Old Aug 22, 2011, 05:59 PM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
I also dont use a rudder.
Cir2kuk is offline Find More Posts by Cir2kuk
Old Aug 22, 2011, 10:01 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Originally Posted by AdamChicago View Post
I'm just about done with my Skywalker rebuild after a crash in June but now I want to power my radio/LR UHF Tx (hitec A9 with Scherrer LR UHF) from a 12volt lead acid battery connected to a Castle Pro BEC, but am not sure if the BEC's output amperage will work with the A9's max input amperage...does anyone know the answer to this?
I'd make my way over to the radio forums and ask there. Maybe you'll get an answer here, but that's a very specific question to ask. I couldn't tell you the draw of my Fut 9C and that's what I fly with. Let alone what someone else flies with I'd kind doubt that a radio would draw a ton of power. If my 2500mah lipo will power my TX for... say... 6 hours (which is on the safe side, but I don't know exactly) then it's only drawing... well not a lot at all
I could be wayyyy off target here, so you should talk to someone that knows their stuff. But that's a good idea
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Aug 22, 2011, 10:28 PM
nyc863 is offline
Find More Posts by nyc863
Joined Nov 2008
@AdamChicago: Of course it will work: you need just 1 amp for regular TLRS and 3 amp for high power setting or 10 amp for booster. The hitec TX power use is inconsequential.
But you are over-engineering. You don't need a heavy lead-acid battery.
Just get a cheap 20c 6s lipo. It'll run your transmitter and TLRS for ages. You can buy an "Any to 12v" regulator with 16amp output on ebay for $20. The ones that are in a metal case.
Much more reliable than the Castle.
nyc863 is offline Find More Posts by nyc863
Old Aug 23, 2011, 01:10 AM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I use lots of rudder, mainly to keep plane turning level instead of banking so I counteract turning with ailerons.
In an approach prior a sequence for video I can use ailerons/rudder as per normal, but when I fly in the area I want to record I always try to keep camera movements smooth.
UndCon is offline Find More Posts by UndCon
Old Aug 23, 2011, 05:26 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Another vid for you SkyWalker nuts....
BTW, this place is up for sale - 2 million......
http://www.vimeo.com/28047228
Why is it when you head out all is calm, then as soon as get to the field the wind starts up. meh it P's me off.
I guess the answer is to get up early!!
Shikra is offline Find More Posts by Shikra
Old Aug 23, 2011, 09:07 AM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Thanks for your info, I have been trying a few threads because this is kind of an obscure question....but it is for my SW and this thread has a LOT OF experienced FPVers. Currently my 2500mah lipos only last about 10mins, maybe 15mins powering the A9/Scherrer LR @ 2Ws with a 30ft shielded cable in between and that's why I wanted to move to lead acid so I can just go the whole day without worrying about losing power. I've seen other's ground stations that use lead acid but can't find those specific posts now. I may just bail on the lead acid and go with a 6000mah lipo.
AdamChicago is offline Find More Posts by AdamChicago
Old Aug 23, 2011, 09:12 AM
nyc863 is offline
Joined Nov 2008
2500mah 3s at 10w is 1 amp
that should last 2 hours
something wrong: look deeper!!
even if the a9 was running it's rf (usually not if you plug in, nor do you want it to) you should still be good..
Old Aug 23, 2011, 09:38 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Agree, something isn't right!!
I run 2500 with a scherrer like probably many others and it lasts a fair time. Not sure how long excactly, but I had 2 * 1 hour flights without recharge. Certainly capable of more. Not at 2W though...
Old Aug 23, 2011, 09:58 AM
Chicago, IL USA
Joined May 2010
Thanks for the info...actually the lipo is a 2S (7.4v) and I'm using it with the Scherrer LR set at 2Ws
Old Aug 23, 2011, 01:10 PM
cliffkot is offline
Find More Posts by cliffkot
cliffkot's Avatar
Joined Jun 2010
OK, now I understand the problem. i went to the Scherrer site and noticed that he uses an internal switching supply that bumps the voltage to whatever his circuit requires. A 2S battery voltage is just too low for efficient operation, way too much current draw.
I seem to recall that you use a 4s for the Zeph. In that case in the interest of simplicity, I think I'd run the UHF on the same size lipo battery that you have in the Zeph (or Skywalker). That way you don't need to have a lot of oddball stuff that has only one purpose. You could also run the UHF on a lead acid battery if you prefer, but either way I'd mount that battery close to the transmitter and use decent leads, maybe some #18 speaker wire. I would also power the RC radio with its own internal battery.
Cliff
PS - Looks like the UHF can use up to a 6S. You could also wire 2, 3S packs with the same mah ratings in series if that would be more convenient
cliffkot is offline Find More Posts by cliffkot
Old Aug 23, 2011, 05:17 PM
motojoe996 is offline
Find More Posts by motojoe996
motojoe996's Avatar
Panama City, Fl
Joined Jan 2009
Originally Posted by rcplanes1234 View Post
This is the one I use with a 10x5 prop. On a fully charged, well used 4S battery and a wattmeter, I get 32.4A and 509W. In the air, I never get over 32A, and mid to upper 20s for take off.
I have a few vids on YT under my name for verification.
Joe
motojoe996 is offline Find More Posts by motojoe996
Old Aug 23, 2011, 05:25 PM
octane81 is online now
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Another successful LR flight with Skywalker , what an awesome bird !!
Scary landing(w/goggles) , felt like I was about to hit those trees
Skywalker 12.5KM FPV Flight #009 (13 min 8 sec)
octane81 is online now Find More Posts by octane81
Old Aug 23, 2011, 06:03 PM
Cir2kuk is offline
Chris R
United Kingdom
Joined Dec 2009
octane81 your MAH is very low for 25km round trip!
Yours 3500mah to do 25km
Me 4000mah to do 20km
Maybe its down to lipo weight and wind speed! or did you fly with crosswind?
Old Aug 23, 2011, 06:15 PM
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
It was almost no wind this day, that might be why.. i dont know.
I just set the throttle to cruise at about 70km/h , 7-8amp drain.
Im carrying a 5000mAh + 2200mAh for video (however it only drained 300mAh for the whole trip)
Old Aug 23, 2011, 06:26 PM
Cir2kuk is offline
Chris R
United Kingdom
Joined Dec 2009
I was flying into 10mph head wind, but that shouldnt matter if you fly back with tail wind helping you!
I carry 4s 6000mah and 3s 2200mah for video.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
