Old May 23, 2011, 05:13 PM
delimawi is offline
Find More Posts by delimawi
when dreams come true
Turkey, Istanbul, Istanbul
Joined Dec 2006
Originally Posted by Targetlocman View Post
I now use the rubber bands to play with the cats.
What is twinstar, any links for that?
delimawi is offline Find More Posts by delimawi
Old May 23, 2011, 06:02 PM
Alpina540 is offline
Find More Posts by Alpina540
Fly Big, Low and Slow....
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
No rubber bands for me.... two Twinstar wing mounts and nylon bolts on my Skywalker. I now use the rubber bands to play with the cats.
If anyone has the skywalker rubberbands and is not using them I wil buy them off you as long as they are in good condition.
Alpina540 is offline Find More Posts by Alpina540
Old May 23, 2011, 07:03 PM
randall1959 is offline
Find More Posts by randall1959
Joined Feb 2004
Originally Posted by Daemon View Post
The keychain cams generally suck, but all those wavy's are telling you, you need to
balance your prop. A CCD camera won't show the vibration as much, but all
current compact HD cameras use CMOS sensors so they will all show it.
ian
Yea I allready knew all that. I've been doing AP and AV for 10 years. This was simply stuck to the wing with double sided tape with no foam. The prop is allready balanced.
randall1959 is offline Find More Posts by randall1959
Reply With Quote  (Disabled)
Old May 23, 2011, 07:04 PM
Joined Feb 2004
Great planes #64 will work. That's what I use.
Old May 23, 2011, 07:06 PM
Joined Feb 2004
Originally Posted by takeoff2 View Post
Sorry for the intervention, but some of you,seem to not know how to mount the rubber bands.Attach a picture with correct position.
As long as you criss cross them you don't need to do anything else. You don't have to run 2 lengthwise as the wing fits into a pocket in the fuse.
Old May 23, 2011, 07:18 PM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
This was not my idea, I found out about it in this thread.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPVG7&P=Z
Along with:
http://www3.towerhobbies.com/cgi-bin...?&I=LXTDE8&P=7
Add two plywood (1/4" or thicker) pieces and either drill and tap for 5mm thread or use 5mm blind nuts.
No more rubber bands, screw the wings in place, and the twinstar wing mounts also hold the wings together. Just press them into the wings in two places and then locate the plywood in fuse directly underneath them. The screws pass through the plastic mounts between the two wings and thread into the plywood mounted in the top of the fuse (in the cavity where the wing plugs in).
billyd60 is offline Find More Posts by billyd60
Old May 23, 2011, 07:47 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
.....My SkyWalker would violently do a 360 Loop with full throttle and only/slightest amount of "up" elevator.....scary! it happend soo quick!
Someone mentioned that I was too "tail heavy" ?
I'm at 20mm COG.
but I think my rubber bands on the wings were not strong enough to hold the wings' down into the fuselage. I will use all 4 rubber bands diagonally this time around, and buy more #64 RubberBands.
so all in all, the cause of this was the front leading edge was raising/rising up from the fuselage?????? anyone confirm if this is true.
rclab1 is offline Find More Posts by rclab1
Old May 23, 2011, 09:26 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
I'm at 20mm COG.
This happened with mine as well. When the planes angle of attack is increased the lifting pressure moves forward on the wing. At a given speed and angle the force can be large. It is important to secure the front of the wing unless flying upside down. After setting the bands I grab the leading edge and give it a brisk lift upward verifying it will not separate.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old May 23, 2011, 10:07 PM
Strudel is offline
Find More Posts by Strudel
Joined Jan 2011
Finally ordered one Skywalker frame from BevRC + FY20 II.
The journey begins.
Now to order other parts!
Strudel is offline Find More Posts by Strudel
Old May 24, 2011, 12:26 AM
JLager is offline
Find More Posts by JLager
Canada, BC, North Vancouver
Joined Apr 2011
First of all, sorry for the noob questions. This is my first plane that I'm building myself and I've definitely jumped in on the deep end but it's gone well... so far
I'm wondering how to properly mount the motor to my Skywalker. Does the wood mount that came with the Skywalker screw onto the motor with the metal X mount that came with the motor, sandwiched inbetween? And then do I glue the wood mount onto the foam mount position on the Skywalker?
If so, do I need to enlarge the hole on the wood mount since there is metal ring mounted on the motor shaft (see picture) which won't fit through the wood mount? Or can I simply remove the metal ring? What is it for anyway?
Description:
I've already cut out a compartment in the foam mount so the motor shaft can spin freely in there? Was that the right way to do it?
Finally, should I be angling the motor a certain way or is whatever angle currently on the foam mount sufficient?
Again, sorry for the bunch of beginner questions and thanks in advance!
JLager is offline Find More Posts by JLager
Old May 24, 2011, 12:31 AM
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
That metal ring holds the motor together, best not remove it.
Go ahead and make the hole in the ply larger than the ring to fit.
Old May 24, 2011, 12:32 AM
JLager is offline
Joined Apr 2011
Old May 24, 2011, 12:53 AM
aa78 is offline
Find More Posts by aa78
Fast and low...
aa78's Avatar
Joined Apr 2009
SW video from this weekend:
20110522 - Skywalker EPO FPV flight (8 min 40 sec)
Nearly crashed it but luck was on my side for now.
5.8GHz 200mW Vtx was shifted from canopy to the right side of fuselage for this flight resulting in more than usual static.
aa78 is offline Find More Posts by aa78
Old May 24, 2011, 02:17 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Hey aa, Islamambad is not as green as I remember it. I visited as a bank officer in the '90's. I was always told it was similar to one of our modern planned cities here in Australia (Canberra). I wasn't disappointed.
Maybe it was seasonal. From memory , I was there in september.
I would have been a very nervous flier with that much static. What range do you reckon you got?? J
jayb1rdz is offline Find More Posts by jayb1rdz
Old May 24, 2011, 03:15 AM
toeickris is offline
Find More Posts by toeickris
korea
Joined Jun 2010
queston for landing wheel
hello,
want to hear your opinions about landing wheel to skywalker...
will the landing wheel be a protection to the camera equipment when landing?
if not, I don't c the need to attach the landing gear...
toeickris is offline Find More Posts by toeickris
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
