Espritmodel.com Heli Air
Old Mar 26, 2011, 01:08 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Originally Posted by rcmonster99 View Post
Hooks.. I see you extended the elevator surface...any reason why ? did you have the chance to fly it like that ? how do you like the modification?
For whatever it's worth, this plane does not need a larger elevator surface at all.
On my SW with the CG back 30mm or so, using the stock foam elevator, I'm running a
total of +/-5mm throw and my SW is quite lively in the turns. If the surface were made
bigger, the throws would have to be even smaller, and eventually you lose servo
resolution.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 26, 2011, 01:13 PM
electricmick's Avatar
United Kingdom, England, Castle Donington
Joined Aug 2010
Finally got the glue out and started to put together my Skywalker FPV ship. I have followed many tips from this thread so thank you to everybody who has posted them. I strengthened each wing with a 300 x 4.5 x 1.4mm carbon strip from between the two main spars out to well beyond the aileron servo. I put these in with medium foam safe CA and then sprayed the kicker, this worked well.
I opened out the channel for the Vtx cable and added a large diameter carbon tube so I can feed cables through this later or change the configuration at any time. I found the tube in my box of junk, for those eagle eyed it is the remains of a carbon tail boom from a TRex 450 that ended it life some time ago, doing the funky chicken.
The rest is as per this thread. The glue is drying on the fuselage as I type. I noticed that when I put the sides together using the supplied glue it was easy to take any twist out of the tail relative to the fuselage by over-twisting then it relaxed to the right place. This would not have been so easy with CA or contact adhesive.
So far so good.
electricmick is offline Find More Posts by electricmick
Old Mar 26, 2011, 01:58 PM
Fly Big, Low and Slow....
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
Originally Posted by Daemon View Post
For whatever it's worth, this plane does need a larger elevator surface at all.
resolution.
ian
He means doesn't need a larger elevator.....
Alpina540 is offline Find More Posts by Alpina540
Old Mar 27, 2011, 12:30 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, that's what I meant..
ian
Latest blog entry: My 2012 FPV year in Review
Old Mar 27, 2011, 03:33 AM
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
ian
I am in agreement, I just wondered what was the thought behind the modification....
rcmonster99 is offline Find More Posts by rcmonster99
Latest blog entry: Airframes
Old Mar 27, 2011, 05:46 AM
Hooks's Avatar
Joined Jun 2009
Hehe I got my reasons. :-)
Hooks is offline Find More Posts by Hooks
Old Mar 27, 2011, 08:44 AM
UK, North Down, Bangor
Joined Nov 2009
Well I finally glued my fuselage together this morning. The maiden won't be that long away now!
How do you guys mount the motor to the foam? Epoxy?
venquessa is offline Find More Posts by venquessa
Old Mar 27, 2011, 11:35 AM
Joined Mar 2006
Motor mount on Skywalker
http://www.rcgroups.com/forums/showt...0#post17083888
scrape is offline Find More Posts by scrape
Old Mar 27, 2011, 12:14 PM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
I also copied Scrape's idea. very strong.
Derek_S is offline Find More Posts by Derek_S
Old Mar 27, 2011, 01:06 PM
Joined Mar 2006
Old Mar 28, 2011, 09:28 AM
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
ok just fully converted my SW from 910mhz to 1280...can't wait to get it out to try it out.
Just a thought...I am considering changing my VTx/VRx's to horizontal polarization because I was just thinking...all RF interference is mostly vertical polarization...think about all the antennas you see on buildings, towers, hills, wifi routers, cell towers...ALL VERTICAL!
AdamChicago is offline Find More Posts by AdamChicago
Old Mar 28, 2011, 09:46 AM
CQ CQ DX RC
w7mag's Avatar
Pahrump, NV
Joined Nov 2008
Hmmmm...
w7mag is offline Find More Posts by w7mag
Old Mar 28, 2011, 10:16 AM
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
Yeah but you will eventually fly in two one of the two nulls of you antenna on the plane or on the ground.
Old Mar 28, 2011, 04:40 PM
Joined Nov 2009
A tip.
During building, when you glue the fuselage together. DO NOT leave the canopy bolt in after the test fit.
I left mine over night and the bolt is completely, solidly glued in! Had the cut round the ply block to get it off.
I had intended on putting a wing elastic or velcro strap round it anyway, what with go pro on it and all. So not a biggy.
Old Mar 29, 2011, 03:10 AM
Joined Mar 2011
Originally Posted by tuppertn View Post
Just clicked "Buy It Now" on an Aiptek DV5800CB.
I also just bought my SW a new Pixim Seawolf camera.
kendall
I am interested in pixim camera too.
I guess you have not receive your pixim camera, right?
That is great if you can share your camera test result.
superjunio is offline Find More Posts by superjunio
Question Best plane for FPV while on vacation? patricklupo Video Piloting (FPV/RPV) 23 Aug 08, 2010 06:27 AM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC Video Piloting (FPV/RPV) 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
