Old Jun 10, 2011, 01:46 AM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
Originally Posted by sfakias View Post
This is with the servo positioned at bottom of wing. For top mounted servo, the horn should be tilted rearwards when the servo is at the neutral position, correct?
My horns are almost 45degrees forward direction when rudders are neutral.(servos mounted on bottom side of wing)
About Tilt rear - correct - your goal is still the same.
As is right now I have 4 channels for my wing
2 ailerons and 2 flaps
I did not use the advantages of trimming any surface separately and If I do I can do so with the linkage instead.
I'm going to solder a bunch of Y-cables to solve this and it most likely requires reversing of 2 servos mounted in the wing (internal servo mod)
UndCon is offline Find More Posts by UndCon
Old Jun 10, 2011, 04:35 AM
WalneyCol is offline
Find More Posts by WalneyCol
youtube.com/seafax
WalneyCol's Avatar
United Kingdom, Barrow-in-Furness
Joined Feb 2011
Originally Posted by venquessa View Post
If at 100% throttle it needs 60amps to achieve close to it's Kv, then at 50% throttle it will draw 60amps (or more!) for 50% of the time.
Cheers Venquessa, I know it should have been obvious but it was quite a lightbulb moment for me. :-)
WalneyCol is offline Find More Posts by WalneyCol
Old Jun 10, 2011, 08:06 AM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
Venquessa and vegasbs, thanks for the explanation. I've been googling and reading a lot and understand what you are saying, I see how the loads may be focused on one winding only at 1/3 throttle instead of spreading the load to all windings, very interesting.
Where I am going off of the tracks is with this example.
I'm looking at this Turnigy Motor
Dimension: 36mm x 51mm, 70mm(with shaft)
Weight: 181g (kv1450) (not including connectors)
Diameter of shaft:?strong>F5mm
Length of front shaft:?strong>F19.1mm
Lamination thickness: .2mm
Magnet type: 45SH
Specification:
No. of cells: 3-6S
RPM: 1450kv
Max efficiency current: 45A-50A
No load current: 11.1/4.6A
Current capacity: 70A/20sec
Internal resistance: 0.010ohm
Max performance;
Voltage: 3-6S
Prop: 7x5, EDF90
ESC: 60A
Thrust: 1450-2300g
Power: 1600W
For EDF 1500~1800g model airplane.
Kv (rpm/v) 1450
Weight (g) 181
Max Current (A) 50
Resistance (mh) 0
Max Voltage (V) 22
Power(W) 1600
Shaft A (mm) 5
Length B (mm) 51
Diameter C (mm) 37
Can Length D (mm) 30
Total Length E (mm) 70
The motor states it can take 1600 watts. If I deliver 22V (6S) and 50Amps (max rated), I am only delivering 1100watts. How would I ever get to 1600 watts without exceeding a limit??
People using this motor are reporting pushing this motor to 1597 watts but it takes 92amps. Are they vastly overamping the motor?? THANKS AGAIN!!
thekubiaks is offline Find More Posts by thekubiaks
Old Jun 10, 2011, 08:24 AM
billyd60 is online now
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Magnet type: 45SH
Specification:
No. of cells: 3-6S
RPM: 1450kv
Max performance;
Voltage: 3-6S
Prop: 7x5, EDF90
ESC: 60A
Thrust: 1450-2300g
Power: 1600W
Kv (rpm/v) 1450
Weight (g) 181
Max Current (A) 50
Resistance (mh) 0
Max Voltage (V) 22
Power(W) 1600
Shaft A (mm) 5
Length B (mm) 51
Diameter C (mm) 37
The 1600 watts is a peak number and the amps is a continuous number. So continuous power out of this motor is 3.7x6x50x.8(efficiency) = 900watts continuous. Working backwards, the 1600/.8 = 2000 peak watts in. 2000/(3.7x6) = 90 amps peak.
billyd60 is online now Find More Posts by billyd60
Old Jun 10, 2011, 08:26 AM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
I don't use the motor but your post said the motor can take 70A for a while. A fully charged 6s has 25.2v. At 25v and at 70 amps that's 1750 watts. That wouldn't be maintained for long but 1600 could.
Floater73 is offline Find More Posts by Floater73
Old Jun 10, 2011, 02:49 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
I would really like to pan my camera, but the rudder use my pan-channel. Should I drop the use of rudder, and only turn left/right with the use of ailerons, so that I can pan ?
I have a 7 channel Futaba, but I guess that the last 3 channels are controlled by the switches.
SpookiePower is offline Find More Posts by SpookiePower
Old Jun 10, 2011, 02:52 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
I would advice not to cancel rudder. During low speeds ailerons are not enough to steer.
Firatp is offline Find More Posts by Firatp
Old Jun 10, 2011, 03:00 PM
Joined Jun 2009
I guess you are right Thanks.
I have a switch on my Futaba with 3 positions (up/center/down). Would it be possibly to use this as Left/Center/Right-position for my pan-servo ?
I just did a test, and it worked just fine using the switch for Left/center/right-pan. I think I'll use that.
Old Jun 10, 2011, 03:36 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
And depending on the level of aerial videography you do, it's nice to be able to point the plane/camera in a cross wind while keeping the plane level
AdamChicago is offline Find More Posts by AdamChicago
Old Jun 10, 2011, 05:04 PM
UndCon is offline
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
I have my camera connected to elevator /rudder with Y-cables and I really like it
Old Jun 10, 2011, 06:17 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
So,
I got my skywalker together. I took it up the other day, and tried to fly it.
Despite the lack of thrust that it was exhibiting; I continued to try to fly it until
I crashed it.
I got it repaired and waited for a good day which happened to be today...
When I launched it, It still showed a lack of thrust (with a higher pitch prop) , but it was flying. I went to bank it to the right, to bring it on course & nothing...
I let off the throttle, and it started to bank, but then it nosed in.
I thought I tested it on the ground, but now I can't remember. When I showed up to the crash site, everything was working.
I'm starting to get a little frustrated. I just want to fly. I never used to have this many problems with nitro pull prop set-ups.
motor 780 kva
prop circa 9 1/2x10
Battery 3s 5300 mah
CG 30mm behind aileron wires.
I can't figure out why the it woudn't bank.
m_beeson is offline Find More Posts by m_beeson
Old Jun 10, 2011, 06:40 PM
henkvdw is offline
Find More Posts by henkvdw
KJ6BFN
henkvdw's Avatar
United States, CA, Fountain Valley
Joined Aug 2008
Originally Posted by m_beeson View Post
So,
Despite the lack of thrust that it was exhibiting; I continued to try to fly it until I crashed it.
motor 780 kva
prop circa 9 1/2x10
Battery 3s 5300 mah
With a Voltage constant (kV) of = 780 RPM/V and a 9.5"x10" prop one could probably run on 5S before the motor will generate the thrust needed.
Although 10" pitch prop is in my opinion not well suited to this plane. The SW flies relatively slow. That 10" pitch is for moving fast. So you are probably also stalling it. 6" pitch is more than enough.
On the 3S pack that you are running you should have a motor with kV of 1300 to 1450.
henkvdw is offline Find More Posts by henkvdw
Old Jun 10, 2011, 07:30 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I'm watching the video right now. That's another story. My computer is having a problem with Emperex files.
Anyway, it reaches a speed of 20mph, and I can see when I give it aileron to bank right, it doesn't react.
Then it banks right, but I give it left aileron and it stays in a right bank.
Full throttle, until it circled 270 degrees, then I let off, and when it nosed in, I punched it, but it wouldn't pull up because it was in a right bank.
Old Jun 10, 2011, 07:32 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
9x6 prop with this motor on a 3S didn't have enough thrust to glide
Old Jun 10, 2011, 09:36 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Everybody likes to watch carnage these days. Enjoy
unresponsive SkyWalker (0 min 55 sec)
If you watch the ailerons, you can see that I hold them in the right-bank position for about 5 seconds before I get any response.
Then I hold them in the left-bank position (trying to level it out) and it remains in a right bank.
p.s.
I'm settled down now a little, and not clouded with anger & frustration any more.
I'd like to figure it out though before I chuck this thing in the air again.
Has anyone else experienced these symptoms?
Does anyone have a stall-speed on this airframe?
I am wondering if I just tip-stalled d/t insufficient thrust & speed. I'm thinking about purchasing a more suitable motor.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
