Old Apr 08, 2011, 11:54 PM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Originally Posted by npole View Post
Is it the NEW version (actually Version III) with the additional carbon rods into the wings?
Looks like it is
http://www.readymaderc.com/store/ind...roducts_id=438
billyd60 is offline Find More Posts by billyd60
Old Apr 09, 2011, 03:18 AM
Ramnes is offline
Find More Posts by Ramnes
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
Originally Posted by Ramnes View Post
venquessa:
I'm looking for a 4S motor. The TGY ones dont say how many cells one can use on them.
Is one of this the motor you tested?
TR 35-36B 1300kv Brushless Outrunner (Eq:2814)
NTM Series 35-36B 1400Kv / 495W
Jorn
Originally Posted by venquessa View Post
The Turnigy, didn't realise you were looking 4S sorry.
Hi again
I've been looking around trying to find a motor that runs on Turnigy Nano-Tech 4S 5000Mah 25-50C but have no luck at HK, so i now thinking of going down to Turnigy Nano-Tech 3S 25-50C 50000Mah instead and use the motor you recommend. If i can get around 30 minutes per battery of flight i think thats more than enough for me.
I've tried to use calculators on different websites to calculate the difference between them, but i'm not shure if i understand them.
I'm not very technical when it comes to this kind of electronics, but i'll be there one day.
Jorn
Ramnes is offline Find More Posts by Ramnes
Old Apr 09, 2011, 04:34 AM
venquessa is offline
Find More Posts by venquessa
UK, North Down, Bangor
Joined Nov 2009
Interestingly (maybe?), I was using a Turnigy 3S 25-30C 5000mAh pack and had my timers at the end of the testing flights say:
Flight time: 21:50 (This is time with the throttle safety switch off)
Motor Time: 13:12 (This is non-idle time)
Pack read 38% on the LiPo tester and took 3500mAh to charge.
Bear in mind the "Flight time:" timer includes ground time when I forgot to switch the safety switch on.
This was line of sight, so lots of fast low passes and climb outs.
venquessa is offline Find More Posts by venquessa
Old Apr 09, 2011, 04:58 AM
Ramnes is offline
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
That seem to be more like what i have in mind regarding flighttime, i will buy two batteries and since i'm kind of new to FPV i'm not going to do the big stunts in a while, but low passes is interesting. What do you mean by "throttle safety switch off"?
Jorn
Old Apr 09, 2011, 08:49 AM
npole is offline
Find More Posts by npole
Joined Apr 2009
Originally Posted by Targetlocman View Post
Where did you read it?
npole is offline Find More Posts by npole
Old Apr 09, 2011, 11:36 AM
Alpina540 is offline
Find More Posts by Alpina540
Fly Big, Low and Slow....
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
He must think you can tell what version by looking, but you need to see the bottom of thw wing to tell if its V3
Alpina540 is offline Find More Posts by Alpina540
Old Apr 09, 2011, 12:36 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Had the SW at the club field this morning. I think every member in attendance got a "ride" along through the Headplays. Universally cool experience.
Most commonly asked question: "So how much did all this cost?"
kendall
tuppertn is offline Find More Posts by tuppertn
Old Apr 09, 2011, 01:10 PM
billyd60 is offline
Joined Mar 2006
I was going by the number of carbon rods provided, but you're right I was guessing, which is why I said "looks".
Old Apr 09, 2011, 01:12 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
V3 has two more carbon rods pre-installed inside the wing. The ones in the picture
are for joiners and fuse longeron.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 09, 2011, 02:02 PM
perfeet is offline
Find More Posts by perfeet
Internal Paradigm Consultant
perfeet's Avatar
Joined Dec 2009
Originally Posted by pshimm View Post
I just drilled a hole in my mount right into the foam to accomodate the shaft. Others have cut the shaft with a dremmel or bolt cutter--I don't see the need.
I don't know of anyone selling skywalker motor mounts, but it's pretty easy to make if you have a scroll saw or band saw and some plywood. Place the blind tee nuts--then just glue it to the suppplied mount and glue it to the plane.
I understand now. Thanks!!!
perfeet is offline Find More Posts by perfeet
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Quick question.
I just got the new 5000 Mah batteries from HK and the wires are just horrendously thick.
What kind of plugs I could use?
nakelp86 is offline Find More Posts by nakelp86
Old Apr 09, 2011, 02:08 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
Originally Posted by nakelp86 View Post
Quick question.
I use EC5 plugs on packs with 10AWG or larger leads.
kendall
Old Apr 09, 2011, 02:16 PM
perfeet is offline
perfeet's Avatar
Joined Dec 2009
God kveld.
Are you going to buy a new motor for your abit heavy FPV plane mister? I'm also looking for a motor and was going to go for the stock one, but i want one that have at least 1,6kg of thrust. Of course without increasing the propsize.
Folks here seems to have Scorpion motors.
Jorn
The reason I am changing motors is that the BEVRC-motor has a vibration in it . It is pretty strong motor, but a no do with FY20A.
I want a better quality motor.
Ordered Scorpion S2-3014-1040 motor and a APC 10x5E propeller (will raise my motor mount some). That should give the plane good and smooth power.
Old Apr 09, 2011, 02:52 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Thx Kendall
Old Apr 09, 2011, 02:56 PM
rclab1 is online now
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
perfeet
when you make that motor mount, post pics....
I have that same motor (3014-1040kv Scoprion) but I use
a 9x6 APCe prop..... that 10x5 prop will be nicer :-)
I'm using 4s 5000mah Lipo
http://innov8tivedesigns.com/Scorpio...40%20Specs.htm
it will go just a bit faster
rclab1 is online now Find More Posts by rclab1
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
