Old May 08, 2011, 11:39 PM
Alpina540 is offline
Find More Posts by Alpina540
Fly Big, Low and Slow....
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
I agree, the missing canopy cant be helping.
Alpina540 is offline Find More Posts by Alpina540
Old May 08, 2011, 11:54 PM
PMRfly is offline
Find More Posts by PMRfly
Joined Mar 2011
yeah, i snapped my wing in relatively easy going flying (slight pull up... very very very very very slight pull up). I'm not happy about it. v3 does not look much better either (spar looks too close to the surface). they need full length spars. no point having a plane that is designed to carry so much without a properly supported wing.
And as for them saying its not designed to carry so much.. that's the market they are targeting, thats the main and probably only reason why we buy the skywalker!! that sort of comment will just turn people away ;-)
Originally Posted by danvegas View Post
be carefull on newest skywalker...my wing broke off at the ends of rods in wings ....this while flying straight at hald throttle and only had a digital camera on board...manufacture said it must of been from a steep climb!! as well as it will not handle over 1.8kg anyway had this happen to a friend fpv shywalker too...if its not meant to put a few grams in it why the space? anyone want to see their responce will be more then happy to forward it along with pictures of plane...buyers beware!!!!!
PMRfly is offline Find More Posts by PMRfly
Reply With Quote  (Disabled)
Old May 09, 2011, 12:19 AM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
I have a V3 under construction. I cannot compare it to earlier versions as I am a newbie to FPV. The V3 wing looks up to the task if, in my case the simple procedure is followed.
I always reinforce the LE with cross weave fibretape on every foamie. I do if more to ensure that this critcal part of the airfoil stays unspoiled for as long as possible. The fiber tape does go deteriorate after a while so I ususally over cover that with trim tape which also aids orientation. There appears to be enough CF to keep it well together although as a precaution I intend to add some cf ribbon out to the tips.
BTW thanks for the warnings.
Hopefully a flight report in a couple of weeks.
IMO you could but the V3 with confidence. No comment on previous versions.
jayb1rdz is offline Find More Posts by jayb1rdz
Old May 09, 2011, 12:25 AM
jayb1rdz is offline
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Dumb newbie question.
I lack experience with flight aids like gyros and auto pilots etc. However, I do want to fit the FY 21 AP to give me an additional safety net given our aussie RX/TX limitations. I will have decent DMGs all round.
Will the model be more stable if I set the model TX with expo or should I just let the AP do its own thing and manage the gain??
J
Old May 09, 2011, 04:14 AM
cmanley_nl is offline
Find More Posts by cmanley_nl
Unregistered User
cmanley_nl's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by flyboy321 View Post
Are you guys feeding you elevator and rudder extensions through the cf boom?
And if I have some tail twist, will 30 min epoxy and just holding it where I want keep it in the right place after it dries?
-Tyler
I am and I'm using toroids near the tail servos just in case. About 1 page ago I asked the same question about the glue because I have the same twist problem so you can read those answers.
cmanley_nl is offline Find More Posts by cmanley_nl
Old May 09, 2011, 04:43 AM
npole is offline
Find More Posts by npole
Joined Apr 2009
be carefull on newest skywalker...my wing broke off at the ends of rods in wings....
More details please, you managed to broke a V3 wing? When you say the "newest" you mean the latest? The one with the third carbon tube embed into the wing? If yes, please respond to this, it would help all us:
- You were leveled flight (or doing "normal" manouvers)?
- Where exactly the broke happened on the wing, where the two rods finishes, or where the third rod finishes (do you have a picture)?
- Did you glued the rods into the wings (one piece wing)?
Thanks.
(if it wasn't the V3 .. nevermind about the questions, we know unfortunately)
Edit: this is your third message about your broken SW (from May 4th), and we asked already about if you owned the v3 or not, but u never gave details... not to doubt about your words, but we need to know for sure, it would "save" us .. eventually. Thanks.
npole is offline Find More Posts by npole
Old May 09, 2011, 05:05 AM
UndCon is offline
Find More Posts by UndCon
UAV Pilot
UndCon's Avatar
sweden
Joined May 2007
-Tyler
I feed them thru the CF - works great for me with no toroids on tail.
I used supplied glue - generously spread over all surfaces - still some twist but that is due to EPP nature - not the glue itself.
//UndCon
UndCon is offline Find More Posts by UndCon
Old May 09, 2011, 05:53 AM
PMRfly is offline
Joined Mar 2011
i live in panania, sydney, did some minor expo dialled in on turnigy 9x with bevrc long range. had to tune fy21ap to ensure direction matched intention on rth, but did not pull it back too much from top tune and it seems to work well.
have not had an issue with fy21ap yet.. (fingers crossed!)
p.s. pm me, where you flying?
J
Old May 09, 2011, 11:07 AM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
First of all, sorry for a mistaken input!
I did NOT use a EasyStar motor!!!
I use the motor that did follow the Skywalker Combo + prop !
I also checked the cog, and it`s exactly ON the servo wires on the wing.
Will try to move it 3cm back (as recommended here)
I think that will be tail-heavy ?? but I will try it anyway.
Let you know how it goes later today
Thanx again..
liteglow is offline Find More Posts by liteglow
Old May 09, 2011, 11:17 AM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Originally Posted by liteglow View Post
...Will try to move it 3cm back (as recommended here)
Thanx again..
Don't forget to reduce your elevator throws.
kendall
tuppertn is offline Find More Posts by tuppertn
Old May 09, 2011, 12:05 PM
borneobear is offline
Find More Posts by borneobear
Oopss. Oh well.
borneobear's Avatar
In the tropics
Joined Jan 2006
IMHO, foam wings MUST be reinforced with fibretape to prevent breakage.
The carbon rods only prevents wing flexing, not breakage of the foam structure in case of high G force (acting downwards).
Foam is excellent to counter compression, but has very little structure to prevent separation (breakage).
Regardless if you are flying above or below the recommended 1.8 kg flying weight, reinforcing the wings with fibre-tape is a must!
borneobear is offline Find More Posts by borneobear
Old May 09, 2011, 12:35 PM
npole is offline
Joined Apr 2009
Better.. but WICH motor? ...name? Model? KV ? Watt?
Don't move it so much initially, move it just 1cm. back .. and try, then 2cm. and see if it's getting better. SW isn't that sensible to a wrong CG but a very tail heavy airplane would be hard to control and we won't have a crash.
Old May 09, 2011, 12:44 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
30mm behind the servo wire slot does not make the SW "a very tail heavy airplane". Many of us are running that far back, and sometimes more, without issue.
Running the CG *at* the servo wire slot, makes the SW a "very nose heavy airplane" and performance suffers accordingly.
ian
Daemon is online now Find More Posts by Daemon
Old May 09, 2011, 08:39 PM
Avenger GBU-1H is offline
Find More Posts by Avenger GBU-1H
Avenger GBU-1H's Avatar
Acworth, GA
Joined Mar 2007
Skywalker "Belly Sheild"
Friends,
I am about to start building my 2nd skywalker. I recall seeing somewhere that someone was making "belly sheilds". Can someone direct me to a website that carries these?
TIA to all.
Avenger GBU-1H is offline Find More Posts by Avenger GBU-1H
Old May 09, 2011, 08:55 PM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
Originally Posted by Avenger GBU-1H View Post
Friends,
TIA to all.
http://www.bevrc.com/bevgf-protect-k...ker-p-209.html
they've been out every other time I checked so get it now if you want it.
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
