Old Aug 07, 2011, 09:29 PM
nyc863 is offline
Find More Posts by nyc863
Joined Nov 2008
cool, you got yourself a sort-of naca duct.
nyc863 is offline Find More Posts by nyc863
Old Aug 07, 2011, 09:40 PM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
Originally Posted by webdr View Post
For those interested, a plastic spoon cut in half makes for great cooling intakes. I attached them with hot glue. The top scoop cools the esc and the bottom cools the RVOSD5. Before the OSD would hit 112-degrees. After cutting the scoop, it stays around 89 degrees.
Good Idea, I like.. I like
Eternalflight is offline Find More Posts by Eternalflight
Old Aug 07, 2011, 09:45 PM
bakchos is online now
Find More Posts by bakchos
2Vision-Air
bakchos's Avatar
Canada, QC, Blainville
Joined Aug 2009
So...... where can we get that SW ?
BevRc and LowpriceRC ?
Bevrc is out of stock, any other place worth buying from ?
bakchos is online now Find More Posts by bakchos
Old Aug 08, 2011, 02:03 AM
Nettraptor is offline
Find More Posts by Nettraptor
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
Originally Posted by peatmoss View Post
Did you embed the tx in the wing or just tape it to the outside? Check out this info from Crist http://www.rcgroups.com/forums/showthread.php?t=1309106
Wonder if drag caused the issue?
i embed the tx into the wing and used 800mw
Nettraptor is offline Find More Posts by Nettraptor
Old Aug 08, 2011, 02:35 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
let me tell again what i did.
Christ rigotti put his tx Below wing. I put it in the same position but above. embedded into the wing with Cloverleaf antenna.
so i make a demo flight just like that. The plane bang to the right when i throw it into the air. but i manage to land it.
After that i put some weight 60gr to the other wing to balance the wing i put it below left wing.
so i make a demo flight and this time it was realy hard to turn right or left , it was stack to go straight, i was lucky again and manage to land it
this happen maybe because i put the weight below the left wing and not above ,like i did in tx wing? i dont know.
i better move that tx to safe in front position , but it is realy cool to keep it into the wing.
Old Aug 08, 2011, 02:59 AM
alan.tz.tan is offline
Find More Posts by alan.tz.tan
alan.tz.tan's Avatar
Joined Apr 2011
Originally Posted by EarthOrbiter View Post
Let me guess.
High pressure system near Redding California?
Possibly around the central valley.
Nice flying.
Actually this is in the Bay area, more precisely, RC flying field in Ranch San Antonio, close to Cupertino, CA.
Glad you like it.
TZ
alan.tz.tan is offline Find More Posts by alan.tz.tan
Old Aug 08, 2011, 07:14 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
OK reading this makes me thing the following.
1) Are you on 1.2GHz VTX if so, the cloverleaf antenna at the wing tip would be a massive drag. I use my VTX following the same way as Crist Rigotti but I use an inverted Vee at the wing tip, so minimum drag here.
2) My SW also had problems being lazy on the turns, I cured it by sealing the gap between aileron and wing with tape, by introducing differential aileron (moves more UP than down) and by mixing rudder with ailerons.
Mine turns on a sixpence
rcmonster99 is offline Find More Posts by rcmonster99
Old Aug 08, 2011, 08:00 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
i'll put in the standard place behind the motor. and i will fill the gap i made to wing with some lightweight putty
Back to the basics!!
Old Aug 08, 2011, 08:17 AM
Patchitagain is offline
Find More Posts by Patchitagain
NE Texas, USA
Joined Jan 2011
$89 at readymaderc.com... and in appears to be in stock..
-Paul
Patchitagain is offline Find More Posts by Patchitagain
Old Aug 08, 2011, 08:19 AM
NE Texas, USA
Joined Jan 2011
My bad, out of stock ..
Old Aug 08, 2011, 08:28 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
i saw somewhere that HK will have it soon
Old Aug 08, 2011, 12:03 PM
in_out is offline
Find More Posts by in_out
in_out's Avatar
Espainia, PV, Berriz
Joined Jul 2011
Originally Posted by crash_1958 View Post
This morning started off really well the sun was shinning with very little wind so it looked to be a great day to fly. Unfortunately I made a couple of mistakes. First mistake forgot to charge the batteries in my goggles so a minute into the flight the warning light comes on telling me to land. 2nd mistake instead of landing I talk my buddy into taking the controls instead of landing. 3rd mistake not making sure he had control of the plane. Last mistake forgetting we were flying with another plane that looks like mine. My buddy was trying to fly the plane but of course he was looking at the wrong one and mine ended up crashing hard. Not his fault totally mine. Looks like I'll have to buy a new one when they come back in stock.
http://www.vimeo.com/27412451
autx !! i'm sorry ...
great vid anyway!
high video quality and very stable !
how is your setup ?
in_out is offline Find More Posts by in_out
Old Aug 08, 2011, 02:18 PM
CaliDave is offline
Find More Posts by CaliDave
CaliDave's Avatar
Bay Area
Joined Dec 2010
Looks great! I've got a pair of spoons waiting to be placed into my build as well. Love the freebie build parts.
CaliDave is offline Find More Posts by CaliDave
Old Aug 08, 2011, 02:24 PM
beaverlover is offline
Find More Posts by beaverlover
United States, NC, Mooresville
Joined Jun 2008
bevrc is out of skywalkers, who else has them in-stock?!
beaverlover is offline Find More Posts by beaverlover
Old Aug 08, 2011, 02:37 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Just a heads up to all you wing-mount tx guys... placing weight on a long moment arm like that will make roll rate sluggish. Maybe this is good? I guess it would make it more stable, anyway.
erkq is offline Find More Posts by erkq
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
