Old Jul 19, 2011, 11:21 AM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Originally Posted by rcplanes1234 View Post
will a 40amp esc be plenty with a 9x6? on 4s
Because the kV is quite low, a 40A ESC should be good.
Since you are already ordering from HK you may consider getting a TGY 60A Plush ESC, if it is in stock, and not worry if you have enough or not.
http://www.hobbyking.com/hobbyking/s...ontroller.html
These have proven to very reliable.
henkvdw is offline Find More Posts by henkvdw
Old Jul 19, 2011, 11:26 AM
rcplanes1234 is offline
Find More Posts by rcplanes1234
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
im thinking a 800mah will be plenty
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Jul 19, 2011, 11:31 AM
henkvdw is offline
KJ6BFN
henkvdw's Avatar
Joined Aug 2008
Ok and then what size vid pack for this plane to make it balance right?
The plane should balance with or without a pack for the AV equipment.
If you follow Daemon's guidelines for setting your CG there will be no problem with being tail-heavy.
What are the voltage requirements for your Video equipment?
Have you considered the TBS guidelines for setting up you video equipment?
If your AV equipment can handle a wide range of input voltage, then go ahead and connect directly to a suitable cell count LiPo.
The recommendation is however to run the supply through a Filtered Voltage Regulator in order to supply voltage to the AV equipment in it's workable input range.
Old Jul 19, 2011, 11:45 AM
Joined Jan 2010
Here is what video equipment I will be using.
Camera can be 7-12v
http://www.bevrc.com/bevkx121ntsc-p-254.html
Video tx 7-12v as well
http://www.bevrc.com/bev-24g-500mw-p...-fpv-p-46.html
osd this what I will plug the 3cell into. Requires a 3 cell.
http://www.bevrc.com/ce-osd-v15newest-p-113.html
Old Jul 19, 2011, 12:04 PM
henkvdw is offline
KJ6BFN
henkvdw's Avatar
Joined Aug 2008
Camera can be 7-12v
Seems as this equipment will allow you to connect directly to a 3S LiPo then which is simple.
Make sure you have some way of monitoring the AV pack voltage to not drop below the 3S LiPo's minimum around 10V. The OSD can probably do this for you.
Alternatively you can omit the AV LiPo pack and run a Voltage Regulator directly off the 4S flight pack LiPo.
Old Jul 19, 2011, 12:28 PM
Joined Jan 2010
Im just got to plug it into the osd. Should 800mah be enought for an hour or so, or should i get higher.
Old Jul 19, 2011, 01:04 PM
venquessa is offline
Find More Posts by venquessa
UK, North Down, Bangor
Joined Nov 2009
Originally Posted by Fpvicv View Post
Most people on here use a 9x6 E-prop, but it all depends on your power setup and battery selection. I use a 9x4.5 as I have a higher KV motor (1220KV) and a 4S battery. What motor and battery are you planning to use?
Yea. 9x6 at around 1400Kv 3S seems very common.
Mine produces 1400g static thrust and is way over powered in the air. 30/40* climb, 60 mph level flat out.
If you want more performance you probably shouldn't be using a SkyWalker.
venquessa is offline Find More Posts by venquessa
Old Jul 19, 2011, 01:07 PM
Joined Nov 2009
Is this 800mAh for the Vtx, camera, OSD only?
I used a 500mAh 3S for Vtx+Cam on a few flights. With a 5000mAh flight pack. I swapped both batteries at the same time. On charge the 500 and the 5000 where about the same % drained.
In short... getting an hour out of an 800mAh I would say is "risky".
I now use a 1300mAh 3S for Vtx, Cam and Rx/Servos and I will just about get 2 5000mAh motor packs or about an hour flight time from it.
Old Jul 19, 2011, 01:14 PM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
hi
can you reference that guideline please? Im unable to find it.
Matt
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Jul 19, 2011, 01:23 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Originally Posted by AdamChicago View Post
Thanks...I was about to consider getting that one but then found "Servo Stretcher" from ServoCity that is basically just a servo cable for $20 that increases the servo pulse signal so you can get 180degrees out of a normal 90degree analog servo...woohoo!
Some people don't like those becasue they tend to degrade the resolution of the servo movement, i.e. making it jerky and not smooth. Although, on some servos it works fine.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Jul 19, 2011, 01:28 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
I could have predicted that because I didn't check with the forum before purchasing...it seems every time I find something cool to purchase I later find out there's something wrong with it...ugh
AdamChicago is offline Find More Posts by AdamChicago
Old Jul 19, 2011, 01:33 PM
pdiddyg40's Avatar
Joined Jul 2008
Hey, get that frowny face outta that post! It may work fine for you! At least now you'll have it to try and you could try a couple of different servos to see what works best. All hope is not lost
Old Jul 19, 2011, 01:44 PM
Joined Jan 2010
Ok so im going to get the 960kv motor on bevrc's website and 40amp esc with a 9x6e prop. I will be using a 4 cell lipo from hobbyking 20c. For video osd, and video tx I will use a 1300mah. does this sound good? Thanks
Old Jul 19, 2011, 01:50 PM
henkvdw is offline
KJ6BFN
henkvdw's Avatar
Joined Aug 2008
All the components should specify their current consumption. The OSD, Camera, AVTx and whatever else you hook up to this pack.
Add it together and compare with the Pack Capacity. Then you will know what to expect.
I would guess that 800 mAh is on the low side as suggested above.
Probably should work in a safety factor of 2.
Old Jul 19, 2011, 01:56 PM
henkvdw is offline
KJ6BFN
henkvdw's Avatar
Joined Aug 2008
Sounds good.
Personally I would run a bigger ESC although the 40A unit may suffice.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
