Old Jun 12, 2010, 09:29 AM
Kev.au is offline
Find More Posts by Kev.au
Post # 20 million
Kev.au's Avatar
Joined Aug 2009
Originally Posted by Cralis View Post
OK, I'll try!
How are you guys fixing things like your OSD, or your radio Rx into the plane? Velcro? Hot glue?
Next time you place an order with HobbyKing, get this stuff.
http://www.hobbycity.com/hobbycity/s...G___%281mtr%29
Cheers, kev.
Kev.au is offline Find More Posts by Kev.au
Old Jun 12, 2010, 01:18 PM
iw28 is offline
Find More Posts by iw28
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
skywalker
wow thats a big plane !!!!
iw28 is offline Find More Posts by iw28
Old Jun 12, 2010, 01:20 PM
iw28 is offline
iw28's Avatar
Joined Nov 2009
received my FPV skywalker today AND GUESS WHAT !!!!
Old Jun 12, 2010, 01:23 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Cheers, kev.
Yeah, got loads of that stuff.
Is that the way to go for keeping tuff inside the plane? Easy enough!
As for software updates, I am building a plug hole on the side of the aircraft, so that I can just - plug in.
Cralis is offline Find More Posts by Cralis
Old Jun 12, 2010, 01:51 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Originally Posted by iw28 View Post
What's wrong?
Where did you get it from?
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jun 12, 2010, 02:05 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Ok.. hinging all complete... Now, I want to seal my servos into place. My choices at the moment for servos are:
HS-65s on Ailerons, Y-Cable so that my OSD can control them if need be, as well as my stabilisation system (FMA CoPilot).
HTX900 for rudder. I know this isn't the top of the range servo, but the rudder will probably be the least used control surface, and if the servo did die... I don't think is will spell the end for my plane.
HS-81 for elevator. This is a bit heavy, and it doesn't fir tight (It will sit out a bit, as it's too deep for the tail) but I have 2 spare, along with a few unused spare HTX900s and 2 HS-55s. I looked at the HS-55, and thought they might look a bit fragile. If I have stabisation working, I think the elevator will be pretty busy, along with the ailerons. So, my thinking is that the servo will be working quite hard, and maybe an HTX900 or HS55 wouldn't be the best choice. Is this valid?
Old Jun 12, 2010, 03:18 PM
hendrix is offline
Find More Posts by hendrix
Greece, Attica, Piraeus
Joined Jun 2004
Guys what is the maximum weight that this plane can lift?
I am thinking of installing a 20Ah pack on it (about 1.5 kgm)
It looks like it could become the perfect uav platform.
Chris
hendrix is offline Find More Posts by hendrix
Old Jun 12, 2010, 03:34 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Elevator is pretty important.... IMHO....
I know you don't want to... but I would get another HS-65mg for the elevator....
I don't think the HS-55 or the HXT900 will be enough for elevator....
might be strong enough torque wise, but kinda fragile...
The HS-81 is ok, but as you pointed out, it's a bit too big for the tail pocket.
Do what will make you happy in the long run.... so that later you don't regret....
galaxiex is offline Find More Posts by galaxiex
Old Jun 12, 2010, 04:50 PM
techspy is online now
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Maidened today!
Got mine maidened today. Here are some specs.
Weight 1.9kg
6 minute flight used 1000 mah. (with a good amount of throttle used)
3s 5700mah total (will soon have one 3s 5000mah that I will use)
Max speed = approx 57mph
Max amps = 30
Max watts = 360
The maiden was with no video transmitting. The 2nd flight was with the video transmitting and recording but not flying FPV. I accidentally turned off the osd while flying so I wasn't able to see all the data during playback of the video, but I did get the data recorded in the Eagle Tree Logger. I could tell however that I had way too much vibration in the video. I am going to balance the prop and mount the pan servo in MoonGel and try it again. If that is successful, I will FPV with it.
I also tested the aileron gyro and AP2000i and they worked fine. One thing I did notice however was that it need considerable up elevator and aileron correction when turning with the rudder. Otherwise it will lose a good bit of altitude. I may try setting up a mix for this but it will be a little lighter and move the cg back a bit with the new battery. Here is a video showing the launch, top speed flyby and mid speed flyby slowing at the end and the landing.
I was a bit worried about going with the lighter motor, but it turns out to be perfect!
Skywalker Maiden (0 min 52 sec)
techspy is online now Find More Posts by techspy
Old Jun 12, 2010, 05:18 PM
galaxiex is offline
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Looks pretty good techspy.
What motor did you go with?
Old Jun 12, 2010, 05:19 PM
~>Miha<~ is offline
Find More Posts by ~>Miha<~
~>Miha<~'s Avatar
Joined Dec 2009
These numbers look great, techspy!
Was this with the motor described in post #709?
I am asking because you said the motor is 230W at WOT.
Great video. I will be on a similar AUW. Hope it can glide slower too without stalling.
Miha
~>Miha<~ is offline Find More Posts by ~>Miha<~
Old Jun 12, 2010, 05:25 PM
iw28 is offline
iw28's Avatar
Joined Nov 2009
smashed like a pancake almost every part was damaged except the tail wing.
got it from fpvflying.com
Old Jun 12, 2010, 05:27 PM
iw28 is offline
iw28's Avatar
Joined Nov 2009
Originally Posted by Crist Rigotti View Post
What's wrong?
Old Jun 12, 2010, 05:31 PM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I ended up going with this motor.
http://www.toddsmodels.com/SUPG8050_...p/supg8050.htm
Lighter and stronger than the one I was originally going to use. Cheap too!
I didn't get too much slow gliding in. I will give it a try when FPV'ing so I can have a higher altitude to test in. It did slow down pretty good at landing so I think it will slow down pretty good.
Old Jun 12, 2010, 06:12 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
Nice, techspy.
Seems to fly a lot faster than I expected! Much faster than an Eay Star, eh?
You were pulling up nicely... and the wings remained intact! Did you add extra CF or any other support to the wings?
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
