S. Wales
Joined Jun 2008
mustangbrandon don't be too nervous. I felt the same on my maiden. After reading all the threads in all the various forums I got to the point where I felt it's now or never. I got some one to launch the SW horizontally without putting too much effort into the throw. The SW set off and started to pitch up, got it horizontal with a bit of down and then let it climb to a safe height before putting in quite a lot of down trim. Turns were a bit hairy, the ailerons being a bit slow to take effect but nothing frightening. After a few manoeuvres I was happy the plane was controllable and enjoyed the rest of the flight.
Good luck. |
Joined Oct 2010
Do and re-do your pre-flight checks and go for it. I have done 4 flights with my skywalker, LOS before installing the FPV kit. Here is what I have learnt: Flight 1 - Did not have enough aileron throw, lost control, got into a spin and ended up in the top of a tree. Snapped tail off just below tail plane . Increased the aileron throw, repaired with gorilla glue and fibre tape.Flight 2 - <15 seconds, nose in to ground . Conclusion: did not launch with enough power, did not have enough air speed to get control or height. Smashed nose in, repaired with gorilla glue and fibre tape.Flight 3 & 4 - (today) Re checked everything, CoG ~20mm behind servo wire, good aileron throw. 75% throttle, good fast throw, gained height and enjoyed 15mins of exploring the behaviour and limits. Landing required faster approach than I am used to with my Hawksky but two successful landings brought a smile to my face. Hope that helps you skip my first two disasters and go direct to a big ![]() Regards, Mark Leman |
http://www.innov8tivedesigns.com/pro...2e9864b41738a3 On 3S one can run a 10x5E, 10x7E or even a 11x5.5E if it'll fit on the plane. On 4S one can run 9x4.5E or 9x6E. If you haven't bought the LiPos yet, consider buying 4S rather than 3S simply because of then having to only step-down voltages for on-board 12V equipment. A second advantage is less losses due to lower amp-draw at the higher voltage. |
Scorpion 3014 Item Number scp3014 / 23018 / WS3 , Options: Wind(3014-16 (1187Kv)) is it the same one? Cheers |
I didn't change the thrust line angle. If I'm low to the ground and mash it to full throttle, it will pitch down a bit until the airspeed picks up, for the reasons mentioned above. Quote:
gliding to full throttle. It still has a little bit of positive stability so it'll glide level, hands off, but if I roll onto the throttle smoothly the nose doesn't go up or down. Quote:
and lengthen your pushrods to re-center the control surfaces. That'll create mechanical differential and they'll go up faster/further than they go down. Quote:
ian |
Latest blog entry: My 2012 FPV year in Review
thanks |
Get a Zephyr...they're rockets and very responsive...good for proximity flying.
| Thread Tools | |
| Question Best plane for FPV while on vacation? | patricklupo | Video Piloting (FPV/RPV) | 23 | Aug 08, 2010 06:27 AM |
| Cool FPV plane rescue with an FPV truck :-) | AnthonyRC | Video Piloting (FPV/RPV) | 17 | Feb 24, 2008 10:45 PM |
| For Sale Skywalker plane and a bunch of extras | moody07747 | Aircraft - Electric - Airplanes (FS/W) | 8 | Sep 19, 2006 09:34 PM |
| Discussion Aviator Skywalker RC plane given to me | moody07747 | Electric Plane Talk | 46 | Sep 12, 2006 11:45 AM |
