Old Sep 03, 2011, 06:10 AM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Originally Posted by RolandS888 View Post
Webdr, the spoon mod should be on the list of standard mods.
I put my ESC in the cavity under the wing, temperature sensor showed up to 55C (131F) without the vent and only 25C (77F) with the spoon mod.
Its a very tidy and effective mod that is just too simple..
Very clever idea.
Where did you cut the holes for the spoon mod if your ESC is under the wing? Were the air scoops cooling the under-wing cavity, or were they in the body of the plane?
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Sep 03, 2011, 06:28 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
In the under wing cavity.
Same as the pictures in posts 9349 and 9356, the upper "webdr spoon scoop" is catching air and feeding it into the cavity under the wing join.
My ESC is in there.
RolandS888 is offline Find More Posts by RolandS888
Old Sep 03, 2011, 07:00 AM
bakchos is offline
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
My ESC is in there.
I did it too, 2 poons up, and 2 spoons down.
bakchos is offline Find More Posts by bakchos
Old Sep 03, 2011, 07:12 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
i am back from the field, did the maiden LOS, spent most of the flight triming the SW, very smooth flyer, just keep the turn smooth and not banked like i am use too on the Edge 540 and its all easy lol.
My CG was about 15mm aft servo wire, i might try to go at 25-30 and compare, the motor was more than enough, i did not use more than 1/4 stick and took off at 15 amps (my setup is doing 45 amps and 550W).
I am uploading the raw video from the ground station recorder, only thig negative is after taking this all off the Twinstar, reinstalling in the SW with new camera, torrid to all the wires, i get the same white lines in the video, those lines never got identified as outside interference, tryed all the channels, with and without diversity, same result, so it comes from the VTX, it is a Sunky 1.2 400mw, i will order a 800mw while the video uploads.
thats it, i am sure there is more to be said, but i will think about it.
video to come in a couple of minutes.
ohh. p.s. i used 540 mah of the 4400 available..... this plane will go to the clouds !
Old Sep 03, 2011, 07:23 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
Originally Posted by webdr View Post
I really cools the electronics down well. I went from 105 at the RVOSD5 down to 89 degrees during flight.
I love that ideia, will do that on my next SW as soon as it arrives around 30 to 45days But now I got smart order 2 for me....
mauromassari is offline Find More Posts by mauromassari
Old Sep 03, 2011, 08:31 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by mauromassari View Post
I love that ideia, will do that on my next SW as soon as it arrives arroung 30 to 45days But now I got smart order 2 for me....
yea its nice to have one in backup , its only $99 .. and with bevrc u get free shipping , so win win
octane81 is offline Find More Posts by octane81
Old Sep 03, 2011, 11:26 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
here is the video, i ordered a new vtx since the new camera and rx did not change the white lines i always had with this one and not with the 900mhz.
final picture :
Maiden 3 septembre 2011 (5 min 2 sec)
Old Sep 03, 2011, 11:38 AM
Matt Gunn is offline
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
good lookin' bird
Matt Gunn is offline Find More Posts by Matt Gunn
Administrator
Old Sep 03, 2011, 11:52 AM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
final picture :
http://www.youtube.com/watch?v=1WCuqVREHSA
Can you post a pic of the Vtx installation underneath the wing?
aa78 is offline Find More Posts by aa78
Old Sep 03, 2011, 12:18 PM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
here, it was on last page
http://www.rcgroups.com/forums/showp...postcount=9349
Thanks for the comment Webdr
Old Sep 03, 2011, 12:25 PM
aa78 is offline
Fast and low...
aa78's Avatar
Joined Apr 2009
Thanks.
Old Sep 03, 2011, 07:17 PM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
2nd maiden of the day, this time is my brother, still waiting for his RVOSD G5
almost had no trim to do, he is a good builder ;-)
Maiden Yanick 3 septembre 2011 (4 min 17 sec)
Old Sep 04, 2011, 03:18 AM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
]here is the video, i ordered a new vtx since the new camera and rx did not change the white lines i always had with this one and not with the 900mhz.
the interference seems quite rhythmical.. I wonder if you have you mobile phone with you during the flight ? do you fly LRS ? if so try stepping as far a you can from the ground station and make sure you aerials are as close to the ground as possible.
the sunsky receiver NEEDS a ground plane. leave it on the floor or touch it during the flight or leave it on a metal plate.
rcmonster99 is online now Find More Posts by rcmonster99
Old Sep 04, 2011, 05:57 AM
bakchos is offline
2Vision-Air
bakchos's Avatar
Joined Aug 2009
Thanks but here is the test i did so far
was on the Twinstar 1st, 2.4 rtx, 1.2 vtx, diversity on the GS, 2 vrx of the same type, 1 omni and 1 patch, stock omni on vtx or inverted V = white lines
try new camera, new antenna, removed diversity, new rca cables, new torrid added to all wires on plane, = white lines
then switched it all to the Skywalker, new installation, new wires, all filtered, shielded vtx cables, new Chainlink LRS system, = WHITE LINES !!
then same Vrx, with my brother maiden but he is using my old Dpcav 900 vtx, we did not even change the GS patch and omni (Was for 1.2) and look at his video !
So with all that i identify the Vtx as the responsible for the white lines.
do you think i should try anything else ? lol
the video from my brother 900 is pretty much what made me order a new Vtx from Zoltan at nghobbies, i took the 800mw, since i got a LRS now i can use the extra range, the sunsky 400mw might have been damaged in my twinstar crash last winter.
thanks
edit: if the new Vtx fail, then i will try to take the OsdPro out and try again.
Old Sep 04, 2011, 06:23 AM
KIR2142 is offline
Find More Posts by KIR2142
KIR2142's Avatar
Russia, Klin
Joined Nov 2010
Originally Posted by BEVRC View Post
The newest and final version of the skywalker(V5) will be ready in days, stronger wings and fuselage and tail, no need extra strengthening work any more.
Would it be possible to buy an old fuselage (v2)?
KIR2142 is offline Find More Posts by KIR2142
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
