Old Apr 03, 2011, 05:50 PM
Shikra is offline
Find More Posts by Shikra
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
I see some of you guys put their ESC under the wing - well I did that too, but it failed after a few flights. I don't know if it was heat related or just a general fault.
Luckily I was close in and use a seperate BEC so could glide back OK.
Didn't fancy risking another under the wing without knowing the temperature in there.
Shikra is offline Find More Posts by Shikra
Old Apr 03, 2011, 06:25 PM
VaZ is offline
VaZ
Find More Posts by VaZ
VaZ
TheFlyer_PT
VaZ's Avatar
Portugal
Joined Feb 2011
Originally Posted by electricmick View Post
The switch positions depend upon how you have mounted the sensor block + or x relative to the fuselage. However, the trick with the CP4 is to follow the instructions very carefully. They are not well written and not laid out to easily read on a screen, more logical if you have them printed out.
1) Set up the CP4 precisely as per the instructions
2) If possible have the sensitivity going to a trim on your radio.
3) Trim the SW for straight and level, hands off the controls at cruising speed with the CP4 turned right down. Land and check all control surfaces are neutral, if not then different issue.
4) Set CP4 sensitivity to maximum, perform the pre-flight check as per instructions
5) Check that servos move in the correct directions when tilting the SW
6) Check that when you hold the the SW in the straight and level flight attitude the control surfaces are neutral.
7) turn down the sensitivity to low-position i.e. stabilisation off
8) launch SW and achieve straight and level flight at cruise power and then slowly increase sensitivity. SW should stay S&L, if not then above not carried out correctly.
Hope this helps, good luck.
Will do so. Thanks for the info
VaZ is offline Find More Posts by VaZ
Old Apr 03, 2011, 07:56 PM
wtl0715 is offline
Find More Posts by wtl0715
United States, CA, Marin County
Joined Apr 2009
Originally Posted by rcmonster99 View Post
I see the ESC is under the wing.
1) the toroid might foul against the wing base
2) it has been acknowledged that this is not the best place for the ESC as it will overheat, either install cooling vents or install the ESC outside, for example, right under the motor
The toroid wasn't an issue with the wing base, but the ESC heat is a good point. Unfortunately, that isn't a problem I'll have the opportunity to solve. I set the CG at 75mm behind leading edge, but it flew like it was a little tail heavy, so I brought it around to land. The right wing folded on the way down, less than 30 seconds in. Of course, it folded near the end of the wing spar.
I read where a few people said that extra wing reinforcement isn't necessary with the new EPO version, so I chose to use stock wings. Big mistake!
The plane could probably be salvaged, but I hesitate to spend more time and money knowing that another part of it may fold. I think I'll just wait for the Ritewing I ordered a couple of weeks ago.
-TL
wtl0715 is offline Find More Posts by wtl0715
Old Apr 03, 2011, 09:21 PM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
-TL
Sorry to see that, but if the plane is flown within a conservative flight envelope as I do, there is not a problem with the stock wing. I have made no modifications and have over 30 flight hours on my plane. Maybe I'm just lucky, but who knows.
rsowder is offline Find More Posts by rsowder
Old Apr 03, 2011, 09:32 PM
wtl0715 is offline
Joined Apr 2009
I'm not sure what I did wrong. I flew for less than 20 seconds - definitely didn't get crazy with it. I was trying to get it back down because it felt a bit tail heavy. I'm not sure how fast I was moving, but it wasn't anything over the top.
if I decide to rebuild, I guess I'll have to use a CF rod along the top of the wing from the end of the stock spars to the end of the wings. I'll search for a mod and see how others have done it.
-TL
Old Apr 03, 2011, 09:36 PM
rsowder is offline
rsowder's Avatar
San Francisco
Joined May 2009
-TL
Ii see that BEVRC just came out with a new wing that has the CF extend well beyond the current design. You might just buy the new wing if the fuselage is ok.
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
wtl0715
Ross is selling these SkyWalkers now and you he has parts....
He can make this SkyWalker anyway you like also....
Great Guy knows his stuff.
www.Visual-rc.com
http://www.visual-rc.com/node/165
rclab1 is offline Find More Posts by rclab1
Old Apr 03, 2011, 10:20 PM
wtl0715 is offline
Joined Apr 2009
I think that I may be able to rebuild mine (if I decide to give SW another chance). If not, I'll definitely get in touch with Ross.
Old Apr 04, 2011, 04:19 AM
rcimports is offline
Find More Posts by rcimports
South Africa
Joined Oct 2005
What is the concensus on putting the esc in the cabin?
People like Crist Rigotti flies with the ESC in the top bay without any issues whatsoever, is it not a matter of to small esc if you are overheating? I'm planning a 920Kv, 9x6 and 60Amp Turnigy plush, should me more than able to handle and not overheat?
rcimports is offline Find More Posts by rcimports
Old Apr 04, 2011, 05:29 AM
hornant is offline
Find More Posts by hornant
Back in Hong Kong
Joined Sep 2003
I have got mine in the fuse under the wing and it runs stone cold...but I do have scoop intakes on both sides and I enlarged the hole that goes down at the back of this compartment to help with getting good air flow. ESC out in the air flow also works well and is easy to do but I just dont like how it looks. What ever you do you need to test that it works with your setup. Remembering that these aircraft will be having long constant engine runs. I am fitting a temp gauge(eagle tree) to mine on my SW because of the flight times I am hoping to acheive when I get my DL tx. Going bigger alone on the ESC is not always enough. Bigger is better but aircooling is a must to keep it reliable. There are enough things that can go wrong with FPV without having to worry about an ESC thermal cutout.
ps...love the SW for FPV.
hornant is offline Find More Posts by hornant
Old Apr 04, 2011, 08:35 AM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
I have my ICE50 under the wing without problems. I don't have anything in the servo cutout on top of the fuse so I cut a cooling hole through that area into the top compartment. The ICE50 also has a big heatsink on it already which I'm sure helps a bit.
kendall
tuppertn is offline Find More Posts by tuppertn
Old Apr 04, 2011, 08:43 AM
South Africa
Joined Oct 2005
Cool, thanks for the replies, I'll be putting my Eagletree temp on it as well and see how it goes,
Cheers
D
w7mag is offline
Find More Posts by w7mag
CQ CQ DX RC
w7mag's Avatar
Pahrump, NV
Joined Nov 2008
I placed mine outside alongside the fuse due to summer time temps out here get ridiculously hot. I can't see it getting enough airflow (at least in my case) in the under wing location.
w7mag is offline Find More Posts by w7mag
Old Apr 04, 2011, 09:08 AM
Shikra is offline
SILURIA / UK
Shikra's Avatar
United Kingdom
Joined Jun 2009
Thanks for the feedback.
Maybe I was just unlucky with a dodgy ESC. I went for a 70A one too - thinking that would help.
I've just fitted mine underneath the motor, in front of the prop.
I shaved off a bit of the fuselage to make a flat, cyano's it then velcro'd it in place. To be sure I wrapped a cable tie around it and through the fusaelage.
Not going to have any airflow issues there! It looks quite tidy too.
And as a bonus, that bay is perfect for my IMU and a few other bits
Old Apr 04, 2011, 09:29 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Like Crist said, I guess different setups will produce different results. the same happened to me as shikra... on the maiden flight the ESC overheated and shut down. I had no UBEC and mine ended up in a spiral dive nose first on the ground from about 100m height.
Fortunatele I got only a crumpled nose out of this. I tried prizing off the ESC from the compartment, it was stuck to the foam by being melted into it.
I had a 40A speed controller and my motor does not burn more han 35A WOT .
In hindsight I should perhaps have a 60A speed controller, but the one I have now (another 40A) lives outdoors and it is cool as a cucumber at all times
so, from personal experience I will keep it out...
My GPS sensor lives inside the wing housing compartment.
rcmonster99 is offline Find More Posts by rcmonster99
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 04:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 11:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 10:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 12:45 PM
