surface and push to the extreme end of the control surface. End result? lots of flex. Reinforce.
I don't think it is necessary to glue the horizontal/vertical stabilizers together, but not a bad idea either. I don't see any benefit other than transporting the planke to have it removable.
beaverlover is offline Find More Posts by beaverlover
Old Sep 28, 2011, 09:05 PM
viper6549 is offline
Find More Posts by viper6549
Bugs!!!!!!!
viper6549's Avatar
USA, OK, Wayne
Joined Sep 2009
I covered mine with packing tape, not sure if it needed it or not.
viper6549 is offline Find More Posts by viper6549
Old Sep 28, 2011, 09:07 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
I just have a strip of CF in the stab. Nothing in the elevator. No issues here.
ashdec87 is offline Find More Posts by ashdec87
Old Sep 28, 2011, 09:56 PM
Wingnut13 is offline
Find More Posts by Wingnut13
I do all my own crashes
Wingnut13's Avatar
United States, NH, Rochester
Joined Jan 2011
My elevator flexed quite a bit until I removed the EPO hinge and used tape. No issues after that, and I have a porky plane. ~Wingnut13
Wingnut13 is offline Find More Posts by Wingnut13
Old Sep 29, 2011, 02:43 AM
htran is offline
Find More Posts by htran
Joined Jan 2011
I managed to do a 1.7k FPV flight this morning. Limited by my Futaba FASST radio, waiting for my Dragonlink LRS to arrive.
http://vimeo.com/29759287
htran is offline Find More Posts by htran
Old Sep 29, 2011, 11:09 AM
yanickr1973 is offline
Find More Posts by yanickr1973
Zebro
yanickr1973's Avatar
Canada, QC, Blainville
Joined Sep 2007
There is absolutely no need to reinforce the elevator ! you are not flying a 3D plane, it's a fpv platform with 5mm of elevator throw!
I recover easily from high speed dives with no problems on the stock elevator
remember that to some extent, you want your plane to flex if you stiffen your plane too much, it becomes like riding your car without a suspension.
yanickr1973 is offline Find More Posts by yanickr1973
Old Sep 29, 2011, 11:28 AM
htran is offline
Joined Jan 2011
high speed dives? power off, reduce airspeed, then lower the nose and you won't get into a high speed dive. Also deploying flaps and you can descend at a steeper angle and not get into a high speed dive.
High speed dive = either pilot error or aerobatics.
Old Sep 29, 2011, 11:29 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Just so everyone is on the same page.
The elevator is the control surface that moves up and down.
The horozontal stabilizer aka horizontal stab is the fixed wing that the elevator is attached to.
The horizontal stab, as you all know, has a rod in it but it can still benefit from a carbon strip. The elevator is fine as is and needs nothing.
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Sep 29, 2011, 11:31 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
You forgot also, (or wing snaps off) like mine....
mauromassari is offline Find More Posts by mauromassari
Old Sep 29, 2011, 11:44 AM
htran is offline
Joined Jan 2011
LoL I don't think the high speed dive caused that, it was probably the "abrupt" controls (ie. too much elevator) for that airspeed resulting into too much load on the wings.
Did you have the whole bottom of your wing fibre taped? I just can't see how with 4 carbon tubes and the bottom fibre taped a wing could snap.
Old Sep 29, 2011, 11:53 AM
Joined Jun 2011
You are probably right I did not have fibre tape on it, but alredy got some and will use in mine next SW, but be carefull this baby gets speed very easy because of the load on it.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
