Old Jul 18, 2011, 10:37 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Can someone recommend a good solid panning FPV cam servo? Preferably Hitec, but I'm not wetted to the brand, metal gear and as close to 180 degree panning or better if possible.
Thanks much!
AdamChicago is offline Find More Posts by AdamChicago
Old Jul 18, 2011, 10:44 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Thanks much!
What's wrong with the GWS sail-winch servo? It's really heavy for a servo, but I've never heard any complaints about it failing to do what it needs to do.
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Jul 18, 2011, 10:55 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
I also use the GWS sail-winch servo on my Skywalker, recently hit a tree doing 88km/h and still works like a new.
On which plane you want to have pan?
saucisse is offline Find More Posts by saucisse
Old Jul 18, 2011, 11:06 PM
rcplanes1234 is offline
Find More Posts by rcplanes1234
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
Hello all. I am upgrading my fpv to be put all into a skywalker that I am getting from bevrc.com. I am getting the version they have on there now and this is the gear I will be using. Please fell free to comment if its not ideal. Thanks!
40 amp esc with internal bec
http://www.bevrc.com/ax-45a-brushless-esc-p-208.html
Motor
http://www.bevrc.com/ax2814-special-...ker-p-207.html
Servos
http://www.bevrc.com/beves08ma-p-203.html
Battery
http://www.hobbyking.com/hobbyking/s...dProduct=15003
http://www.hobbyking.com/hobbyking/s...dProduct=14958
I dont know what one I should get yet.
All of the equimpment for the plane is suggested by bevrc and sold by them except the battery. Also, what prop should I use. Will I need a prop adapter? Thanks! Cant wait to get this thing and fly!!!!
rcplanes1234 is online now Send a private message to rcplanes1234 Find More Posts by rcplanes1234 Edit/Delete Message
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Jul 18, 2011, 11:09 PM
pdiddyg40's Avatar
Joined Jul 2008
I heard you the first time That all looks pretty good, and I've seen many people being successful with the combo you suggested. Some people prefer to use higher kv motors (in the 1200 range) if running a 3 cells, but like I said, people have been successful with the 900-ish flavor. You will probably want to go with the heavier battery upfront in order to get it to balance out; or you could wire up 2 of the smaller ones in parallel.
Old Jul 18, 2011, 11:30 PM
Joined Jan 2010
Is the 4500 enough or do I need more?
Old Jul 18, 2011, 11:36 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
My Skywalker balances with a single 4000mAh 3S battery, and it's about 50mm
back from the nose.
ian
Daemon is offline Find More Posts by Daemon
Old Jul 18, 2011, 11:39 PM
Joined Jan 2010
back from the nose.
ian
So a 4500 should be just right then if placed in the front of the nose. Will a 4500 and a 1000 stacked on top of each other fight up front?
Old Jul 18, 2011, 11:56 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
back from the nose.
ian
Mine is about the same but I use 5000 mah 4s, I also have steering nose geat but no GoPro camera gear. The mains are just behind the Cg which is 25mm behind the servo wires. J
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jul 19, 2011, 12:01 AM
Joined Jan 2010
ok im going to get 4500 and a 1000 for video also what camera is the best for the price? Any one try the new kx-12
Old Jul 19, 2011, 12:19 AM
Joined Jan 2010
almost forgot what prop should i use
Old Jul 19, 2011, 08:25 AM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
Ordered my SW V4 yesterday...shipped out today
setup will be:
Lawmate 1.2 1w w/ LP filter
Lawmate 1.2 receivers on EE diversity
DragonLink
GoPro HD
RVOSD5
9.5db helical and cloverleaf antennas on rx
cloverleaf on vtx
45amp Great Planes SS esc
35-36 1200 Rimfire
3S 5000 flight pack
3S 910 video pack
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Jul 19, 2011, 08:58 AM
Fpvicv is offline
Find More Posts by Fpvicv
$$$'s vs Skill
United Kingdom, England, High Wycombe
Joined Feb 2011
setup will be:
DragonLink
GoPro HD
RVOSD5
cloverleaf on vtx
35-36 1200 Rimfire
3S 5000 flight pack
3S 910 video pack
I still need to try mine on a 3S, I see a lot of people opting for a 3S over a 4S. On 4S this thing is ballistic, cruising on quarter throttle and I can never go above 75% throttle... too much power but I get unlimited vertical.
Fpvicv is offline Find More Posts by Fpvicv
Old Jul 19, 2011, 09:21 AM
Joined Jan 2010
what prop?
Old Jul 19, 2011, 09:26 AM
Fpvicv is offline
$$$'s vs Skill
Joined Feb 2011
Originally Posted by rcplanes1234 View Post
what prop?
Most people on here use a 9x6 E-prop, but it all depends on your power setup and battery selection. I use a 9x4.5 as I have a higher KV motor (1220KV) and a 4S battery. What motor and battery are you planning to use?
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
