Old Aug 24, 2011, 05:10 AM
takeoff2 is offline
Find More Posts by takeoff2
takeoff2's Avatar
Romania, CL, Călărași
Joined Jan 2009
Originally Posted by troynh View Post
This isn't an FPV flight but thought I'd post anyway... I've had this SW kicking around for close to 6 months + and I just got around to putting it together. I scavenged the wing spars from the kit for another project a month or so ago. So, Instead of using the original wing, I'm using an Easy Glider wing. The maiden was tonight and everything went very well. The AUW is around 54 ounces. The motor is an old Rimfire 35-30-1450 spinning a 9x3.3 SF. One 3s 2650. It was getting dark and it shows in the GoPro footage but that was shot in the R5 1080P mode.
-Tim
Super flight, where CG is in this case?
takeoff2 is offline Find More Posts by takeoff2
Old Aug 24, 2011, 06:30 AM
htran is offline
Find More Posts by htran
Joined Jan 2011
Originally Posted by brifa View Post
i don't think so
without fy21 i had to put CG on the servo wire and it flies well... finally...
then i used fy 21 with that CG and no issues...
According to the manual the CoG should be 75mm from the leading edge. I measured that today and if I put my CoG there its about 6mm FORWARD of the servo leads.
I measured 30mm aft of the servo leads, and if I were to put the CoG there that would be way too tail heavy. In fact my first flight resulted in uncontrolled collision into terrain because the battery moved back 3/4 inch. I couldn't even hand launch with CoG there far back.
htran is offline Find More Posts by htran
Old Aug 24, 2011, 06:33 AM
htran is offline
Joined Jan 2011
Originally Posted by nyc863 View Post
ardupilot mega has a LOT of PID tuning parameters
the defaults are not going to suit your setup. have you tried tuning them?
I used the Skywalker.params that is provided. I was however surprised why the Pitch P was set for 3.3 when the default is 0.8. I was playing around using XPlane for hardware in loop and I had to dial it down to 0.4.
The problem with using ardupilot mega is that I have to drag my laptop down to the field to tune the PIDs, and right now my skywalker needs stablisation, so I'm installing the FY21AP II now, as everyone's telling me it works well.
Old Aug 24, 2011, 08:40 AM
htran is offline
Joined Jan 2011
Originally Posted by Daemon View Post
The plane (any/all planes) does not need any more power to fly upwind at the same
airspeed as it flies downwind. The only thing that can cause it to stall
is you at the sticks, choosing to slow it down when you turn downwind
because it *appears* to be going too fast from the ground.
You wouldn't have this problem if you were actually piloting it FPV
and simply letting it fly the speed it wants to.
It'll fly with the CG anywhere from the servo slots to about 35mm behind the servo
slots. 30mm is optimal but control throws must be reduced.
ian
@Daemon, upon reflecting over the last 8 flights of the SW, I think its too tail heavy as the CoG is too far toward the aft. So this is my recollection of the flights.
Flights 1-6 where done with 4S 6000MaH battery and ReadyRC Camera pod canopy. Flights 7+ done with standard foam canopy and undercarriage. Flight 9-10 done with 4S 5000MaH battery.
Flights 4-6 where the most successful flights.
Flights 1 - 3 CoG was aft of flights 4 - 6.
Flights 7 - 10, weight was removed from the front (ie. FPV pod and going to smaller battery), therefore I assume CoG moved aft compared to flights 4 - 6.
These are the results of each flight:
Flight 1. Ground take off, nose up, plane banks left, full right aileron, plane still is banked left with nose up attitude, powered off, crash landing, landing gear torn off.
Flight 2. Hand launch, flys straight but fails to maintain level flight refuses to gain altitude, belly landing
Flight 3. Hand launch with flaps down, maintaining straight and level @ 1m AGL but can't climb, flaps up, plane lands.
Discover that the battery pack has moved 3/4 inch rear, move battery pack forward and secured it.
Flights 4 to 6, successful hand launch and completed a number circruits. Battery only lasted about 15 mins with throttle needed to be 3/4 to full for most of flight.
Flight 7. Change to foam canopy, had to abort one take off due to not lifting off. Hand launch successful, aircraft seems to be fighting the wind, full power required most of flight.
Discovered prop on backwards.
Flight 8. Take off on half throttle, much more power. Still fighting the wind. Aircraft almost rolls past 80degs on turn to crosswind. Aircraft enters spin on turn to base leg.
Flights 9-10. Change battery to 4S 5000MaH. Climbing well on take off, turn cross wind fighting the wind as it wants to roll me over. Turn to downwind, can not maintain height, losing height on full power. Power off, nose into wind, glide landing
Old Aug 24, 2011, 08:47 AM
troynh is offline
Find More Posts by troynh
No thrust...It'll bust...
troynh's Avatar
Troy, NH
Joined Sep 2006
Start at the standard (Easy Glider) 70mm from the leading edge and move up from there. I'll have to load it back up and find where mine landed last night. It's well in front of the standard 70mm mark.
Also, I added a 1/4" piece of of basswood to the LE to give the wing roughly 2 degrees of incidence.
-Tim
troynh is offline Find More Posts by troynh
Old Aug 24, 2011, 09:01 AM
htran is offline
Joined Jan 2011
I've just done some balance checks with the load out of my SW from the previous flights. It looks like with the FPV pod the CoG with 4S 6000Mah is just foward of the servo leads. Without the pod and using foam canopy the CoG has moved aft of the servo leads. That explains how come flight performance started getting bad when I started flight with the foam canopy.
Now tested with today's configuration 4S 5000MaH with the foam canopy, and the CoG is again aft of the servo leads but more so than with the 4S 6000Mah. This correlates with the performance getting worst. When I put on the FPV pod the CoG is on the servo leads. Now I move the 4S 5000Mah all the way to the front, and the CoG is now on the 75mm line recommended in the manual.
I will test fly tomorrow and post results to see if they validate my theory.
Old Aug 24, 2011, 09:02 AM
BushmanLA is offline
Find More Posts by BushmanLA
BushmanLA's Avatar
Joined Dec 2005
Something is horribly wrong here.
I fly with CoG about 25mm behind servo leads.
4S 9x6 prop 1400kv motor
I can take off at 20 amps no problem, if I juice it more than that it wants to jump out of my hands.
BushmanLA is offline Find More Posts by BushmanLA
Old Aug 24, 2011, 09:08 AM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
I usually give about 10amp (4S lipo) at takeoff , no more is needed... and then just give it a gentle throw.. away it goes!
octane81 is offline Find More Posts by octane81
Old Aug 24, 2011, 09:18 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Hey guys, since there are so many options and questions regarding motor/prop/ESC and other electronics would it be beneficial for all to group all the options in a separate thread for Skywalker instead searching individual posts here?
Something like this:
http://www.rcgroups.com/forums/showthread.php?t=1494373
nakelp86 is offline Find More Posts by nakelp86
Old Aug 24, 2011, 09:36 AM
htran is offline
Joined Jan 2011
Ok, maybe your servo leads are in a different position than mine (I have v4 SW). The only real point of reference is the leading edge.
How far back from the leading edge is your CoG?
Old Aug 24, 2011, 10:33 AM
octane81 is offline
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
That is very wrong ! and i dont think thats an CoG issue
htran is offline
Joined Jan 2011
Originally Posted by Crist Rigotti View Post
Ian,
Where iis the center of lift located on the Skywalker?
lift acts at the CoP (Centre of Pressure)
Old Aug 24, 2011, 10:35 AM
htran is offline
Joined Jan 2011
@Octance, it is very correct, as per my post, I later discovered the low flight time was due to the prop behind mounted backwards, which after fixing resulted in flights 7+ using very little battery, and being able to take off at half throttle in 1/3 the distance.
It all starting getting worst when I started removed weight from the front
Changing from FPV canopy to standard foam and then and even more worst when I went from 4S 6000 to 4S 5000
Old Aug 24, 2011, 10:59 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
My CoG is currently about 25mm behind the servo wires (on a v2)
I think you'll find the SkyWalker has a very wide range it can accept and still fly because of teh large underhanging fuselage.
I started on the recommended point and moved it back 5mm at a time, adjusting the elevator each time so it would fly hands off level.
Then it's a case of getting it as close to the point wher eit doesn't pitch up or down under the various throttle settings
Shikra is offline Find More Posts by Shikra
Old Aug 24, 2011, 11:01 AM
htran is offline
Joined Jan 2011
Shikra, how far back from the leading edge is your CoG?
Also, planes should pitch up when you increase throttle, that's how you'r suppose to climb. Sounds a bit weird to setup a plane not to pitch up when throttle is increased.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
