Old Jun 12, 2010, 05:26 PM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Thanks. Yeah I added 2 strips of CF strips to each wing. They overlap approx 4" past the stock CF tubes. It is very stiff and strong. I also added fiber tape along the bottom of the wing and fuselage and on the vertical stab. I also added some monokote trim to the center of the wing. This was mainly to keep the rubber band from digging into the foam, but it made it a little stronger too. This airframe is very sturdy now.
I was surprised at the power it had too.
techspy is offline Find More Posts by techspy
Old Jun 12, 2010, 06:20 PM
First to go over 106K feet
Crist Rigotti's Avatar
USA, IA, North Liberty
Joined Mar 2008
Originally Posted by iw28 View Post
smashed like a pancake almost every part was damaged except the tail wing.
got it from fpvflying.com
Ohhh, sorry to hear about that! I'm sure FPVFlying will do what's right.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jun 12, 2010, 06:25 PM
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
So far he has shined on other problems. One of the good guys.
aviatordave is offline Find More Posts by aviatordave
Old Jun 12, 2010, 11:12 PM
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
My initial layout
Here is what I think my layout of components will be like on my Skywalker. I am still waiting for my Turnigy Motor (drawn onto the image), and my CoPilot II (also drawn in). The camera is a $49 480Line Ebay Sony camera (Also drawn in).
Here's the components:
1. 10Hz Flytron GPS Rx
2. FMA Co Pilot II
3. 40A Turnigy Plush ESC
4. Turnigy Motor
5. Dragon OSD+
6. Power Sensor
(Forgot to show, to the right of the power sensor is a DPCAV power filter. 13 shows the power pluf that will power the video harness)
7. 2 x 3S 3000mah packs (for now)
8. GWS 360 degree Pan Servo
9. $49 Sony Camera
10. 900Mhz 500mW AV Tx
11. Barometric Sensor/Temperature sensor
12. Thomas LRS LR Rx
13. Power plug for Video harness (Video harness still being built)
14. Cables to rudder and elevator
My ideas around this layout are:
GPS very far from noisey 900Mhz video Tx.
Radio Rx pretty far from all noisey items.
Power Sensor and Power filter (maybe both dirty?) moved forward to help CoG.
Video Harness will be pretty short and contained to forward section, except for the 4 wires that go to the OSD.
Radio Rx is mounted on a removable panel. When it opens, the radio Rx will come out on the panel. I should then also have easy access to the OSD board.
Antenna on Rx is a whip. That may be upgraded to a heavier antenna.
Missing from this diagram is the LRS antennas.
One might be mounted on top, with a stick being dug into the fat bit of foam holding the motor on. The stick will be pretty high. It will be vertical for long range flight.
The other antenna (For altitude above me) would be stuck to the side of the fusalage, from the nose, running done to the start of that CF rod.
You experts, can you maybe see any issues I may have or have any better ideas?
Here's a wee video of access options.
My Skywalker Layout test video (2 min 28 sec)
Also, CF rods and wings...
I have 2 of these 400mm rods...
Would it be of any use in adding these? Or must I get 750mm?
Cralis is offline Find More Posts by Cralis
Old Jun 13, 2010, 12:45 AM
Italia, Piemonte, Torino
Joined Jul 2009
Cralis i suggest one think, about your TXv, put a 3 Dbi Rubber Duck, don't use 1/2 Wave antenna, for me the 3Dbi is much better.
I flew for 8km without problem with the 3 Dbi rubber with 500mW!!
Neo360 is offline Find More Posts by Neo360
Old Jun 13, 2010, 12:48 AM
I love FPV!
Cralis's Avatar
Joined Jan 2007
Thanks Neo!
Something like this?
Found one in my GS box!
So, with that added to the equation - component layout OK?
Old Jun 13, 2010, 01:08 AM
Hooks's Avatar
Joined Jun 2009
@iw28 as mentioned mail 5 days ago I will ship you a new one you just have to send me the damaged one.
Hooks is offline Find More Posts by Hooks
Old Jun 13, 2010, 05:56 AM
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
yeah I hope so!!
iw28 is offline Find More Posts by iw28
Old Jun 13, 2010, 06:10 AM
iw28's Avatar
Joined Nov 2009
Hooks,
I have send you message about the damaged skywalker, the first thing that you told me that it was okay to keep the damaged skywalker as spare parts. Then the next message was that I should send you the damaged skywalker and I should recieve an opened parcel, which I wasnt glad for. Hooks I asked you if you could send me some pictures, but you refused and told me that this was the last message I should recieve from you. Iam am not glad for this kind of service, and I told you before that I will return the parcel because Iam not satisfied with this service and payment. And again you came with a lame apology that I cant return the parcel and recieve my payment.
Old Jun 13, 2010, 09:35 AM
Oleg
Syberian's Avatar
Omsk,RU
Joined Dec 2008
Tired of makin` and crashin` ugly DIY planes. Ordered Skywalker off B.E.V. I hope it arrives not as kinda foam powder ;(
Syberian is offline Find More Posts by Syberian
Old Jun 13, 2010, 07:10 PM
Paris
Joined May 2010
transportability 2
Hi,
Ok I have made progress, all control surfaces are done, fuselage is glued (with dummy cables in some places for the future) and I am now struggling on my motor mount and the wing mouting
I am toying with an idea and wanted to test it here.
- cutting the carbon rods for the wings in two
- glue each of the half rods in the wings at their place the the over on
- use two plain smaller rods of 1meter (or less) each that I would slide inside the glued rods.
This would allow me to keep the wings separated and not loose any stiffness.What do you think?
I still need to find something to lock the two wings together, maybe some FG tapes first
@rcmonster99: the kettle technique for my compressed foam was not that successful so I stopped before the foam get cooked
badzz is offline Find More Posts by badzz
Old Jun 13, 2010, 07:53 PM
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
I flew this model this week but for me is a no go...
main reason is too fast, too much weight on nose to get it balanced, tail is very shaky. I needed 2x 3s 2200 lipo + a gopro on nose to have it balanced. way too much, we should be able to balance it with a single 3s 2200. there is enough room in the middel fuselage to add all the equip.
On a future newer version I would like to see a longer nose for easier cg balance with less weight use, a stronger tail , a thicker canopy, precutted flaps with servo holes ready, longer cf tubes inside the wing and absolutely better shipping box and packaging, looks like almost all of us received it damaged somewhere...
it's a nice plane but still some upgrades to do imho.
Maybe I will try twin engine on wings instead, more efficiency, less noise, less vibrations and no torque with counterprops..
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Jun 13, 2010, 08:44 PM
I love FPV!
Cralis's Avatar
Joined Jan 2007
Same as this one, zaguruinzasky?
skywalker FPV & virtual cockpit (4 min 0 sec)
Looks like it cruises around 50km/h. Match yours?
Old Jun 13, 2010, 08:52 PM
ashdec87's Avatar
Chicago suburbanite
Joined Feb 2004
well I think I'm gonna take the plunge and get one of these from FPV flying.com Picking up the FY 20 as well.
Gonna get the DL and ET OSD PRO. That should make for a nice setup.
EDIT: Actually I will not be ordering from fpvflying.com. $100 for shipping is ridiculous, especially since they are charging $40 for the plane and an additional $40 for the FY 20.
ashdec87 is offline Find More Posts by ashdec87
Old Jun 13, 2010, 08:56 PM
Smoke on , go !
Verona - Italy
Joined Jan 2007
Same in what ? speed?
well I didn't measured but it's fast, I cannot use it for work because of fast landing speed too.. I will just use it for fun and keep flying the Solution when I need heavy lifters
btw I love that cockpit in the video..!
Question Best plane for FPV while on vacation? patricklupo Video Piloting (FPV/RPV) 23 Aug 08, 2010 06:27 AM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC Video Piloting (FPV/RPV) 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
