Old Jun 16, 2010, 02:52 AM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Nice Kev. I've gone and ordered the damn strips. I have 4 x 350mm rides like that in a box. Damn.
Have you flown yet? Haven't seen much detail on your build. She looks to fly pretty fast! And.. is it me, or does it seem to fly with a bit of a nose-up attitude when flying level flight?
Cralis is offline Find More Posts by Cralis
Old Jun 16, 2010, 02:59 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Yea, i thought the same, looks like the tail bogs down a bit in level flight. Don't worry, cf strips should be just as strong.
No, haven't finished her yet, plus i don't have a LRS yet , EzUHF are on backorder, maybe by the start of July i should have it.
Got the camera position worked out.
Kev.au is offline Find More Posts by Kev.au
Old Jun 16, 2010, 03:01 AM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
That looks NICE! Man, you're gonna have some nice footage...
And you're already onto the stickers?! Excellent...
Old Jun 16, 2010, 03:05 AM
Kev.au is offline
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Yea, HobbyKing chucked them in with my order lol.
If i had the cash, i would put a Gopro on too .
Cheers, kev.
Old Jun 16, 2010, 05:33 AM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
SPL nice to see a successful outcome ! this plane really looks stable. Hopefully I will do my first FPV flight this weekend with it.
Rough landing though ... on the tarmac... ouch did you leave some foam behind ?
rcmonster99 is online now Find More Posts by rcmonster99
Old Jun 16, 2010, 05:50 AM
Fergus is offline
Find More Posts by Fergus
Fergus's Avatar
Ireland
Joined Apr 2005
Originally Posted by Cralis
Thanks ashdec87.
I like the sound of the strips, but ... 0.5mm is VERY thin. Would it be strong enough?
Easily strong enough.
0.5mm might seem thin... but once glued into a slit cut in the foam you will be surprised at how stiff it will make the wing.
I used a strip along the wing on my first model. It snapped when the wing let go in flight. I think tube would be a better option.
Fergus is offline Find More Posts by Fergus
Old Jun 16, 2010, 06:53 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Originally Posted by Cralis View Post
I had my GPS inside the 'ESC' area... the area under the wing joins... and took ages to get a lock... I'm suprised.
Probably because of the carbon fiber tubes.
techspy is offline Find More Posts by techspy
Old Jun 16, 2010, 08:39 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
dont wanna turn this into a CF tube vs strip discussion, but did you have the strip glued vertically in the wing or laid flat on the bottom of it?
ashdec87 is offline Find More Posts by ashdec87
Old Jun 16, 2010, 08:50 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Oh I have a motor question.
I've got a park 480-890, an axi 2814-12 and a park 400-920.
I ran the first two through motor calc. I would like to use a 4S pack to keep the amps down. So the park 480 draw about 18 amps with a 9x6 or 10x5 with roughly 45 oz of thrust. The axi draws about twice that (38amps) while making 70 oz. Obviously the axi will lift a brick, but does this plane need that kind of power??
Old Jun 16, 2010, 08:54 AM
boopidoo is offline
Find More Posts by boopidoo
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
I think Sander did a good job when he embedded the cf-strip pretty close to the original wing spar. The cf-strip is good at handling bending forces in one axis. It doesn't handle twisting well so it should be placed as close to the main spar as possible. As far as I can see Fergus placed the strip close to the leading edge which is further from the main spar and does make wing twisting possible which the strip obviously doesn't handle very well. Because of this the strip also needs to be placed where it's supported from all other directions. When it's placed in the middle of the wing it has better structural support then when placed close to the LE.
boopidoo is offline Find More Posts by boopidoo
Old Jun 16, 2010, 11:06 AM
LFLoTiTo is offline
Find More Posts by LFLoTiTo
Just want to fly...
LFLoTiTo's Avatar
Brazil
Joined Mar 2009
New SkyWalker Build
Hi folks,
Here is my wip skywalker build. Not yet complete, as I am still waiting for my P&T rig and have not yet painted it, but some ideas I would like to share in advance. The key differences from the great ideas I already saw posted here are:
- Screws holding the wings instead of rubber bands;
- Air in-take for the ESC compartment (also enlarged air out-take)
- Side door beveled and with hinges, magnets and puller. (not so new)
- Just Fiber tape instead of carbon re-enforcements on the wings (letīs wait and see)opcorn
- Small motor: just a KDA 20-20L. Cruises at 6A and climbs at 14A (on 3S)
- Dual battery connectors;
- Magnets on canopy (not new either)
- Extended tx antenna (to clear the plane/gear)
- I am still going to add 90 degrees flaps for hand catch.
I flew a few packs with it just to trim, calibrate the co-pilot and Eagle Tree RTH and it is great. Very stable, docile and RTH worked perfectly on default settings. Nothing worth recording, but I am very anxious to put my hi-def rig on it and do some nice footage.
Let me know what you think.
Cheers,
Luiz
LFLoTiTo is offline Find More Posts by LFLoTiTo
Old Jun 16, 2010, 11:41 AM
techspy is offline
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Nice LFLoTiTo. Can you share your ET RTH settings? I have mine installed and had a great maiden and first day flights but haven't configured the RTH yet. Was there anything that was changed from default? What speed did you set for your cruising speed? Did you find that it looses more altitude than it should when turning with the rudder? I am thinking that I will give a descent amount of up elevator when programming the turn parameters.
Old Jun 16, 2010, 11:49 AM
_helitron_ is offline
Find More Posts by _helitron_
Multicopter/FPV/UAV/HAM
_helitron_'s Avatar
Austria, Stmk., Neudau
Joined Jun 2006
LFLoTiTo,
very nice build and some great ideas.
Erwin
_helitron_ is offline Find More Posts by _helitron_
Old Jun 16, 2010, 11:53 AM
LFLoTiTo is offline
Just want to fly...
LFLoTiTo's Avatar
Brazil
Joined Mar 2009
Techspy,
I left all the gains/limits on default values.
I disabled the cruise speed feature (as it should be by default if you donīt use a pitot tube) by inputing a high number (i.e.:150 kmh);
I connected my rudder on the OSDPro instead of ailerons (as it is now recommended);
During the RTH wizzard: (1)I gave full rudder left and about 10% elevator up when it asked to set the sticks to turn left. (2) I gave full elevator up when it asked to set the sticks to climb; (3) I set the throttle stick to the equivalent of 7A to cruise and 14A to climb; I think thats all.
I did not notice any loss of altitude when turning with rudder on default settings. But when I tried to increase the turn gain it banked too much and started to dive, so I went back to default.
Cheers,
fjnetcom is offline
Find More Posts by fjnetcom
France
Joined Sep 2009
yes nice build LFLoTiTo,soon the video
I am finally deciding to buy this plane in next order at bevrc
fjnetcom is offline Find More Posts by fjnetcom
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
