Old Jun 14, 2011, 01:19 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Putting the VTx and antenna on the wingtip will almost eliminate interference/RF shadow from the electrical components in the fuselage
That stock boom location is not ideal.
Originally Posted by aa78 View Post
I moved the Vtx to the flat spot on the boom behind the motor. Since the ESC is placed near that spot, there was interference from the ESC in some portions of the throttle range.
http://vimeo.com/25051435
There was minimal static compared to the last two Vtx positions (canopy and side of fuselage).
There is still a pronounced yaw to the left which was corrected with trim, for this flight. I might need to have a look at the motor's mount to see if it is seated properly.
The SW was flown for 28+ minutes which was squeezed into this six and a half minute clip.
Enjoy!
Skywalker FPV build log
AdamChicago is offline Find More Posts by AdamChicago
Old Jun 14, 2011, 01:33 PM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
That's too much fatigue on the wiring/connectors on each mount/dismount cycle of the wing. Any sudden maneuvers will add stress to the wingtip area due to extra weight. Plus, the Vtx has to be balanced with a counter weight on the other wingtip. Putting the Vtx inside the wing would require the wing's foam to be carved out. Comments/opinions on all that?
Out of the three locations I tried, the one on the boom worked out best for having the least static, excepting the ESC noise.
aa78 is offline Find More Posts by aa78
Old Jun 14, 2011, 01:44 PM
omegamanuk is offline
Find More Posts by omegamanuk
omegamanuk's Avatar
United Kingdom, Bradford
Joined Jul 2010
Originally Posted by EugeneFlorida View Post
What ESC are you using with the Turnigy TR 35-36 1450kv Brushless Outrunner.
thanks
EugeneFlorida, i'm using a 45a Ripmax dragon, I would steer clear of it as the programming is unfathomable.
The motors made a massive difference, loads of power to the extent that the SW feels much lighter whilst flying, and doesn't feel like its dragging its tale . Noticed the motor and ESC are now getting warm to the touch where as they were stone cold before.
Need to get an amp meter on it to see what its pulling at WOT just to be safe. Guess its given me a bit more confidence with it as I feel like I've got enough power to get out of trouble.
omegamanuk is offline Find More Posts by omegamanuk
Old Jun 14, 2011, 03:20 PM
Chicago, IL USA
Joined May 2010
There are actually quite a few who mount the antenna this way on Skywalkers and other planes, including myself with great success.
I use shielded USB cable with servo connectors on the ends for the VTx feed so when I break down the wing it's just a simple unplug or plug just like any normal servo connection. Then while some fly it with no counter weight with no problems (Crist for example), I partially counter balance mine and it works fine. I have not experienced any lateral CG or asymmetric-drag issues at all...it's unnoticeable...I do the same on my Zephyr as well
It made such a huge difference in video reception it's totally worth trying.
Old Jun 14, 2011, 04:24 PM
AndreF2TH is offline
Find More Posts by AndreF2TH
AndreF2TH's Avatar
Sao Paulo, Brazil
Joined Nov 2010
aa78,
Adding weight to the wings, i.e. VTX and counter-weights, may be not only harmless but also helpful on keeping the wing's integrity. In fact, a heavy fuselage and a light weight wing means concentrating forces on the wing roots and, in SW's case, on the dihedral break point. In this sense distributing some of your loads to the wing could be a good idea, as it directly counterbalances lift and frees the critical junction points of some loads.
This is exactly how it's done in full-scale, large commercial jets. Although most of them have wing and central tanks, the latter is only used when necessary, and also the first one to be used up after take-off, leaving most of the fuel load in the wings for the remainder of the flight.
Regards.
Anddre
AndreF2TH is offline Find More Posts by AndreF2TH
Old Jun 14, 2011, 04:34 PM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
Skywalker, Chainlink, CEOSD, 1.2ghz 800mw VTX, Lawmate VRX, Turnigy 9x.
FPV Skywalker CEOSD v1.5 (14 min 34 sec)
Cir2kuk is offline Find More Posts by Cir2kuk
Old Jun 14, 2011, 09:32 PM
motojoe996 is offline
Find More Posts by motojoe996
motojoe996's Avatar
Panama City, Fl
Joined Jan 2009
First Skywalker FPV maiden...
Skywalker FPV maiden (3 min 19 sec)
This a clip from the second flight from the 4S 4000 that I use. I had to come down and do some hardware swapping, then this flight.
I wanted to check motor amp draw, ESC temps..., which the ESC is located in the wing root. I have a temp sensor from RangeVideo OSD next to the ESC. The first flight showed ESC compartment temps up to 136, under various throttle settings, such as during this flight. After cutting some small vents in, temps show ambient temp or a few degrees above.
Aircraft weight for this flight was 1760g.
Equipment list:
RVOSD /GPS, current sensor
Cheapo security cam
900mhz video TX
4S 4000 main batt
APCe 10X5e
3S 100 video/OSD aux batt
BPHobbies 2814-8 1100kv motor
BPHobbies 45A ESC
5A BEC
CoPilot IR sensors (x2)
AR6200 RX
misc wires/connectors
Next up, checking out same numbers and flight characteristics with a GoPro in the nose.
Feel free to ask me any questions you may have.
Also, I've been flying my TwinStar II via FPV for the past 2 years (vids on YT). I decommissioned that very trusty platform to try this out.
Thanks for watching,
Joe
motojoe996 is offline Find More Posts by motojoe996
Old Jun 14, 2011, 09:37 PM
saucisse is offline
Find More Posts by saucisse
Don't disturb the pilot !!!
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
Some fun with the Skywalker...this is definitely my favorite plane of my fleet!
Skywalker FPV fun! (3 min 5 sec)
saucisse is offline Find More Posts by saucisse
Old Jun 14, 2011, 10:03 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
http://vimeo.com/25114412
Nice flying.
m_beeson is offline Find More Posts by m_beeson
Old Jun 14, 2011, 10:06 PM
mustangbrandon is offline
Find More Posts by mustangbrandon
United States, NC, Wake Forest
Joined May 2011
That was one damn fun video to watch! I thougt for sure I was going to get a face full of grass a couple times! You need to mount a 3D gopro and do that again!
mustangbrandon is offline Find More Posts by mustangbrandon
Old Jun 14, 2011, 10:34 PM
aa78 is offline
Fast and low...
aa78's Avatar
Joined Apr 2009
Any pics of your Vtx installation in the wing?
There is the option to bring all wires (servos, Vtx) into a single connector (e.g. DB9, perhaps?) and simply plug that into the mating connector.
Old Jun 15, 2011, 04:58 AM
latin105fm is offline
Find More Posts by latin105fm
latin105fm's Avatar
London, UK
Joined Jan 2009
Hacker motor??
Has anyone stuck a HACKER motor in their skywalker?
What model was it??
Cheers
Dan
latin105fm is offline Find More Posts by latin105fm
Old Jun 15, 2011, 07:09 AM
Moose2 is offline
Find More Posts by Moose2
Moose2's Avatar
Joined Aug 2008
saucisse-
What camera are you using?
Moose2 is offline Find More Posts by Moose2
Old Jun 15, 2011, 08:37 AM
saucisse is offline
saucisse's Avatar
Canada, QC, Quebec
Joined Jun 2008
FPV cam is the RCV922 on pan tilt (which is real good !!) and GoPro HD (which sucks in low light conditions as you can see) for onboard recording.
I still don't get it why some still want to use the GoPro as a primary cam for FPV, did it for a while and since I've switch to the RCV922 I just can't figure out why I did not go with this one in the 1st place...
Originally Posted by Moose2 View Post
saucisse-
Old Jun 15, 2011, 08:52 AM
Fpvicv is offline
Find More Posts by Fpvicv
$$$'s vs Skill
United Kingdom, England, High Wycombe
Joined Feb 2011
Skywalker Newbie - My Setup
Hi forum!
Been watching and poaching ideas from this thread for a while now. Finally have all my gear and the Skywalker is coming together nicely. Couple of custom parts are taking some time to finish. Will post pictures of the build before the maiden... just in case it is the only flight it does.
For those interested, here is my setup:
Scorp Commander 70a ESC
Scorp 3014-1220KV Motor
APC 9x4.5 Prop for 4S (2200g thrust), 9x7.5 Prop for 3S (1650g thrust)
HS65-MG's on control surfaces, HXT900 added to tailwheel
Carbon Fiber landing gear, 55mm wheels (short grass takeoffs)
Custom wing saddle and mount, attaches using 4 Nylon screws.
Carbon strips in wings, vert and hori stabs as well as carbon supports between hori and vert stabs.
Custom 1mm aluminium canopy.
Fibreglass sheath round rear part of tail and vert stab to limit tail twist.
Will be running on 35mhz rc with 2.4ghz vtx, pan/tilt mount with 420TVL camera, nothing special. OSD will be EagleTree OSD Pro with Data Logger V4 and FY21AP, V4 GPS, Altimeter Module, Airspeed Module.
Fingers crossed.
Fpvicv is offline Find More Posts by Fpvicv
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
