Old Mar 20, 2011, 12:06 PM
scrape is offline
Find More Posts by scrape
Joined Mar 2006
Originally Posted by flyboy321 View Post
Does anyone not use the screw to hold down the foam canopy? Or at least know the size? Today I had an awesome flight but when I landed in the grass the screw popped out somehow. Any ideas? -Tyler
I used some fuel line on the screw to keep it attach to canopy.
scrape is offline Find More Posts by scrape
Old Mar 20, 2011, 12:11 PM
irri is online now
Find More Posts by irri
irri's Avatar
Australia, ACT, Canberra
Joined Jul 2009
My worst crash till date, It hurts more when you have been working on a model for hours and it ends up like this on maiden
AUW was 1540 grams with a 5000 mah 4S and a 3S 1000mah used as weight to balance. it balanced at servo wire channel. Peak amp draw was 40 amps using a 9X6 APC E and 1000kv motor. hand launched at around 40 % throttle and it required very minor aileron trim. did 4 to 5 circuits and gave controls to a flying buddy and i went to grab camera from my car. when i returned i asked him to do a low pass and with in 5 seconds of that we had no rc link. it dived at a 70 degree angle from around 200-300 meters. i could hear the motor going full throttle and had no servo controls.
both 5000mah 4S and 3S 1000 mah batteries were destroyed.
metal gear servos have survived, both hxt900 have stripped gears.
no idea about the motor, esc and Rx yet. i don't feel like going to my rc workshop anytime soon.
wing has a bend at LE and some cracks at TE but i think its easily repairable.
two crack at horizontal stab.
vertical stab looked ok to me.
Fuselage broken from 3 points with entire nose ripped off.
But; i really enjoyed some first 4 mins of its flight, it flies awesome. glides good with zero throttle.
Lesson learnt; test your new electric setup on an old airframe first.
This was going to be my first FPV plane, had video link, DOSD v2 and TLRS UHF still in box which was planned to be installed next week.
PS: it wasnt an FPV maiden, i finished working on SW last nite and wanted to test how it flies before i put fpv equipment on it.
irri is online now Find More Posts by irri
Old Mar 20, 2011, 12:24 PM
scrape is offline
Joined Mar 2006
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
OHH CRAP, Sorry man, hope most electronics are still good.
nakelp86 is offline Find More Posts by nakelp86
Old Mar 20, 2011, 12:26 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
sorry about the crash....
what happened to your RC control? I see that you are using
2.4ghz for RC control.... what do you think happened?
rclab1 is offline Find More Posts by rclab1
Old Mar 20, 2011, 12:29 PM
flyboy321 is offline
Find More Posts by flyboy321
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Originally Posted by Mikey636 View Post
not working for me. Do you have an IP address? or another fix?
Same here! I'll try it later and see if the update fixes it.
flyboy321 is offline Find More Posts by flyboy321
Old Mar 20, 2011, 12:31 PM
irri is online now
irri's Avatar
Joined Jul 2009
lockout/ Brownout may be.
it had a new esc, new battery. an old Rx flown dozens of times before.
i never experienced any lock out in one year of my rc flying experience.
could be bad factory solder joints.
Old Mar 20, 2011, 12:32 PM
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
Scrape, good idea! -Tyler
Old Mar 20, 2011, 12:45 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
Originally Posted by rclab1 View Post
s
BAD IDEA, sorry dude again:-(
Old Mar 20, 2011, 12:55 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
He was flying it visually, so it'd be hard to blame previously working 2.4Ghz RC gear for this one.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 20, 2011, 01:06 PM
nakelp86 is offline
Nakelp
nakelp86's Avatar
Joined Sep 2004
then wonder what the hell happened? bad servos?
Old Mar 20, 2011, 01:09 PM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
I'm guessing the BEC was inadequate.
rsowder is offline Find More Posts by rsowder
Old Mar 20, 2011, 01:15 PM
irri is online now
irri's Avatar
Joined Jul 2009
Guys
can it be brought back to life? has anyone experienced a similar crash and repaired it/?
what concerns me is the heavily glued spar in the boom.
none of the servos were responding and motor was at full throtle, i am sure spektrum had something to do with it.
Old Mar 20, 2011, 01:17 PM
RC = FUN
Fort Wayne, Indiana
Joined Aug 2008
New airframe is only $100. That's probably worth it...
Old Mar 20, 2011, 01:54 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
A Spektrum-style brownout will turn the motor off. It may depend on your ESC, but with my DX7 and Turnigy (actually the old OEMRC) 40A, no signal from the receiver results in servos stuck in last position and motor off. I just reproduced the condition on my EZ* to be sure. The motor powers off about half a second after I pull the BEC power. If the motor was running I don't think it could have been a brownout.
Loss of signal would have resulted in a failsafe condition, ie--whatever postion the sticks were in when you bound the receiver. That's usually neutral sticks and motor off for most folks.
Based on this I can't think of a reason Spektrum would have caused a crash with the motor on. Perhaps the elevator servo/linkage failed as your buddy was headed for the deck for that low pass.
Back in the "old days" of 72MHz no one ever crashed their planes. It was always a radio glitch.
kendall
tuppertn is offline Find More Posts by tuppertn
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
