Old Apr 04, 2011, 06:46 PM
Mikey636 is offline
Find More Posts by Mikey636
Mikey636's Avatar
United States, VA, Charlottesville
Joined Dec 2010
I have my ESC (Moxie 80A professional series) in the under wing compartment and it operates without any issues. I also made a small intake duct:
Mikey636 is offline Find More Posts by Mikey636
Old Apr 04, 2011, 07:03 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
I have my VidTx out on the Wings and the "Mic" is in the
VidTx itself.... what are you guys using to cover up that built in Mic?
The Wind Noise is crazy loud....
Can I use HotGlue or Some sort of Silicon..... anyone have any ideas for me?
I can't use foam on the VidTx itself because it will melt it
Thank You
p.s. VidTx is from HobbyWireless
LexusFPV is offline Find More Posts by LexusFPV
Old Apr 04, 2011, 08:02 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
Thank You
The white wire is the audio lead. Cutting it will halt the audio to a lawmate xmitter. I use a EZOsd and the right audio out is attached to the white wire not to the board but to the xmitter on the backside for tracking and telemetry.
The packet audio telemetry is nearly 100%.
I have a small 12 volt fan that is mounted near the xmitter. If it lands somewhere remote I want to assure the vid Tx stays cool.
Take care
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Apr 04, 2011, 08:11 PM
pdiddyg40 is offline
Find More Posts by pdiddyg40
Flying low is expensive.
pdiddyg40's Avatar
United States, CO, Boulder
Joined Jul 2008
If you're worried about the VTx melting foam, I certainly wouldn't use hot glue! It would just melt that too!
pdiddyg40 is offline Find More Posts by pdiddyg40
Old Apr 04, 2011, 09:08 PM
Mikey636 is offline
Mikey636's Avatar
Joined Dec 2010
Well, apparently I just jinxed myself:
Was out flying this evening and while making a full throttle pass, the ESC shutoff and the plane nose dived. The weird part is, the throttle cut out and then a split second later it dove straight down as if the elevator was full stick forward. It's weird because I have a 5A UBEC powering the servos and receiver.. so the ESC cutting out shouldn't effect the servos?
oh well, the damage wasn't too bad. Should be able to repair it.
Old Apr 04, 2011, 10:55 PM
hornant is offline
Find More Posts by hornant
Back in Hong Kong
Joined Sep 2003
That sounds more like a radio going into failsafe with the elevator not set correctly dont you think ?
hornant is offline Find More Posts by hornant
Old Apr 05, 2011, 12:22 AM
Alpina540 is offline
Find More Posts by Alpina540
Fly Big, Low and Slow....
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
+1 ^^
Probably because of the close proximity of your 80 amp esc to the receiver antenna.
ESC's make lots of switching noise.
Sorry to see your plane smashed....
Alpina540 is offline Find More Posts by Alpina540
Old Apr 05, 2011, 02:13 AM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by EugeneFlorida View Post
What motor are you using?
thanks for the help
I use a 3642 1200KV
rcmonster99 is online now Find More Posts by rcmonster99
Old Apr 05, 2011, 07:20 AM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Oh man - that didn't take you long to trash. Gutted for you...
This is how I fixed mine after the first one failed in teh compartment....
Shave off small bit of foam under teh motor to create a flate, cyano'd the surface, then velcro'd theESC on and to be sure use a cable tie.
The only thing I wish I had done was to fit a small tube for the tie to go through so it doesn't pull on teh foam. I'll probably retrofit that.
Shikra is offline Find More Posts by Shikra
Old Apr 05, 2011, 10:18 AM
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
But we don't think the problem was heat related the RX more than likely went into fail safe.
Old Apr 05, 2011, 12:44 PM
Ramnes is offline
Find More Posts by Ramnes
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
This is what i'm going to build.
Hi. I'm planning on building a Skywalker and thought i would share what i have found to be a good setup for this FPV plane. I've choosen this parts based on what i've read here and advice from friends flying this FPV plane today. Since i can't buy it all together i have to buy over a few months. I have a quadcopter today which is going to fly as a FPV quad when the parts needed for it arrives. This month i plan to buy the following:
April:
BEV-KX181H-PAL Camera 82
BEV 1.3G 800mW 74,99
BEV-2.8mm board lens 9,99
CE OSD V1.3(Newest) 92,99
BEV-GF protect kit 21,99
Total $281,96
May:
Fatshark RCV922 BASE Edition $275
June:
BEV-FY-20A II Flight Stabilization System
Skywalker 168cm EPO airplane Version II
80A brushless ESC Turnigy Plush(I have this already)
HXT900 9g / 1.6kg / .12sec Micro Servo
TR 35-36A 1450kv Brushless Outrunner (Eq:2814)
Turnigy nano-tech 5000mah 4S 25~50C Lipo Pack x2
Turnigy nano-tech 1600mah 2S 25~50C Lipo Pack x1
Chainlink (433MHz for video)
Total $541,77
Total $1348,73 with the Ardupilot Mega($250)
Im not shure what kind of controller i want for this project, but i need advice on IkarusOSD($130) vs Ardupilot Mega($250) and maybe others.
My Tx is a DX7. I'm planning on buying a Turnigy 9x.
Jorn
Ramnes is offline Find More Posts by Ramnes
Old Apr 05, 2011, 01:03 PM
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
eewww don't add it up like that.... its depressing lol
Old Apr 05, 2011, 01:35 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
That's a lot of stuff.
How about this:
1) Buy the plane, motor, ESC, servos and battery. Then go fly it.
2) Add a VTx and camera. Then go fly it.
3) Add an OSD. Then go fly it.
4) Add autopilot, stabilization and various must-have doo-dads late this summer.
It'll still take months to accumulate the gear, but it'll make a whole lot more sense once it's finally all in the air.
Now, if you'll excuse me, I'm going to go run a marathon. Training? Bah! How hard can it be?
kendall
tuppertn is offline Find More Posts by tuppertn
Old Apr 05, 2011, 01:43 PM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
I bought the DOSD a couple weeks ago and realized I shouldn't install it for at least a few more weeks until I'm certain everything else is in order! You can buy all that now, but you'll probably end up not using it immediately (and you probably shouldn't). Wouldn't want to lose all that cash just because you rushed things.
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Apr 05, 2011, 01:47 PM
Ramnes is offline
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
I know, the most expensive project so far, but with it i plan to fly in the high Norwegian mountains with a GoPro HD.
How about this:
kendall
Kendall
Nice plan, like you i also do some other things beside flying, i train a few days a week and i play golf. Therefore i've planned it a few months ahead.
Jorn
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
