Old Jun 22, 2011, 08:22 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Originally Posted by Cralis View Post
Thanks man! I'll keep that formula in mind. I'm not sure how it works out though. To me, the mah is the mount of petrol the tank can hold... So how does a tank with more capacity, effect the C (Which I am not sure what that represents, but I thought it was how tough a battery is...).
Wait, this is way off topic, so let me add ... Anyone else flying 500mah packs in their Skywalkers ?
C=Current rating. A 20C 1000mAh pack means it's rated to deliver 20x1000mA (or 20x1A) for 20A of constant current while holding voltage. A 20C 5000mAh pack is cable of 20x5A for 100A of constant current. That doesn't mean your power system will draw more amps though. Your power system will only use what it requires. A higher capacity and higher C rated battery is able to supply the current easier than a smaller capacity and smaller C rated battery.
Okay, I said a higher C rated battery doesn't mean your power system will draw more amps...sorta. In most cases it actually will. That is because of the voltage drop under load. A lower capacity/C rated battery will have a reduced voltage under load. A higher capacity/C rated battery will hold a higher voltage under load. Amps=Voltage/Resistance. Resistance is pretty much fixed via the windings in the motor and design of the ESC. Consider resistance a fixed value that doesn't change. Let's say a low capacity/C rated battery only holds 10v under load and a larger capacity/C rated battery holds 11v. Both batteries are connected to a power system measured at 2ohms. The 10v battery will draw 5A (10v/2ohms). The 11v battery will draw 5.5A (11v/2ohms). So the larger capacity/C rated battery will actually allow the system to draw more amps, which equates to more power. All very confusing at times. Just consider larger capacity and higher C rating means easier ability to provide the amps the power system wants at a higher voltage.
Lastly (on the C rating stuff). Don't take C rating as gospel. It is often exaggerated as part of the marketing. I just knock of a couple of C's for a rough guesstimate of what it can actually do. So a 20C battery if probably more truthfully like an honest 15C, A 30C like a 25C, etc. Either way, the larger the pack and the higher the C rating the easier the battery can provide amps while holding a higher voltage level.
As for the second part of your question. Yes, I fly my SkyWalker with a 5000mAh, 3S, 40-50C Turnigy battery. The SW handles the weight with no issues. I cruise around in the 6A-8A range at ~24mph/38kph.
Vantasstic is offline Find More Posts by Vantasstic
Old Jun 22, 2011, 08:27 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Actually, in your example it equates to a constant power. (P=IV)
Blueshy is offline Find More Posts by Blueshy
Old Jun 22, 2011, 08:39 PM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Well, maybe more to 'apparent power' (P=IV), where 'real power' is P=I2R. All mute really as the higher the current and voltage the higher the power in Watts. A higher C pack should provide higher amps since it's holding a higher voltage under load so the overall power is also increased.
Old Jun 22, 2011, 08:41 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Actually no. That was the whole point of the example. Read it again.
The current draw is more or less fixed by the demand of the motor, but the voltage of a
lower C battery may drop under load so P=IV means less total power delivered.
A higher C battery is less likely to drop the voltage under high load, so
given a fixed current draw, and higher voltage, it delivers more power.
Before one jumps to the conclusion that higher C is always better, remember the SW
and most other FPV planes only need 30-40Amps at most, so a 20C 5Ah battery (capable
of delivering close to 100A draw) won't sag at all, and a 25C or 30C battery offers no
benefit at all. It'd be a different story if we were talking 2000mAh batteries at 15-20C rating
for a small fast plane like a Funjet with a hot motor.
ian
Daemon is offline Find More Posts by Daemon
Old Jun 22, 2011, 08:57 PM
Blueshy is offline
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Oops, you're all right. I totally missed the point that he was trying to make.
Old Jun 22, 2011, 09:14 PM
Jaybee is offline
Find More Posts by Jaybee
SLO Flyer
Jaybee's Avatar
San Luis Obispo, CA
Joined Dec 2003
Beautiful video, Tom. Favorited.
Originally Posted by tom223866 View Post
little flight with my skywalker, lawmate 2,4 500 and scherrer uhf
http://vimeo.com/25464739
Jaybee is offline Find More Posts by Jaybee
Old Jun 22, 2011, 09:36 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Has anyone vertical flown the SW?
I am thinking about doing a vertical strait lift for about a min on the SW.
If moto calc calculates right This configuration will do 2419ft(737m)/min @ 90.
Here is the analysis.
In-flight Analysis - Test4blade
1000ft above Sea Level, 29.92inHg, 55F
Motor: Scorpion SII-3026-1190; 1190rpm/V; 3.26A no-load; 0.008 Ohms.
Battery: 11600 LIPO (25C); 3 series x 2 parallel cells; 11600mAh @ 3.7V; 0.0015 Ohms/cell.
Speed Control: Scorpion Commander 110A; 0.0008 Ohms; High rate.
Drive System: APC 10"; 10x6 4-bladed (Pconst=1.11; Tconst=1) direct drive.
Airframe: Skywalker; 550sq.in; 92.5oz RTF; 24.2oz/sq.ft; Cd=0.068; Cl=0.87; Clopt=0.95; Clmax=1.72.
Stats: 156 W/lb in; 136 W/lb out; 19mph stall; 26mph opt @ 47% (255:04, 87F); 27mph level @ 48% (264:21, 87F); 2419ft(737m)/min @ 90; -177ft/min @ -4.4.
AirSpd Drag Lift Batt Motor Motor Input Loss MGbOut MotGb Shaft Prop Thrust PSpd Prop Total Time
(mph) (oz) (oz) Amps Amps Volts (W) (W) (W) Ef(%) Ef(%) RPM (oz) (mph) Ef(%) Ef(%) (m:s)
17.0 2.8 35.9 83.9 83.9 10.8 909.9 119.7 790.2 86.8 84.9 11662 106.7 49.3 28.5 24.2 16:36
I think the stiffening of the tail will need to be done. The plane oscillates with speed.
All opinions accepted.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jun 22, 2011, 10:46 PM
Cralis is offline
Find More Posts by Cralis
I love FPV!
Cralis's Avatar
Eastern side of Australia
Joined Jan 2007
Elevator throws... Are you all using maximum deflection, or are you dialling it down a bit? I am going to maiden mine soon, and wondering if I will battle with full deflection.
Cralis is offline Find More Posts by Cralis
Old Jun 22, 2011, 11:08 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I put mine into the ground for not having enough deflection.
I have it at full deflection.
& I am using the mechanical Anti reverse yaw technique that is described in previous posts.
essentially offset the servo horns one notch to the back, so you get more upward deflection than down.
When you go into a bank, it helps to pull it around, instead of the lower one pushing it in the wrong direction.
m_beeson is offline Find More Posts by m_beeson
Old Jun 22, 2011, 11:12 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
My SW does loops and dodges between trees with +/- 5 to 7 mm of elevator deflection
and the CG somewhere beyond 30mm behind the servo wire slot. The further ahead of
that your CG, the more elevator throw you'll need.
ian
Old Jun 22, 2011, 11:14 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Earthorbiter,
I have seen some steep climbs in youtube. search Skywalker FPV, and Clouds.
I think that will pull up what you are looking for.
Old Jun 22, 2011, 11:15 PM
Cralis is offline
I love FPV!
Cralis's Avatar
Joined Jan 2007
I just put in my 5000mah pack, and find I am still tail heavy. So I added an extra 2200mah pack (dead weight - not functional), and it's perfect. So, might have to fly with dead weight... OR ... remove my power for my camera/vtx from my harness, and power it off the spare 2200mah pack... Maybe that would be a good idea? Lots of work though...
Old Jun 22, 2011, 11:24 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Define "tail heavy"? Where is your CG? If it's anywhere near the wiring slot,
then it's actually severely nose heavy. 25-35mm behind the wiring slot is a better range.
Where I run the CG, I can't put a 4 or 5Ah battery anywhere near the nose.
If you need 7A worth of battery to balance it, something is very wrong.
ian
Old Jun 22, 2011, 11:29 PM
Joined Feb 2011
Originally Posted by m_beeson View Post
Earthorbiter,
Thanks, M B.
I will look for a 1 min climb there.
Old Jun 23, 2011, 01:22 AM
motoguy1 is offline
Find More Posts by motoguy1
MO, USA
Joined Jun 2010
Short of reading all 500+ pages, is there a synopsis of the "must-do" mods for the SW? Mine arrived yesterday, and I'd like to know what's in front of me, assembly-wise.
motoguy1 is offline Find More Posts by motoguy1
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
