Old Jun 11, 2011, 11:17 PM
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by henkvdw View Post
Those motors are probably to small.
These are probably better suited to 3S use:
http://www.hobbypartz.com/86mb85-3015-1450kv.html - watch the Amps on this one.
http://www.hobbypartz.com/86mb86-3015-1300kv.html
and 4S:
http://www.hobbypartz.com/86mb87-3015-1100kv.html
Thank you henkvdw,
I got it ordered
m_beeson is offline Find More Posts by m_beeson
Old Jun 11, 2011, 11:39 PM
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Originally Posted by cmanley_nl View Post
To those of you who have added flaps:
How effective have they proven to be?
I haven't decided yet on whether I should build them in or not since they seem so small.
Actually I added flaps. I thing SW does not need flaps because it is already a slow flyer but with flaps you can easily catch your plane when it's landing. Very effective on landings and take offs.
Firatp is offline Find More Posts by Firatp
Old Jun 12, 2011, 04:15 AM
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by AdamChicago View Post
Here's one of my favorites so far...a little somber, but good
http://www.vimeo.com/24961942
That was a very scenic and beautiful video, not somber at all... it depends on the mood you are I guess. I found it relaxing
You are brave flying on the water like that.
rcmonster99 is offline Find More Posts by rcmonster99
Latest blog entry: Airframes
Old Jun 12, 2011, 07:49 AM
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I also have flaps and I think they are really useful. Mine are set at ~45 degrees and ~85 degrees so they kill speed very effective
In my video where follow a car you clearly see where I applied flaps
(where the plane almost stops)
Chitchat FPV (3 min 15 sec)
UndCon is offline Find More Posts by UndCon
Old Jun 12, 2011, 09:26 AM
takeoff2's Avatar
Romania
Joined Jan 2009
I'd say you really don't have to have them, I've landed many times without, but it is kinda fun to use them.
In my particular case, having a SW at 3.4kgs, I definitely need the flaps for launch and ......
Wow,Adam,why is it so heavy?
takeoff2 is offline Find More Posts by takeoff2
Old Jun 13, 2011, 12:42 AM
Outta Sight
Australia, WA, Perth
Joined Jul 2008
Hey Adam, thats a really nice video, the afternoon light always makes for a nice FPV vid IMO. I dont download and keep many FPV vids but this one is excellent. I'd like to use it to show friends what FPV looks like, so thanks for posting it..
I am also wondering what you have in there that makes you so heavy, I didnt see an answer. No doubt the extra mass works as a stabilizer making your footage so smooth.
(Found out the hard way, but we now know that the SW foam can float over 3kg )
Cheers,
R,
RolandS888 is offline Find More Posts by RolandS888
Old Jun 13, 2011, 09:04 AM
United States, NC, Wake Forest
Joined May 2011
That's what I did...I actually cut the nose clean off in front of the canopy, mounted the GoPro to the top of the part that was cut off, then re-attached the nose but with layers of vibration deadening material (foam and moongel) in between.
Originally I was a little worried about having it on the nose where it could get damaged, but its in its protective case and probably 4-5 inches up from the ground on landing, and I haven't had any problems/damage yet...except for crashing into the lake but that's a whole other story
I am so digging the cocktail hour in the background. But IMHO you need better Gin...
mustangbrandon is offline Find More Posts by mustangbrandon
Old Jun 13, 2011, 09:25 AM
Joined May 2011
Originally Posted by m_beeson View Post
Thank you henkvdw,
I got it ordered
Mike, Which one did you go with? I just mounted this one, hopefully it works!!
http://www.hobbypartz.com/75m21-opti...10-1020kv.html
Old Jun 13, 2011, 10:26 AM
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Good, light-weight choice motor.
Are you going to run 3S or 4S?
On 3S my guess would be, that you'd have to run a 10" or 11" prop on a motor with the 1020 kV to get the max thrust that this motor can produce safely.
On 4S probably not more than a 9x4.5E. Make sure not to over-amp this motor on 4S. If it pulls to many Amps on a 9" prop you may have to go down to 8".
henkvdw is online now Find More Posts by henkvdw
Old Jun 13, 2011, 11:39 AM
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
LOL - I was thinking the same
Old Jun 13, 2011, 12:32 PM
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
I'm running two 3600 4S mains and 1250 3S for video and then I don't trust the wings so I added two wooden wing length spars on either side of the main and also epoxy reinforced the tail, then its full FPV/OSD additionally with an FY20A, GoPro-in protective case, Castle BEC Pro (hefty), E-Flite 60amp ESC (hefty), and Scorpion 3020-14 (hefty)...so all that and epoxy/Gorilla Glue and fiber tape to support it all and you get a little hefty. But it hand launches fine, flies fantastic, handles more like a stable full-scale rather than a floaty parkflyer
AdamChicago is offline Find More Posts by AdamChicago
Old Jun 13, 2011, 12:34 PM
Chicago, IL USA
Joined May 2010
Roland, thanks! Too funny about floating 3kgs of SW ...yep, that test has been confirmed successful
Cheers,
R,
Old Jun 13, 2011, 12:36 PM
Joined May 2011
henk,
I'm running a 9x6 on 3s to start. I have a 5000mah batt already... I'm not running heavy to start besides the battery. Have eagle tree components inside and a 900mhz transmitter on the boom. Once I get comfortable with the plane and maybe add a gopro i would step up.
Unless somone sees somthing wrong with this combo...
Old Jun 13, 2011, 12:39 PM
Chicago, IL USA
Joined May 2010
RCMonster, thanks...I wasn't too brave the next day when it crashed into the lake It's a good thing it's built like a tank because the 400ft plunge didn't damage anything LOL
Old Jun 13, 2011, 12:40 PM
Chicago, IL USA
Joined May 2010
It took me a moment to figure that one out LOL That's why my SW is so heavy, I like to keep a bottle booze in it for emergency
Question Best plane for FPV while on vacation? patricklupo Video Piloting (FPV/RPV) 23 Aug 08, 2010 06:27 AM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC Video Piloting (FPV/RPV) 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
