Old Jul 28, 2011, 05:16 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
"pusher" version props only exist for gas planes because they can only turn the motor
one direction. For electrics you just use the regular prop (still with
convex side forward) and spin the motor the opposite direction.
ian
Daemon is offline Find More Posts by Daemon
Old Jul 28, 2011, 05:43 PM
rcplanes1234 is offline
Find More Posts by rcplanes1234
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
ian
Ok and what about the tail being shacky. It was my post before the one about the prop. Thanks!
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Jul 28, 2011, 05:59 PM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
That's normal. Mine shakes and has not been a problem. Some reinforce it, but I don't think it's necessary.
rsowder is offline Find More Posts by rsowder
Old Jul 28, 2011, 06:54 PM
Joined Jan 2010
some people but way to much on. I think if you get those cr in nice and glued the wing snapping will no be a problem especially with the new version.
Old Jul 28, 2011, 07:05 PM
rsowder is offline
rsowder's Avatar
San Francisco
Joined May 2009
I have made no structural modifications to mine and have had no accidents in over 60 flight hours.
Old Jul 28, 2011, 09:22 PM
bah7566 is offline
Find More Posts by bah7566
FPV maniac
bah7566's Avatar
Colorado
Joined Sep 2007
ian
Ian,
Your statement is not totally correct, pusher props do exist for electric motors although they are not really necessary because you can run the motor in either direction.
http://www.toddsmodels.com/APC_Pusher_s/43.htm
An electric pusher is usually used in a twin configuration so you can have counter rotating motors to help with yaw and critical motor issues in the event you have one motor fail during flight. On a single motor application, you have no critical motor so it's just a matter of what torque direction you care to deal with. Either a normal prop or an electric pusher would give equal performance.
Bruce
bah7566 is offline Find More Posts by bah7566
Old Jul 28, 2011, 09:44 PM
Joined Jan 2010
Originally Posted by bah7566 View Post
Ian,
Bruce
Ok thank you!
Old Jul 28, 2011, 10:37 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I put "pusher" in quotes to emphasize the pushing requirement. Your explanation
for the existence of counter-rotating electric props are still for tractor application.
There is no need for a true pusher electric prop.
ian
Old Jul 28, 2011, 11:38 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Vertical wings
Vertical lift with multiple props may require a counter rotation.
A angle of around 3 Deg offset depending if it is CW or CCW helps to mechanicaly balance the twisting air direction. Prop torque is a interesting discussion. It reverses with propeller direction.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jul 29, 2011, 02:03 AM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Hi. Can this plane be successfully flown with just an rudder/elevator? I'm interested in this comparison to stock ezy* which is stable as a simple r/ e flyer. I desire this for simplicity/ safety reasons.
One more question. How does it handle wind? Thanks Regards. Rick
uptime4downtime is offline Find More Posts by uptime4downtime
Old Jul 29, 2011, 02:54 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It might fly with R/E only but it would handle like a pig. Eliminating ailerons
doesn't make an aircraft safer, especially in wind.
ian
Old Jul 29, 2011, 03:24 AM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
In many of my videos I fly with the end result in mind - it means I try to keep the plane and camera as flat as possible.
That is turning with rudder but counteracting with ailerons.
At 1 time I forgot to connect the ailerons and I had a hard time bringing the plane back safe on ground - I would not fly without it.
UndCon is offline Find More Posts by UndCon
Old Jul 29, 2011, 06:14 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Usually but not always, ailerons will bank the plane before turning. With rudder, the model will turn before banking.
On full scale, often the rudder is used to stop the plane dropping the nose and sliding out of the sky like a frisbee on a sharply banked turn. The point being, it's best to have both options.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jul 29, 2011, 09:52 AM
Joined Jan 2010
Where should i measure the cg? The manual says 75mm back from the leading edge but I don't always trust that. I measured at 75mm and I was tail heavy. Thanks
Old Jul 29, 2011, 10:55 AM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
25-30mm behind the servo wires. Haven't you at least skimmed this thread?
pdiddyg40 is offline Find More Posts by pdiddyg40
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
