Old Aug 31, 2011, 12:06 AM
RolandS888 is offline
Find More Posts by RolandS888
Outta Sight
Australia, WA, Joondalup
Joined Jul 2008
Agreed, I'd prefer fibreglass or CF, not steel.
Any chance you might be selling spares like wings, tails, canopies and fuselages?
RolandS888 is offline Find More Posts by RolandS888
Old Aug 31, 2011, 12:27 AM
htran is offline
Find More Posts by htran
Joined Jan 2011
Originally Posted by erkq View Post
Obviously these distances SHOULD be the same. But if they're not, you won't know exactly why. Measure to the center of the back of the airplane instead to make sure the main wings are true. Then you can do the measurement you show to get the stab true, or, a little better, measure the stab to the center of the plane's nose. The way you're showing it you've got more variables than equations.
Yes that's a good idea. I used to do all that when manually building balsa aircraft, but I didn't think to do so with pre fabricated foam. Its been 10 years since I flow rc regularly and now that I'm back into it again, some things have changed (ie the popularity of foam ARF aircraft).
htran is offline Find More Posts by htran
Old Aug 31, 2011, 03:04 AM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I used to build and fly balsa slimers too. Sometimes the old skills become useful in this new world!
erkq is online now Find More Posts by erkq
Old Aug 31, 2011, 03:17 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by CaliDave View Post
Randy's (rsowder) Skywalker captures all of our aerial shots in Dirt Doggin'. Super fun with 3 FPV vehicles at the same time:
http://www.youtube.com/watch?v=_L03KaiEoJo
great video. I really enjoyed it !!
rcmonster99 is offline Find More Posts by rcmonster99
Old Aug 31, 2011, 03:59 AM
Nettraptor is offline
Find More Posts by Nettraptor
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
+1.....
Nettraptor is offline Find More Posts by Nettraptor
Old Aug 31, 2011, 05:48 AM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
+2...
scrape is offline Find More Posts by scrape
Old Aug 31, 2011, 06:12 AM
mauromassari is offline
Find More Posts by mauromassari
mauromassari's Avatar
Brasil, CE, Fortaleza
Joined Jun 2011
+3.....
mauromassari is offline Find More Posts by mauromassari
Old Aug 31, 2011, 06:43 AM
htran is offline
Joined Jan 2011
Maiden flight of the Mini Skywalker
http://www.youtube.com/watch?v=lUbSn-DTLc4
Old Aug 31, 2011, 08:38 AM
MrSilvia is offline
Find More Posts by MrSilvia
BoyDrone
Joined Jan 2011
3rd Attempt = Broken nose
Hello all,
So I finally had an opportunity to attempt to fly my skywalker. After catching up on this thread, I think I know where some of my issues lye.
First of all, worth mentioning that I am trying to fly it with a 5kmah battery.
The Battery is secured via two small velcro strips that dont really do what velcro is supposed to do...
on my second attempt I got the plane to fake off, but it pretty much stalled since i was banking too high.
on my third attempt yesterday, the same thing happened, and it got so high that back on its way down, the battery came loose and most of the nose was damaged.........
I have landing gear on the plane. two front wheels and one free wheel spring loaded in the back.
So I was doing some thinking overnight about this....
My CG is clearly not static. I am planning on "fixing" up the plane soon to try again before the weather goes to the -'s
what would be nice to be supplied is a foam insert. that would go into the plane, that would fill the entire cavity. maybe two pieces, sandwiched.
the idea would be to provide the "cavity insert" and have the users cut out sections of it for batt, ESC, reciever... etc. so nothing has a chance to move around. and it would be better to design the nose not closed off the way it is. but integrated into this cavity insert. If whoever has the 3D models of the plane, I can make the changes and update it for them.
also, for the elevator. its very unstable. a simple A frame support can be made that would install very easily from the top. and could provide more lift with a flap connected. I will do some sketches and send or if someone want to PM me, I can send that way too.
but i guess my question is: How do i know exactly where to install my landing gear??? move it front/back?
MrSilvia is offline Find More Posts by MrSilvia
Old Aug 31, 2011, 08:50 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Originally Posted by Daemon View Post
Uhhhh.. 1 small joiner instead of two? Steel tubes in the wings to block and reflect Rf from video Tx?
You sure you're headed the right direction here?
ian
mmm how can you tell its steel? Me no like either if that is true.
The current two tube setup for the current wing joining works well for me. Just needs a bit more strength through to near end of the span
BEV .. Like to see full list of changes from previous.
Canopy - I like that... this is a plus...
Shikra is offline Find More Posts by Shikra
Old Aug 31, 2011, 10:36 AM
in_out is offline
Find More Posts by in_out
in_out's Avatar
Espainia, PV, Berriz
Joined Jul 2011
Originally Posted by BEVRC View Post
The newest and final version of the skywalker(V5) will be ready in days, stronger wings and fuselage and tail, no need extra strengthening work any more.
stronger wings and fuselage and tail ... but not to go at 100km/h -60mph hehehe...
in_out is offline Find More Posts by in_out
Old Aug 31, 2011, 10:55 AM
erkq is online now
Joined Dec 2010
+4...
Old Aug 31, 2011, 10:56 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The caption under the photo he posted says "steel tube built in".
ian
Daemon is online now Find More Posts by Daemon
Old Aug 31, 2011, 11:42 AM
Joined Jun 2011
Thanks, alredy lear that leason at the hard way... Don't worry will not going to happen again.
Old Aug 31, 2011, 12:47 PM
Joined Jun 2011
Hi again, does anyone know when BevRc will have SkyWalker for sale? On the web site it show todays date. Am I wrong?
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
