Old May 09, 2011, 08:25 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
I have noticed that the 4 Rubber bands included are not enough to hold the wings very securely.
I held the belly of the SkyWalker and wiggled it back and forth (side to side),,,,, I can see that the wings on the fuselage shoulder is rocking back and forth.
...I need more Rubber bands to hold the wings in place.
Where are you guys buying the same exact/or better Rubber bands? Links?
LexusFPV is offline Find More Posts by LexusFPV
Old May 09, 2011, 08:27 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
Or better yet (in my opinion): has anyone done a nylon bolt mod to screw down the wings? I'm sure that someone has, or that this is a viable option. Any examples?
pdiddyg40 is offline Find More Posts by pdiddyg40
Old May 09, 2011, 08:53 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
The 4 rubber bands have held up to everything I've thrown at em.
Loops, rolls, hard landings. The idea is you want them to hold with flight loads
and pop off if you crash, instead of breaking the wing. They do both just as they are.
ian
Daemon is online now Find More Posts by Daemon
Old May 09, 2011, 09:23 PM
IL76MD is offline
Find More Posts by IL76MD
fly it high as possible
Falls Church, VA
Joined Jun 2009
The question is Where to buy them? I really do not know and would like to buy it, too. My rubber bands are already too old.
Who knows?
IL76MD is offline Find More Posts by IL76MD
Old May 09, 2011, 09:25 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Originally Posted by cmanley_nl View Post
I am and I'm using toroids near the tail servos just in case. About 1 page ago I asked the same question about the glue because I have the same twist problem so you can read those answers.
Let me know what you end up doing! Thanks!
And, Anyone know if the DL affects servos? Thanks! -Tyler
flyboy321 is offline Find More Posts by flyboy321
Old May 09, 2011, 09:53 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
daemon
I just noticed that when I hold the underbelly and wiggle side to side, and I look at where the wings sit on the fuselage shoulder...the rocking back and forth causes the wings to separate from the fuselage just a bit..... I'll be more confident if I had 2 extra rubber bands, and still functions as "breaking off" during a crash.
also, where would I find these exact/or better Rubbers bands to hold our wings down?
I may loose some on the way to the field and having extras' to be safe :-)
rclab1 is offline Find More Posts by rclab1
Old May 09, 2011, 09:58 PM
rclab1 is offline
USA
Joined May 2010
found them....Rubber Bands no.64 seems to be the best ones'.
http://www.rcgroups.com/forums/showp...postcount=5578
http://secure.hobbyzone.com/catalog/...h/HBZ4827.html
and
http://www.rcgroups.com/forums/showp...postcount=3368
any other Links would be helpful..... thank you
Old May 09, 2011, 10:03 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I inherrited some of Tim the Toolmans genes. I can't leave well enough alone, even when simple works better.
I have started a nylon bolt mod. It remains unfitted at this stage . The mod is easy, ply braces glued to the CF rods with blind nuts. Large nylon washes and ply plate imbedded in the top wing surface. It's easy but not any lighter. I cut the parts because I wanted to reduce unnecessary drag. I also have made a brace for E-flite retracts similar to F-16 mounting so the track is wider than the fuse when the gear is down. Again it si not fitted yet as I have had not time at home to work on it and having decent FPV is a higher priority than my streamlining mods. J
jayb1rdz is offline Find More Posts by jayb1rdz
Old May 10, 2011, 06:16 AM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Which prop for my motor ?
I'm about to get this Scorpion SII-3014-1040 motor, and I going to use a Turnigy Plush 60amp ESC with it. But would a prop like the APC 9x6E Pusher Prop be a good choice
SpookiePower is offline Find More Posts by SpookiePower
Old May 10, 2011, 06:25 AM
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Hey van, do you have the specs of your homemade mount from awhile ago?
I was looking for people who use DL and DOSD so I could get an idea of where to place everything and saw your mount and really liked it. -Tyler
Old May 10, 2011, 06:46 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Are you planning 3s or 4s?? Prop is good for 4s but I would go bigger prop if staying with 3. I expect the esc will be fine for 4s if it has decent cooling. J
Old May 10, 2011, 06:47 AM
Joined Jun 2009
I'm going to use 4s Lipo
Old May 10, 2011, 06:55 AM
Joined Jun 2009
How big a Lipo are you using ?
I have set my mind on a 4 s Lipo, but I' not sure how many mAh I should choice. Would 4s 5000 mAh give me about 30 minutes in the air ? I'm not going to fly WOT all the time, but just some easy flying around.
Old May 10, 2011, 08:41 AM
wac is offline
wac
Find More Posts by wac
wac
Joined Jun 2005
Hey Guys,
Sorry to ask such a knob question, but do i need to use a pusher prop on my skywalker?
Thank you
Bill
wac is offline Find More Posts by wac
Old May 10, 2011, 09:02 AM
iw28 is offline
Find More Posts by iw28
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
http://www.youtube.com/watch?v=AKMCFKs4Qy8 of my skywalker
rocket launch
and a bad landing
iw28 is offline Find More Posts by iw28
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
