http://www.bevrc.com/ax2814-special-...ker-p-207.html Going to use this esc http://www.bevrc.com/ax-45a-brushless-esc-p-208.html |
The motor will never be stressed on 3S and a 9" or 10" prop, which is a good thing, but thrust will be wanting. At a minimum, the kV should be in the 1250 RPM/V range on 3S. Many run 1450 and even 1500 RPM/V motors on 3S. On 4S and a 9" prop one could drop the kV to around 1000 RPM/V. There are 2814/3536 ish motors in the 1200 RPM/V range that you could run on 4S although most would be overheating outside of the 1000 - 1100 RPM/V on 4S. The Scorpion SII 3014 1220 is one of those that will run safely on 4S with a 9x4.5" prop and deliver 2115 grams of thrust or you can run it on 3S with a 10x7" prop and get 1748 grams of thrust. Depending on the weight of your SW you might get 1:1 thrust to weight ratio on the 4S set-up if you are so inclined. The 1748 grams of thrust would also be more than ample on 3S. |
United Kingdom, England, High Wycombe
Joined Feb 2011
Im not inteding to fly a 123012034123 miles with it. Prob 3 miles out and back will be the max.
Here is the battery I was looking at http://www.hobbyking.com/hobbyking/s...dProduct=15014 |
You could also use a lower C rating. http://www.hobbyking.com/hobbyking/s...arehouse_.html or http://www.hobbyking.com/hobbyking/s...arehouse_.html |
| Thread Tools | |
| Question Best plane for FPV while on vacation? | patricklupo | Video Piloting (FPV/RPV) | 23 | Aug 08, 2010 06:27 AM |
| Cool FPV plane rescue with an FPV truck :-) | AnthonyRC | Video Piloting (FPV/RPV) | 17 | Feb 24, 2008 10:45 PM |
| For Sale Skywalker plane and a bunch of extras | moody07747 | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 19, 2006 09:34 PM |
| Discussion Aviator Skywalker RC plane given to me | moody07747 | Electric Plane Talk | 46 | Sep 12, 2006 11:45 AM |
