Old Jun 16, 2010, 12:05 PM
techspy is online now
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Thanks for the info LFLoTiTo. I assume you mean you gave full rudder left instead of full aileron left? Any idea what your approx rudder deflection is at full turn? I am just trying to get an idea on what the max should be as I did notice quite a bit of altitude loss when turning with rudder and had to add quite a bit of elevator and aileron to keep it straight. Maybe I was just using too much rudder. So to make sure I understand, even though you gave full rudder in the setup, the gain and limit values determine how much rudder is actually used by the OSD in RTH? What about the elevator mix? Does it match exactly what it saw in setup or does it use gain setting somewhere?
techspy is online now Find More Posts by techspy
Latest blog entry: My Esprit Saga
Old Jun 16, 2010, 12:27 PM
LFLoTiTo is offline
Find More Posts by LFLoTiTo
Just want to fly...
LFLoTiTo's Avatar
Brazil
Joined Mar 2009
You are correct, I wrote it wrong (fixed now).
The gains/limits seems to reduce your inputs, thatīs why I gave full rudder during the wizard. The wizzard suggests that you simulate a turn, but I have learned on my other plane that if I do that I will have to greatly increase the gains latter. So on this one I gave 100% and it worked from start.
I donīt know about the elevator as I did not bother to check itīs deflections since the RTH was working smoothly. But at 10% input, it wonīt make such a difference.
Erwin and fijnetcom,
Thank you for your nice comments.
Cheers,
LFLoTiTo is offline Find More Posts by LFLoTiTo
Old Jun 16, 2010, 12:29 PM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Got it. Thanks
By the way, how do you like using the co-pilot with the osd? I was going to use my co-pilot but went with my AP2000i as I really like being able to calibrate in the air. I am thinking that the AP2000i should help keep it level and not lose altitude when turning in RTH.
Old Jun 16, 2010, 01:03 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Very nice airplane, you did a great job putting it together. Is it me or is the prop on backwards?
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jun 16, 2010, 01:19 PM
VAMountains is offline
Find More Posts by VAMountains
Joined Mar 2010
Prepare to be amazed by my idiocy; I do this only so that others don't make the same mistakes.
Unfortunately, I think I might be the only one that put the ESC in the little ESC-shaped nook/compartment between the engine mount and the upper open compartment. I don't have a picture, but there's a slot that fit my Turnigy Plush 40amp perfectly. I regret it now because it can't be removed without some disassembly, and there's no airflow in there. Now I'm going to have to cut it out... carefully. Why is the nook there given these disadvantages?
While I'm 'fessing up to my embarrassing assembly decisions in the hopes that others don't repeat them, I also want to ask why has no one put the GPS chip in the little compartment right over/behind the nose? It fits there perfectly, protects the chip, and provides LOS to satellites overhead. It seems like a great place, but I assume I'm missing something because I haven't seen anyone else put it there.
Oh yeah, and one more thing for fellow newbz. Don't glue the wooden disk to the foam engine mount before you mount the engine. Initially, I thought that I'd be able to drill into it with self-tapping screws after gluing the disk in place to secure the engine, but quickly learned that I needed metal receiving nuts (wrong terminology I know) on the back to hold it in place, even with lock-tite. I had to fashion another wooden disk, mount the motor, and then glue that disk the first one (which can't be removed without an act of demolition). It looks a little ridiculous.
See, Sander? Some of us do need manuals.
VAMountains is offline Find More Posts by VAMountains
Old Jun 16, 2010, 01:30 PM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
lol, you'll get there VAM.
Cheers, Kev.
Kev.au is offline Find More Posts by Kev.au
Old Jun 16, 2010, 03:11 PM
LFLoTiTo is offline
Just want to fly...
LFLoTiTo's Avatar
Brazil
Joined Mar 2009
Those are not idiot but commom mistakes that you need experience to learn. Thanks for sharing and preventing others from doing the same.
When done properly, those empty spaces save weight without significantly reducing the frame strength. They also reduce mass production costs, as less material is needed.
The top compartment also has no ventilation, which might be an issue depending on your set-up. You might want to drill a couple of air in-takes or use an over-rated ESC that will dissipate the heat easier. I did both...
GPS receivers are often affected by video TX and some cameras which usually go on the canopy. This might reduce its ability to get satelites or even to get a lock position. Putting the GPS antenna away from theses sources greatly increases its sensitivity.
You need a self taping screw specifically designed to hold on wood. It has deeper and more spaced threads that should hold your motor mount properly. It is best to pre-drill a 1mm hole to set the path and put a drop of CA to strenghen the wood around it before you insert the wood screw. Be carefull not to overtighten it or you will loose its ability to hold it.
TechSpy,
The OSD Pro handles heading, altitude and thrust/speed, while co-pilot stabilizes the plane. They are complementary tasks, but performed independently, meaning that the OSD doesn't interact directly with the co-pilot (yet). My plane did not need to enter in climb mode during RTH (so it did hold alt ok) but if the altitude goes below the designated minimum, the OSD will increase power and pull elevator to climb back to cruise altitude (I successfully tested this as well).
Although this plane is supposely self stable, I would not trust any auto-pilot without a stabilization system.
Cheers,
Old Jun 16, 2010, 11:26 PM
Talajouy is offline
Find More Posts by Talajouy
Australia, QLD, Gold Coast
Joined Aug 2007
The prop is backwards because its a pusher, I think is supposed to be like that.
Am I right Crist?
Talajouy is offline Find More Posts by Talajouy
Old Jun 17, 2010, 02:40 AM
SON OF PALEFACE is offline
Find More Posts by SON OF PALEFACE
Ozzie Express wiggy pilot
SON OF PALEFACE's Avatar
YANKALILLA , SOUTH AUSTRALIA.
Joined Nov 2002
Am I right Crist?
You are right mate........how many people write before thinking or reading the thread...
SON OF PALEFACE is offline Find More Posts by SON OF PALEFACE
Old Jun 17, 2010, 07:43 AM
Joined Mar 2008
Am I right Crist?
The prop being on backwards has nothing to do with a pusher. I'm was looking at the the direction of the pitch of the baldes. In the up close picture of the motor that shows the GPS and FMA sensor, the lower blade appears that the LE of the blade has the air moving towards the motor. That's whay I made that statement.
Old Jun 17, 2010, 07:46 AM
Joined Mar 2008
I did read this thread and I was only trying to clarify something I thought I saw. I hope your comment wasn't directed at me because if it was you're mistaken about not reading this thread.
Old Jun 17, 2010, 09:09 AM
Talajouy is offline
Joined Aug 2007
But still I can not understand what is backward?
the attached photo show the way I always use the props, if I use it in wrong way your advice is welcome
When using a prop for pusher must put in backward to keep the attack edge
always forward.
Any way I'm sure you read more than I do.
Old Jun 17, 2010, 09:37 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
yes that is correct. Print side should be towards the front of the plane.
ashdec87 is offline Find More Posts by ashdec87
Old Jun 17, 2010, 11:18 AM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Prop direction, writing on the prop could be on either side depending on the maker.
NOT ALL props have the writing to the front.
Look here...
http://www.rcgroups.com/forums/showp...7&postcount=16
galaxiex is offline Find More Posts by galaxiex
Old Jun 17, 2010, 11:46 AM
Joined Mar 2008
always forward.
The attached photo is not the one I was referring to.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
