Old Jul 29, 2011, 04:23 PM
Seafax ROV
WalneyCol's Avatar
United Kingdom, Barrow-in-Furness
Joined Feb 2011
It won't be as nimble as your easy star (i.e you might need to plan ahead more than you're used to), but as the bus that it is it flies fine on just the rudder and it's considerably better at handling gusts.
Just my opinion.
Colin
Originally Posted by Rick662u View Post
Hi. Can this plane be successfully flown with just an rudder/elevator? I'm interested in this comparison to stock ezy* which is stable as a simple r/ e flyer. I desire this for simplicity/ safety reasons.
One more question. How does it handle wind? Thanks Regards. Rick
WalneyCol is offline Find More Posts by WalneyCol
Out of sight, not out of mind
octane81's Avatar
Antarctica
Joined Oct 2010
Nice weather for a flight today , everything went well , except for the bad video about 9km out , it even stayed bad for quite a while when returning to home.
Dont know why it did that , but anyway plane got back on the ground safe... landing with goggles
Skywalker 9.8km FPV flight #004 (26 min 33 sec)
octane81 is offline Find More Posts by octane81
Old Jul 29, 2011, 08:53 PM
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
Hey so I madien my sky walker today and had a great time with hardly any problems. The only problem I really had was the motor got pretty hot. Here is the setup I am using.
9x6 electric prop non pusher
Here is the motor
http://www.bevrc.com/ax2814-special-...ker-p-207.html
ESC
http://www.bevrc.com/ax-45a-brushless-esc-p-208.html
Battery is a 4 cell 4000mah 30c lipo
Im not really sure why the motor was so hot. Is that prop to much for the motor. Do I need to go to a smaller one? Also the esc was not hot at all very cool.
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Jul 29, 2011, 08:55 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Daemon View Post
I put "pusher" in quotes to emphasize the pushing requirement. Your explanation
for the existence of counter-rotating electric props are still for tractor application.
There is no need for a true pusher electric prop.
ian
Sure there is. Tri-copters, quad-copters, Y-6 copters, etc.
Vantasstic is online now Find More Posts by Vantasstic
Old Jul 29, 2011, 10:05 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
quad/hex/octo-copters are still not "pushing". They need counter-rotating props, yes,
but not in a "pusher" configuration. They're still all a tractor application, with
the exception of the Y-6.
ian
Daemon is online now Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Old Jul 29, 2011, 10:21 PM
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Bra gjort
http://www.youtube.com/watch?v=xQAIAYRrSAA
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jul 29, 2011, 10:56 PM
Joined Jan 2010
Any body know whats wrong with the motor? My post is up above
Old Jul 29, 2011, 11:22 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Did it shut down, or start smoking? Motors get hot. That setup is
spec'ed for the Skywalker from bevrc and many people use it just fine.
ian
Old Jul 29, 2011, 11:29 PM
Joined Jan 2010
ian
No it did not start smoking or shut down. Just got worried because none of my motors have ever gotten this hot. I had been flying for around 5 min or so. You would think there would be proper cooling. haha
Old Jul 30, 2011, 02:30 AM
Hong Kong
Joined Sep 2004
Never did like the way the Skywalker sits on top of the landing gear, so taking a little inspiration from F3a, I mounted my gears like this! It makes the planes "sit" a lot better.....
It's pretty tough, there's no way the gears are coming off without removing a large chunk of fuselage with it!
dtm360 is offline Find More Posts by dtm360
Old Jul 30, 2011, 03:14 AM
Aviation industry participant
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
I'd been thinking about making mine a tail dragger, but worry that it might nose over due to the high mounted pusher. How do you find yours handles when you open the throttle on the ground?
subsonic is offline Find More Posts by subsonic
Old Jul 30, 2011, 04:03 AM
Joined Nov 2008
getting towards the end of my build now
what kind of aileron throw is necessary?
the manual says 15 degrees "no more" but that isn't a lot. what kind of gap should I be after?
thanks
nyc863 is offline Find More Posts by nyc863
Old Jul 30, 2011, 11:21 AM
rsowder's Avatar
San Francisco
Joined May 2009
thanks
I use max ailerons. And at low speeds during landing I also coordinate the rudder with the ailerons.
rsowder is offline Find More Posts by rsowder
Old Jul 30, 2011, 03:25 PM
KK4OCZ
webdr's Avatar
United States, GA, Sandy Springs
Joined Jul 2009
Closing in on a maiden
My SW is almost ready for its first flight.
Lawmate 1.2 1w
RVOSD5
Sony KPC 650-CHQ flight camera
GoPro mounted in the nose
Rimfire 35-36 1200
Electrifly SS 45a
3S 5000mAh
Dragonlink
All up weight is 4lbs
I think I could shave a few ounces by using a lighter flight camera like a DX201, since I really want to record with the GoPro; I'll see how she flies at 4lbs and make that decision then. But on the other hand, the quality of the 650-CHQ is superb for a standard-def CCD cam.
I added carbon spars on the top and bottom of the main wing, top of the horizontal stab, and both sides of the vertical stab, and put a few strips of fiberglass packing tape on as well. Im amazed at how much more rigid the entire plane is...this is a mod that's well worth it.
webdr is offline Find More Posts by webdr
Latest blog entry: Aerial Mapping UAV
Old Jul 30, 2011, 08:08 PM
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
the indirect light inside the lens reflected by the white nose under the gopro will decrease the overall contrast and reduce image quality, make that part black. (that's why we use shaders in photography)
zaguruinzasky is offline Find More Posts by zaguruinzasky
Question Best plane for FPV while on vacation? patricklupo Video Piloting (FPV/RPV) 23 Aug 08, 2010 06:27 AM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC Video Piloting (FPV/RPV) 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
