Old Jun 16, 2011, 09:34 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Break-down wings
I was looking for some carbon fiber rod to slip inside the carbon fiber tube
I had to settle for aluminum tube
I smeared a light coat of epoxy glue to the outside of the aluminum tube to snug the tollerances
between the two tubes.
Then I hot glued the one side of aluminum tube to the carbon fiber tube.
m_beeson is offline Find More Posts by m_beeson
Old Jun 16, 2011, 10:04 PM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by williamjames View Post
Hey guys,
What can be used in place of the glue that comes with the package to attach the motor mount onto the fuselage? Hot glue has failed on me in the past. I've been advised to use 30min epoxy. Any feedback?
It might work , but the epoxy gets real hard , and have previously cracked on me due to excess vibrations.
octane81 is offline Find More Posts by octane81
Old Jun 16, 2011, 10:33 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Are you saying you cut the stock carbon joiners in half, and left em
glued into the wing? And then are using a smaller diameter aluminum rod
inside that as joiners? If so, why? Aluminum is not nearly as stiff as the same
diameter carbon and once it bends, it stays bent.
ian
Daemon is offline Find More Posts by Daemon
Old Jun 16, 2011, 11:08 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
ian
yes and no (aluminum tube)
Having that long of a wing is somewhat cumbersome to transport, so I decided to figure out a solution.
The aluminum tube is not nearly as heavy as aluminum rod in the same diameter.
I was looking for some carbon fiber (rod or tube) to slip inside, but the local Hobby Shop didn't have anything that worked,
so I had to settle on Aluminum Tube.
It has withstood some pretty heavy impacts already, and it is pretty convenient.
The protrusions under the wings which insert in the fuselage help to support the structure,
then I use 4 rubber bands lengthwise (2 on each side),
and 2 cris cross (one on each side), and it is a sound structure.
I also supported the wing support rods, much like you did.
After I notched the foam, and epoxied these supports in, I drilled them, and the wing support rods slide through the internal supports.
Thanks ian
Old Jun 16, 2011, 11:25 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I'm still not following why you did any of this.
What's wrong with simply pulling the stock uncut carbon joiners out of the wings when
you need to break it down for transportation? That's what most of us do, and it
works just fine. A small diameter aluminum tube simply cannot be as stiff as
the original larger carbon tubes.
ian
Old Jun 16, 2011, 11:35 PM
mandis is online now
Find More Posts by mandis
Joined Jan 2006
Hey guys,
Hot glue works very well as long as you put dowel post on the motor mount. i have added 4 pcs. 15mm dowel on the motor mount.
mandis is online now Find More Posts by mandis
Old Jun 16, 2011, 11:37 PM
Joined Jan 2006
Originally Posted by octane81 View Post
Do you recommend any of these over the included glue?
The included glue work very well. Easy to work with.:
Old Jun 16, 2011, 11:43 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
ian
I read the thread for three nights straight, and didn't even touch the latest materials. 500 pages is a lot of reading.
I missed that part, I figured you guys were gluing the wings as a single structure.
Old Jun 16, 2011, 11:46 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The stock build just uses the carbon tubes as removable joiners, which is
why you don't see much discussion of it.
Some people choose to glue em in, but I've not found the need to do so.
ian
Old Jun 16, 2011, 11:59 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
I put aluminum rod inserts into my stock SW CF tubes and it works great!
The aluminum will hold a bend, but only when the angle of the bend exceeds that of the CF tube before the CF fractures...in otherwords the aluminum has a range of flexibility up to a point and you won't reach that except when you've already broke the CF tubes...and at that point you're probably screwed already
And I know because the video below shows my SW diving (at probably close to 100mph into Lake Michigan with NO DAMAGE!!!) (other than some electrical)
Here's my test...tested, and proven!
http://www.vimeo.com/24755130
Thanks ian
AdamChicago is offline Find More Posts by AdamChicago
Old Jun 17, 2011, 12:00 AM
Chicago, IL USA
Joined May 2010
deleted duplicate post...
Old Jun 17, 2011, 12:14 AM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Cept you didn't cut your carbon tubes in half. He did. His smaller diameter aluminum joiners
are taking 100% of the load.
ian
Old Jun 17, 2011, 01:23 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
ian
Correct,
I have 6" of tube on each side. That seems to distribute the load evenly, and puts the weakest point of the aluminum tube to the center of the wings.
Once it is strapped down with the rubber bands, It is pretty strong. It isn't a junction that concerns me.
However, I have added more weight. Joining the wings as you did was simple and efficient.
Old Jun 17, 2011, 01:40 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
My wing is a single piece......because I am an idiot. I thought the glue had gone off when it hadn't.
No big deal for me. I expect I'll build a second once I have this one properly dialed in with all the electrics giving me my target range.
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jun 17, 2011, 02:08 AM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
What type of T Strength's are some using on Al?
The higher the more brittle with less bending
EarthOrbiter is offline Find More Posts by EarthOrbiter
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
