Old Jun 11, 2011, 02:24 PM
omegamanuk is offline
Find More Posts by omegamanuk
omegamanuk's Avatar
United Kingdom, Bradford
Joined Jul 2010
AdamChicago, cool video, what sort of altitude were you at?
omegamanuk is offline Find More Posts by omegamanuk
Old Jun 11, 2011, 02:54 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Is it possibly to but this piece anywhere ? I just can't find it on the web.
SpookiePower is offline Find More Posts by SpookiePower
Old Jun 11, 2011, 03:11 PM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
To those of you who have added flaps:
How effective have they proven to be?
I haven't decided yet on whether I should build them in or not since they seem so small.
cmanley_nl is offline Find More Posts by cmanley_nl
Old Jun 11, 2011, 03:15 PM
ssassen is offline
Find More Posts by ssassen
Netherlands, NH, Edam
Joined Jul 2004
Nah, depends on what your AUW will be and how short your landing strip is, I didn't feel the need for them really.
As a FYI, here's a topic aspiring SW pilots should certainly take a look at:
Sander's Skywalker FPV camera plane build
http://www.rcgroups.com/forums/showthread.php?t=1262099
Cheers,
Sander - ImmersionRC
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Jun 11, 2011, 03:39 PM
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Cheers,
Thanks, I guessed so. In the mean time I remembered that while testing the Skywalker in all kinds of abnormal manoeuvres as like I do with everything I fly (hence the Fox <=), I could hold full rudder and some contra aileron and fly in a straight rapid descending line (like old-timer gliders do in slip landings). I think I'll practice that some more and see how viable that is as a short flapless landing technique.
Oh yes, I checked your build out some time ago - it's really neat - almost too neat for a foamy. I just wonder how you did the UHF antenna wiring though at the wing joint (elbow connectors?) as I'm still looking for ideas on how to set up my UHF RX and antennae while I wait for my crimping tools and other stuff to arrive from China and while I grow grey hairs trying to build a descent ground station.
Old Jun 11, 2011, 03:55 PM
Mikey636 is offline
Find More Posts by Mikey636
Mikey636's Avatar
United States, VA, Charlottesville
Joined Dec 2010
I have flaps on my skywalker and think they work great. Why not add them..it's minimal weight
Mikey636 is offline Find More Posts by Mikey636
Old Jun 11, 2011, 04:18 PM
Joined Jun 2009
Originally Posted by AdamChicago View Post
Here's one of my favorites so far...a little somber, but good
http://www.vimeo.com/24961942
Great video and the harbour really looks beautiful from the air
Do you know your longest distance, when you went out over the sea ? You seems to be pretty far away from home.
Old Jun 11, 2011, 04:31 PM
ssassen is offline
Joined Jul 2004
I ripped that out again, too cumbersome in transport, I now typically do it like this:
Cheers,
Old Jun 11, 2011, 07:39 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by thekubiaks View Post
Priority one
if it were my Skywalker would be to make sure the CG (balance point) is on the servo wire channel. The plans call for the CG to be 75mm behind the leading edge, the forward edge of the servo wire channel is 78mm back on my Skywalker. I see that people are able to fly at up to 120mm back so there is a wide "envelope". In general, a more forward CG is more stable but a little less efficient. I would put the CG on the servo wire channel, get everything trimmed up, and then you can start moving the CG back in small increments if your really want to experiment. Since the Skywalker is molded EPO, I think that the wing/tail angle of incidence issue is not likely unless there was some gross building error.
henkvdw, sassen, & kubiaks,
Thank you for your input..
I noticed that the Turnigy motor that is recommended a few pages back; is back-ordered.
Can someone advise me on a motor?
I'm as lost as a prostitute in a church house when it comes to electric power RC .
I found these
I plan to use a 3S, or 4S Lipo. Trying to use 3S first...
Exceed RC Rocket Brushless Motor 1300KV for Airplane
Exceed RC Rocket Brushless Motor 1500KV for Airplane
Exceed RC Rocket Brushless Motor 1700KV for Airplane
m_beeson is offline Find More Posts by m_beeson
Old Jun 11, 2011, 07:55 PM
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Thanks, that's a neat build, again, and both a practical as well as easy V antenna setup.
Old Jun 11, 2011, 08:43 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Omega thanks! ...pretty high
AdamChicago is offline Find More Posts by AdamChicago
Old Jun 11, 2011, 08:52 PM
Chicago, IL USA
Joined May 2010
Spookie, for right or for wrong I actually tested my furthest distance on that flight which was 6500ft LOS...really not far compared to others but I was happy with it. My RSSI was at about 81 and the video held up great, but I just didn't want to push it by going any further.
Ironically I crashed this plane into the lake the next day (check a couple videos back in my Vimeo account for the video) but from about half the distance??? By some miracle a sailor found the plane and returned it to me and it's in perfect shape except I have to test the dried-out electronics...go figure
Old Jun 11, 2011, 08:58 PM
Chicago, IL USA
Joined May 2010
I'd say you really don't have to have them, I've landed many times without, but it is kinda fun to use them.
In my particular case, having a SW at 3.4kgs, I definitely need the flaps for launch and like having them to shorten the landings. With 3.4kgs of mass behind you the SW just wants to keep going on the final glide before touch down.
Old Jun 11, 2011, 09:50 PM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
I found these
Those motors are probably to small.
These are probably better suited to 3S use:
http://www.hobbypartz.com/86mb85-3015-1450kv.html - watch the Amps on this one.
http://www.hobbypartz.com/86mb86-3015-1300kv.html
and 4S:
http://www.hobbypartz.com/86mb87-3015-1100kv.html
henkvdw is offline Find More Posts by henkvdw
Old Jun 11, 2011, 10:28 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Hi all,
Doing some editing using PowerDirector 9 a 15 min YouTube was uploaded showing the entire flight. I thank immersion for a wonderful rc link because during this flight the xmit antenna was vertical while rcv was horizontal. It passed my test.
15 min FPV Flying (15 min 0 sec)
EarthOrbiter is offline Find More Posts by EarthOrbiter
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
