Old Apr 07, 2010, 01:40 PM
Fergus is offline
Find More Posts by Fergus
Fergus's Avatar
Ireland
Joined Apr 2005
Started work on the wing sections today. Sorry for the poor quality iPhone pics. I added a carbon strip to the leading edge which I buried within the foam. The strip is placed on its edge in a way which will prevent wing flex. Due to the dihedral in the wing it requires quiet a deep channel to get this in place but I hope it will significantly strengthen the wing along its length.
I also cut the flap servo recess and inserted the two supplied carbon rods in one half of the wing. The foam covers which slot over the tubes and hold them in place are slightly over-sized and had to be sanded back.
Some tidying up left to be done before joining the wing sections and glassing.
More soon.
Regards
Fergus
Fergus is offline Find More Posts by Fergus
Old Apr 07, 2010, 03:15 PM
bignose13 is offline
Find More Posts by bignose13
Yeah Baby
bignose13's Avatar
Joined Apr 2006
Fergus
Use a soldering iron with a self tapping screw in the end to make channels in the EPS, makes for a much neater job. Make sure you use with a metal ruler
Looks good so far btw
Simon
bignose13 is offline Find More Posts by bignose13
Old Apr 07, 2010, 03:24 PM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
Thats a good trick. Thanks Simon. I'll use that
Old Apr 07, 2010, 04:11 PM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Originally Posted by bignose13 View Post
Fergus
Simon
what do you mean by a self tapping screw in the end ? could you please elaborate ?
rcmonster99 is online now Find More Posts by rcmonster99
Old Apr 07, 2010, 04:15 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
one that's wider at the tip. "screw" that into your soldering iron so that the screw gets hot.
trappy is offline Find More Posts by trappy
Old Apr 07, 2010, 04:16 PM
Yeah Baby
bignose13's Avatar
Joined Apr 2006
Hope this helps
Simon
Old Apr 07, 2010, 05:47 PM
Houba ! Houba !!
Joined Sep 2003
Hope this helps
Simon
Aaaaah !!! Nice idea !!!!! not only you get a nice wide canal but you can also gauge the depth Ingenuous
This is my sodering station
and therefore cannot do it but I am sure I have one like that somewhere
Old Apr 08, 2010, 12:04 AM
Yeah Baby
bignose13's Avatar
Joined Apr 2006
No, you don't want to be using your best soldering iron for that job.
You can get a really neat job with it, not my idea though,
Simon
Old Apr 13, 2010, 08:15 AM
SPL is offline
SPL
Find More Posts by SPL
SPL
SPL's Avatar
Joined Aug 2008
I've order this plane today.
can someone recomend me engine?
SPL is offline Find More Posts by SPL
Old Apr 13, 2010, 08:24 AM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
Originally Posted by zaguruinzasky View Post
I'm not going to touch the rigidity of the airframe, rigidity transmits motor vibrations to the camera and I don't need it for the low speed of this airplane, for me the less rigid the better for quality filming in HD
forget it.. I'm going to touch the rigidity ahha.. now that I have it in my hands it's obvious that some modifications has to be done, even if you land soft all the times...
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Apr 13, 2010, 08:51 AM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
I've glassed a few foam planes, but wonder if solite might be the way to go on this one? I think glassing the inside with WPU is the way to go, but the outside covered in solite would give some good rigidity and durability on (grass anyway) with minimal weight gain. I don't have one in hand, but I bet some carbon and extreme tape reinforcing covered with solite would be a winning combination and look nice too.
I'm anxious to see what you guys come up with and how she flys.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Apr 13, 2010, 02:41 PM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
I've gone with stockings and WBPU on the wings. Just applied the first coat! Not sure how well it will work tho it's my first time trying this. Pics to folllow soon.
Regards
Fergus
Old Apr 15, 2010, 05:58 AM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
Wing covered with nylon stockings and WBPU. Light weight spackle to be applied next. Not much weight gain and the wing can now be flexed without snapping. Hopefully the wing will end up white again haha
Regards
Fergus
Old Apr 15, 2010, 08:32 AM
Houba ! Houba !!
Joined Sep 2003
You should have tried fishnet stockins
Old Apr 15, 2010, 04:21 PM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
Ok two coats of spakle and its white again. Phewwww haha
EDIT: It really is white the lighting and iPhone don't show it though!
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
