Old Apr 06, 2010, 03:38 PM
Fergus is offline
Find More Posts by Fergus
Fergus's Avatar
Ireland
Joined Apr 2005
I've started some work to strengthen the airframe.
First the internal cavity:
Layed up with fiberglass and WBPU
Ridge being cut for a carbon spar.
Regards
Fergus
Fergus is offline Find More Posts by Fergus
Old Apr 06, 2010, 04:28 PM
zaguruinzasky is offline
Find More Posts by zaguruinzasky
Smoke on , go !
zaguruinzasky's Avatar
Verona - Italy
Joined Jan 2007
I'm not going to touch the rigidity of the airframe, rigidity transmits motor vibrations to the camera and I don't need it for the low speed of this airplane, for me the less rigid the better for quality filming in HD
zaguruinzasky is offline Find More Posts by zaguruinzasky
Old Apr 06, 2010, 04:33 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Wow, you don't hang around. I'm sure that the cargo area has to be strengthened or else it will just smash to pieces on the first landing. I will probably build a liteply frame to go in there to give it some strength and put some 3M extreme tape on the outside.
lovegroove is offline Find More Posts by lovegroove
Old Apr 06, 2010, 04:39 PM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
First word of warning. THROW AWAY the supplied glue. It eats the foam as it cures.
I tried it on a scrap piece and thought ya it's fine. Then as it cured it ate the foam. Only noticed after I had used it on the spar. No major damage thankfully.
Regards
Fergus.
Old Apr 06, 2010, 04:46 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Looks like you're the guinea pig for this build. Hope you get it finished before mine arrives
Old Apr 06, 2010, 05:36 PM
wilsonj is offline
Find More Posts by wilsonj
Australia, SA, Waikerie
Joined Mar 2003
Wow, this all sounds a little disapointing! And I have one on the way too. Now not that the glue eating foam is a big problem, but REALLY? Why even bother putting it in the kit? It doesn't instill a great deal of confidence.
wilsonj is offline Find More Posts by wilsonj
Old Apr 06, 2010, 08:40 PM
kist2001 is offline
Find More Posts by kist2001
Senior Gravity Checker
Tampa, Florida
Joined Mar 2001
Would glassing the outside give you strength plus ding resistance?
What motor to use?
I was thinking to glass the outside....now I am thinking tape and solite covering.
kist2001 is offline Find More Posts by kist2001
Old Apr 06, 2010, 08:43 PM
aviatordave is offline
Find More Posts by aviatordave
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
So, instead of building to fly......we must build to crash.
aviatordave is offline Find More Posts by aviatordave
Old Apr 06, 2010, 11:30 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Absolutely. Full scale air and full scale fixed obstacles are hard on small scale fragile aircraft.
If this plane was made of almost anything but EPS foam (EPO, EPP, Elapor.. etc),
I'd be a lot more interested in it. Too bad.
ian
Daemon is online now Find More Posts by Daemon
Old Apr 07, 2010, 02:01 AM
EyeFlyPlanes is offline
Find More Posts by EyeFlyPlanes
So Cal FPV Aviator
EyeFlyPlanes's Avatar
United States, CA, Santa Clarita
Joined Feb 2008
Here is the actual page link for anyone that doesn't want to fiddle around trying to sift through the pages.
http://www.fpvhobby.com/24-168-cm-wi...-airplane.html
So heres the thing, I own a Twinstar 1 and I am pretty sure It is made up of the same stuff as this one is. Ya its your typical styrafoam, but I can tell you from experience that If you know how to land your plane, U dont need to worry about the stability of this foam. I have landed many hard landings on my TS1 & maybe a couple of nicks and scratches here and there is all I have noticed. Sure you can glass it or tape it to death, but im sure some simple reinforcements will keep this plane flying well for a long time.
I am not downplaying ELAPOR by any means, I wish every foam plane used it as a standard in the industry. What I am saying is - it shouldn't be a make it or break it for you. This plane has enough positive points to have it weigh in the other direction.
What I like about it...Look at that cargo room!! No easystar ever had that much space!! Unless of course U do major surgery like we all have. U can put a nice size prop on that for some serious thrust. Its got a nice flat area to mount servos, cameras, HD cameras, small farm animals, I mean just about anything you want.
I guess its just nice to see a plane for once thats made for FPV. Now if we could just get the Pricepoint down a little closer to the EZ*. $183.00 Shipped, geez!
Guess u cant have your cake and eat it too..
EyeFlyPlanes is offline Find More Posts by EyeFlyPlanes
Old Apr 07, 2010, 02:10 AM
Smoke on , go !
Verona - Italy
Joined Jan 2007
but is this airplane so fragile that needs to be reinforced or you guys are just protecting it in case of hard landing?
Old Apr 07, 2010, 02:19 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Fergus:
Do you plan to use the flaps too ? I have noticed there is a cutout on the side of the fuselage , maybe it is intended for a camera but it could give you an easy access to the cargo bay for the side.
How are you going to hinge ailerons and rudder elevator etc... from your pictures there doesn't seem to be any hinges .
Thanks for posting your building experience.
rcmonster99 is offline Find More Posts by rcmonster99
Old Apr 07, 2010, 02:32 AM
Houba ! Houba !!
Joined Sep 2003
If the plane is made of everyday polystyrene then I would perhaps consider glassing the wings so they don't clap on me.
Sometimes the amount of gear we carry can be relatively heavy, this, combined with the poor perception we have on how we dive (depending on the lens of the camera) could produce enough Gs to over stress the airframe.
On some of my videos I have seen ow my Radian's tail stars to wobble on a fast descent...Maybe I was diving but to me it was a fast descent.
However I might consider glassing the underbelly of the plane for durability only
I think Fergus is going a great job and doing us a favour in sharing his experience, the glue being one hell of a warning. I will probably use foam friendly CA
Old Apr 07, 2010, 04:33 AM
Fergus is offline
Fergus's Avatar
Ireland
Joined Apr 2005
On the issue of reinforcing I'm just going by what I've seen on the Chinese forums. Recommendations there call for some form of reinforcement. The designer recommends it on the fuse and on the wings.
Any pics I've seen show the packs up front in the nose. That coupled with the recommended capacity of up to 5Ah batteries puts alot of stress on what is a much higher (less compact than EZ*) fuse and could cause it to snap.
I've chosen to glass the interior cavity and add a spar. I will also glass the underbelly and sides. Others may choose to do this differently but this is what I decided on.
I will be opening one of the two side doors for access to internal components.
The wings have flaps pre moulded although no cavity for servos is provided. I think I will use them. Glue hinge tape is provided but I think I'll just use some blenderm tape.
I have very little fixed wing experience and am just sharing my plans for the airframe. Others will do things differently and I encourage all to share their experience with the model.
Regards
Fergus.
Old Apr 07, 2010, 06:40 AM
Houba ! Houba !!
Joined Sep 2003
this is like the easystar case where everyone has his own recipe for success. whatever you are doing on this plane is great for me ! you are a path finder
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
