South Australia
Joined Mar 2003
What motor did you end up with? Most on this thread had aspirations of putting in motors that were way too big and heavy. What servos? again there was talk of HS81/82s. Too big and heavy. The plane, as I stated just a page or two back, cruises at about 50 kph. This is about min to keep altitude. I do agree the plane could do with a longer nose to help balance though. The other thing I noticed is that the plane is not that sensitive to CoG. So a little tail heavy doesn't present a real problem. Oh and what about twin motor setup is more efficient!!?? Quite the opposite I think you will find. |
I had the same issue when I ordered the FY-21AP II and a video switch from him and he resolved it to my satisfaction. Recommended therefore. Miha |
![]() Quote:
cleaner airflow for props, easier cg centering with LOT less weight, less noise for sure (not pusher props near trailing edges), the weight will be less, slower. the pull will be more with same motor set weight, the tail won't have strong prop wing coming from the motor.. shaking it. for sure less glide in idle but better cruise, the roll momentum will be slower because we move the weight to the outside so it should be a little less sensitive to turbulence as it was my twinstarII. ESC will be away from electronics and with fresh airflow.. With contraprop there is no torque induced roll or other attitude variation that are reflected on the video. lighter = can be hand launched with less RPM = safer/easier for the pilot. overall I think it will be better but it's nice to experiment, the Twinstar has been a very successful airplane and these the CONS: Less glide ratio when idle (but good brake if you need to brake otherwise just keep 1% rpm..) |
South Australia
Joined Mar 2003
I think you will find the reynolds numbers are better for a larger propeller. So running two smaller propellers fast will not be an efficient way to go.
Think of a mesi copter/quad copter, and compare that to a normal two rotor blade helicopter. Flight times are always a problem with the multi blade multi motor machines. This is probably all moot anyhow, if you are not looking for long flight times. Back to the skywalker. What if you extended a dowl out the front with a small weight on it. So as to move the CoG right forward. This might allow you to run smaller lighter packs. Not the most elegant solution, but it would work quite well I think! |
for the price of props, experiments are the best solution, I will try.. I'm considering two of these: http://www.hobbycity.com/hobbycity/s...idproduct=6614 with APC 8"x3.8"SF and SFP (counter rotating) on a single 3s 2200
For me the only important thing is video stability, I don't have to do long range, I have to do nice videos and that only needs very low speeds and roll authority with good gyro. |
http://www.rcgroups.com/forums/showthread.php?t=827488 It will fly very slow, but requires little to no wind. Morris |
Yes, the "little to no wind" is a KO criterium for me. I have a Hawkeye for such conditions. But most of the time it is windy down here. And jobs can't be postponed until we finally get a calm day. Even 50km/h (and the Skywalker can easily cruise at less) is no problem if you image from 100-200m altitude and the shutter speed is 1/250s or faster. Just do the math...
| Thread Tools | |
| Question Best plane for FPV while on vacation? | patricklupo | Video Piloting (FPV/RPV) | 23 | Aug 08, 2010 06:27 AM |
| Cool FPV plane rescue with an FPV truck :-) | AnthonyRC | Video Piloting (FPV/RPV) | 17 | Feb 24, 2008 10:45 PM |
| For Sale Skywalker plane and a bunch of extras | moody07747 | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 19, 2006 09:34 PM |
| Discussion Aviator Skywalker RC plane given to me | moody07747 | Electric Plane Talk | 46 | Sep 12, 2006 11:45 AM |
