Old Aug 22, 2011, 10:10 AM
lrrps is offline
Find More Posts by lrrps
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Originally Posted by nyc863 View Post
There is a turnigy motor popularly mentioned, just search in the topic for 'turnigy motor', on 3s. Usually with a 9x6 prop. If you want less maximum power for slightly more efficient cruise you can do 9x5 or 9x4.5. You can do 10x5 if you mount the motor higher than instructed. Props are pretty cheap, buy a bunch and just try.
You can do folding props but my opinion is what little they save in a long glide from high altitude home probably doesn't make up for them being slightly less efficient. Make sure to enable brake in the ESC. This isn't a plane for finding thermals or doing a lot of motor off stuff.
From office depot you can buy a bag of big rubber bands, I forget the "# number". They are narrower and a bit tighter than the ones shipped, but you get so many you can throw them away after a few flights if you are worried about one snapping. Since they are a bit tighter you don't have to do "triangles" with them, just one on each cross direction, and one on each front-back. They can dent the EPO a little but it is minor.
Thanks a lot for the input, I'm planning on mounting a 4S 5000 mAh lipo pack, will a 9X6 prop fit the bill?
lrrps is offline Find More Posts by lrrps
Old Aug 22, 2011, 10:11 AM
lrrps is offline
lrrps's Avatar
Le Havre, FRANCE
Joined Feb 2007
Originally Posted by man2000me View Post
Turnigy 3536 1400kv
Thanks for the input.
Old Aug 22, 2011, 10:14 AM
rcplanes1234 is offline
Find More Posts by rcplanes1234
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
Also to add to my post. Would this motor work as well
http://www.bphobbies.com/view.asp?id...7&pid=B1898547
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Aug 22, 2011, 10:24 AM
Joined Jan 2010
or this one
http://www.bphobbies.com/view.asp?id...7&pid=B1858544
Old Aug 22, 2011, 12:15 PM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I am very happy with my 3536 1400KV from HK running a Graupner Cam 9*6 foldable.
UndCon is offline Find More Posts by UndCon
Old Aug 22, 2011, 12:31 PM
htran is offline
Find More Posts by htran
Joined Jan 2011
I've done about 8 flights on my Skywalker, but unfortunately I'm not experiencing the same "very stable" platform that people have been saying about the skywalker. I was at the park on the weekend in 10kt wind. After take off I turned cross wind, and almost got rolled over by the wind picking one wing, I had to use full opposite aileron to level off. As I turned from downwind to base, the skywalker suddenly entered into a spin mid turn. Incipient spin recovery worked, I pulled out of it, and flew upwind, but it wasn't stable, got knocked around by the wind.
htran is offline Find More Posts by htran
Old Aug 22, 2011, 12:54 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Were you in a park, surrounded by trees while trying to fly in the wind? That'll create
turbulence that is very unpleasant and potentially fatal to fly in.
ian
Daemon is online now Find More Posts by Daemon
Old Aug 22, 2011, 01:01 PM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
Fly high and get above the wind turbulence.
Cir2kuk is offline Find More Posts by Cir2kuk
Old Aug 22, 2011, 01:08 PM
Joined Jan 2010
You like flying high haha!
Old Aug 22, 2011, 01:09 PM
Cir2kuk is offline
Chris R
United Kingdom
Joined Dec 2009
The higher the better.
Old Aug 22, 2011, 03:06 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
I'm just about done with my Skywalker rebuild after a crash in June but now I want to power my radio/LR UHF Tx (hitec A9 with Scherrer LR UHF) from a 12volt lead acid battery connected to a Castle Pro BEC, but am not sure if the BEC's output amperage will work with the A9's max input amperage...does anyone know the answer to this?
AdamChicago is offline Find More Posts by AdamChicago
Old Aug 22, 2011, 04:26 PM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
SkyWalker vs TwinStar
Can someone that owned both planes tell me the difference in flying characteristics of these two planes?
I'd like to get SkyWalker for few reason, bigger wingspan which probably means better efficiency, it looks like flying a bit faster, i don't want another easy glider or similar, and one motor which means less things to go bad, but there is a possibility i wouldn't be able to get that thing since shipping to here is insane.
I've noticed Twinstar gets decent efficiency, approx 8A on 3S with around 40kmph cruising speed.
hefest is offline Find More Posts by hefest
Old Aug 22, 2011, 05:17 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
Anyone fly with the Rudder disabled?
I ask because I have 9ch and they are all going to
be used up......just asking how it flies without Rudder.
LexusFPV is offline Find More Posts by LexusFPV
Old Aug 22, 2011, 05:20 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
why don't you use a Y cable and connect it with ailerons ? not perfect but better than not having it...
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Aug 22, 2011, 05:24 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I fly without rudder. No problems.
Here's my You Tube channel.
There are plenty of videos, none of which are using rudder.
http://www.youtube.com/user/beesonmf?feature=mhee
m_beeson is offline Find More Posts by m_beeson
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
