Old Jun 17, 2010, 01:51 PM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
Originally Posted by Crist Rigotti View Post
The attached photo is not the one I was referring to.
Talajouy is offline Find More Posts by Talajouy
Old Jun 17, 2010, 03:33 PM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by Talajouy View Post
But still I can not understand what is backward?
the attached photo show the way I always use the props, if I use it in wrong way your advice is welcome
When using a prop for pusher must put in backward to keep the attack edge
always forward.
Any way I'm sure you read more than I do.
I must say I am with Crist on this one.... for a moment it looked like he was right and one of the pictures looked like the prop is installed the wrong way...
even looking at the pictures two posts ago they all look wrong.
Either the pictures return a false perspective or someone is well confused with propeller orientation.
a propeller has a concave side and a convex side. The convex side should alway point towards the front of the plane . I would not trust on the writing although the writing is generally on the convex side.
Now... here we are trying to help each other and I think some smart comments are uncalled for.
All of us write in here in good faith. This is a genuine case and believe it or not, this is a very common mistake .
A propeller mounted backwards will be so inefficient that the plane will feel underpowered despite the motor burning the right amount of power.
rcmonster99 is online now Find More Posts by rcmonster99
Old Jun 17, 2010, 03:47 PM
iw28 is offline
Find More Posts by iw28
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
Is it really necessary to discus this?????
(how the prop is installed in the wrong way)
iw28 is offline Find More Posts by iw28
Old Jun 17, 2010, 04:48 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
It is mounted properly on all photos. But it is easy to get confused, since some photos are taken from an unfavourable perspective. No reason to blame anyone...
Miha
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Jun 17, 2010, 05:07 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Did no one notice the tip? It's the right way around.
Martin Y is online now Find More Posts by Martin Y
Old Jun 17, 2010, 05:38 PM
~>Miha<~ is offline
~>Miha<~'s Avatar
Joined Dec 2009
Okay, folks, those who want to see something that indeed is mounted erroneously, check out the attached photo I copied from a webshop.
It is from one vendor that sells our Skywalker. Not going to mention name. But the "culprit" will recognize it
Anyway, not a problem. Just a bit funny.
Oh, and I can recommend this vendor nevertheless! Keep it up, Hooks!
Miha
Old Jun 17, 2010, 05:41 PM
Dimitris76 is offline
Find More Posts by Dimitris76
United States, IN, Carmel
Originally Posted by LFLoTiTo View Post
- Magnets on canopy (not new either)
Luiz,
what did you use to glue these magnets in the foam.
On my Polish EPP bird I have tried both with CA and UHU Por, and on the first try the magnets ripped themselves straight out of the foam...
Is there a special technique?
Dimitris
Dimitris76 is offline Find More Posts by Dimitris76
Old Jun 17, 2010, 05:49 PM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Miha
Unless he puts the prop as a tractor then it's not a tail but canards.
Old Jun 17, 2010, 09:19 PM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
that tailplane orientation is... sub-optimal.
Keep it up, Hooks!
Miha
Definitely out-of-the-box. Remember to reverse the elevator.
borneobear is offline Find More Posts by borneobear
Old Jun 17, 2010, 09:26 PM
Talajouy is offline
Joined Aug 2007
I do, I learn many things from other guys right here, by reading and watching photos, I had never this chance to have a single hour class or someone to teach me about RC except you people right here.
I learn many things from Crist Rigotti specially, he always share his experience generously.
I apologizes if said or show something wrong.
I really confused for a moment cause I trust his experience and trust what I saw, thats why took those photo to be sure about it and learn if I was wrong.
I do, I respect all you guys that share your knowledge and experience here.
Cheers
Habib
Old Jun 17, 2010, 09:48 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Cheers
Habib
Habib,
The prop in the picture that I was referring to looks like it has been put on the motor shaft backwards. After closely studying the picture it does look like its on correctly. All I asked was if it was me. Obviously it was me. Son of Paleface's comments about not reading the thread is what I took exception to. I felt there was no need to discuss your pictures because they were not the object of the last several posts. I meant no disrespect to you at all.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jun 17, 2010, 10:27 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Miha
hahaha, well spotted.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old Jun 17, 2010, 10:29 PM
bob loblaw is offline
Find More Posts by bob loblaw
Crashy McLandington
Northern Colorado
Joined Dec 2005
Originally Posted by Dimitris76 View Post
Luiz,
Dimitris
I don't know if you can buy them separately but the Radian has neat magnet holders. They slide into the foam and the magnet slides into a groove in them. No way they can come out unless the foam breaks.
bob loblaw is offline Find More Posts by bob loblaw
Old Jun 17, 2010, 10:32 PM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
I have used 5min epoxy for magnets.
Cheers, Kev.
Old Jun 17, 2010, 10:58 PM
Joined Mar 2008
Yup, me too.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
