Old Aug 05, 2011, 10:32 PM
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
There's no airflow, and the prop isn't able to 'unload' it's power as it would be in the air. It puts more stress on the motor and will generally cause it to draw a couple more amps. I feel that it's fine to bench test motors, but not run them for long periods of time. If yours is running long enough to get hot, it's too long IMO. I normally run them long enough to get accurate readings on my watt meter and then shut it off.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Aug 05, 2011, 10:39 PM
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
The motor only ran for a minute or so on the bench and got hot just in that period of time.
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Aug 05, 2011, 10:54 PM
United States, CA, Sebastopol
Joined Dec 2010
A minute can be a long time. Motors heat up fast if they're drawing too many amps.
erkq is online now Find More Posts by erkq
Old Aug 06, 2011, 03:56 AM
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I don't think that is true...
Static on ground full throttle test
In flight full throttle at a few moments
Now explain why the measured loads are greater in air...I do believe in my own logs.
Flying upwards at WOT most likely require more power than static on ground.
I can verify this by opening the logfile and see the load at a specific moment - ie when climbing vertically
UndCon is offline Find More Posts by UndCon
Old Aug 06, 2011, 04:07 AM
Joined May 2009
Could it be greater in air because prop gets lots of air? Static test in ground is different because prop have to suck air?
Props
One guy explained to me that pusher prop is designed differently compared to normal props.
Pusher props have more thrust on end of props than normal props? Is that true? Why is that, because airflow is affected by frame and props don't get clean airflow?
bigbear_fin is offline Find More Posts by bigbear_fin
Old Aug 06, 2011, 04:18 AM
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
Hey there's a SW V4 at my door looking for new friends !! Auuuuuuuuuuuuuu !!!
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Aug 06, 2011, 04:52 AM
Smoke on , go !
Verona - Italy
Joined Jan 2007
I'm probably make mine twin engine with custom motor pods on the leading edge of the wings.., less lipo to balance it, more efficient position of motors.. what do you guys think ? a Twin Sky Walker Star....
Old Aug 06, 2011, 05:55 AM
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
double engine, double trouble...plus wiring complications and lengthy setup on the ground before take off.
I think there is not a lot to improve on the SW. In my book, if it ain't broken, don't fix it.... and that would be in contravention with my KISS rule
that's my personal opinion...
rcmonster99 is offline Find More Posts by rcmonster99
Latest blog entry: Airframes
Old Aug 06, 2011, 05:59 AM
Joined Nov 2008
if the prop is stalled with static test it will draw less?
if the SW has not reached top speed, it is more like a static test?
try wot straight and level.
nyc863 is offline Find More Posts by nyc863
Old Aug 06, 2011, 09:47 AM
Joined Jan 2010
Can a use a 8x6 prop with that motor.
Old Aug 06, 2011, 02:27 PM
Joined Jan 2010
Im going to go to the hobbyshop and pick up a 8x6 and see what happens.
Old Aug 06, 2011, 03:23 PM
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I put my SW in yesterday for it's first major. I run mine with tri- gear and a change of wind direction forced a different approach to usual. My base turn was too near and I ran out of runway so I opened up the throttle to go round and BOOOoooof. Into a 4m high earth mound. It looked lower every other time I flew over it!!
Front gear is mashed. Tail boom ripped at the fuse, pilot is feeling stupid. All fixed overnight except I have realized that the P&T and cam mount are still buried on the mound somewhere.
It seems it will be a while before I am flying with Mooses and carving through the gaps on the trees. J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Aug 06, 2011, 07:27 PM
I do all my own crashes
Wingnut13's Avatar
United States, NH, Rochester
Joined Jan 2011
^^Sorry to hear of your crash, good luck getting it back in the air!
Today was the first time I put my SW V2 up with the RVOSD Gen4 in charge. I've spent the last few days setting up the autopilot. One scary moment when I flipped the RTH switch for the first time and it took a wicked dive.... I took control over and pulled up...hard! Tested the wing strength as well, GTG.
I'm happy, I would have played with the A/P more but in my rush forgot my second battery on the charger. Also looks like it will rain for the next week, glad to get it up!
~Wingnut13
Wingnut13 is offline Find More Posts by Wingnut13
Old Aug 07, 2011, 05:57 AM
Houba ! Houba !!
Joined Sep 2003
~Wingnut13
My second SW is also equipped with the same OSD.... So far I am only using it as a OSD. One day I must summon the courage to enable the RTH...
Old Aug 07, 2011, 08:27 AM
Avenger GBU-1H's Avatar
Acworth, GA
Joined Mar 2007
I remember you had mentioned doing this once before about 2000 replies ago. That would be an awesome build design if you can get the physics just right.
What kind of motors would you use? How would you mount them? I would really like to see the finished product.
Good luck! Keep us updated!
Avenger GBU-1H is offline Find More Posts by Avenger GBU-1H
Question Best plane for FPV while on vacation? patricklupo Video Piloting (FPV/RPV) 23 Aug 08, 2010 06:27 AM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC Video Piloting (FPV/RPV) 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
