Old Sep 22, 2010, 09:09 PM
guipedroso is offline
Find More Posts by guipedroso
guipedroso's Avatar
Brasil, PR, Curitiba
Joined Apr 2010
PanTilt GoPro DIY for Skywalker
Hi guys, just to help someone, i have made a GoPro Pantilt i plan to use on my skywalker. Get a look: http://www.rcgroups.com/forums/showthread.php?t=1311687
Regards
Guilherme
guipedroso is offline Find More Posts by guipedroso
Old Sep 22, 2010, 09:41 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Originally Posted by chimaera View Post
Great idea Crist. I just ordered a couple of these. Would you detail how you did this.
It's easy. Once you determine the correct positon of the knob to give the desired signal, carefully remove the cover and measure the resistance on each side of the pot. Remove the pot and solder in some 1/4 watt resistors that closely match what you measured with your ohmeter.
Or even simpler yet is to turn the knob till you get the desired signal and tape the knob in position!
BTW, the servo tester needs 5v in on one set of terminals and the other 2 sets are where the servo hooks to. In our case where the servo extension connects to that is going to the signal input of the FT-20A stabilizer.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Sep 22, 2010, 09:54 PM
AdamChicago is offline
Find More Posts by AdamChicago
Whats the wrst that can happn?
AdamChicago's Avatar
Chicago, IL USA
Joined May 2010
Need help with a new Skywalker power system (ESC & motor) that is Castle BEC Pro, 4S Lipo, and 9x6 prop for 5mm shaft friendly. Would prefer to use a compatible Castle ESC just to be safe.
My stock ESC and/or motor from FPVFlying.com is shot and I'm not sure if it's the glue that got into the motor or possibly the ESC isn't compatible with Castle BEC Pro, but the motor stutters after half throttle and both the ESC and motor get hot after only throttling up a couple times for seconds.
Because I'm using a BEC I pulled out the red/middle wire going from the BEC to the RangeVideo OSD and from the OSD to the Thomas Scherrer LR UHF RX so there shouldn't be any power overloading.
AdamChicago is offline Find More Posts by AdamChicago
Old Sep 23, 2010, 02:18 AM
GadgetEric is offline
Find More Posts by GadgetEric
A few Models is not enough Hon
GadgetEric's Avatar
Australia, WA, Noranda
Joined Mar 2007
Wiring
Bit confusing. How about a diagram of the way you wired it up
GadgetEric is offline Find More Posts by GadgetEric
Old Sep 23, 2010, 09:01 AM
chimaera is offline
Find More Posts by chimaera
THEY MOSTLY COME OUT AT NIGHT
chimaera's Avatar
Kaysville, Utah
Joined Jul 2005
Thanks again Crist.
chimaera is offline Find More Posts by chimaera
Old Sep 23, 2010, 10:07 AM
Chicago, IL USA
Joined May 2010
Thanks GadgetEric...here's the wiring diagram. Is there anything you see wrong regarding the BEC or something that would cause the ESC & motor to stutter with half throttle and get hot even after only throttling up for a few seconds?
Side Notes:
-The RangeVideo OSD "Power Manager" and the motor are 4S Lipo capable. The RangeVideo OSD and Camera are 3S capable.
-RangeVideo OSD doesn't have Servo-Outs for Flaps or Camera Pan so those are run directly from the RX.
-Center/Red wire is removed between RX and RangeVideo OSD and from RangeVideo OSD and ESC.
Old Sep 23, 2010, 10:20 AM
Joined Mar 2008
Side Notes:
What happens when you connect the TSLRS receiver throttle directly to the ESC by-passing the OSD?
Old Sep 23, 2010, 10:24 AM
Chicago, IL USA
Joined May 2010
Same result with the motor stutter, but am not sure about the ESC/Motor being hot.
Old Sep 23, 2010, 10:55 AM
Joined Mar 2008
Do you have a ervo tester that you can hook up to the ESC?
Old Sep 23, 2010, 11:07 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
if you can hang in there a couple days I can give you a hand sunday
ashdec87 is offline Find More Posts by ashdec87
Old Sep 23, 2010, 12:39 PM
Chicago, IL USA
Joined May 2010
Crist, I don't, but that sounds like a good purchase that I'll add onto my new motor order.
Old Sep 23, 2010, 12:41 PM
Chicago, IL USA
Joined May 2010
Ash, that would be awesome if you're still thinking of some Montrose or Northerly Island flying on Sunday. However, between the glue situation and now the motor stutter I am going to order a new motor today and then if that still doesn't do it, I'll by a new ESC locally afterwards. From all indications, my wiring scenario is ok...I think??
Old Sep 23, 2010, 02:40 PM
Chicago, IL USA
Joined May 2010
What do you guys think about this motor for Skywalker:
http://www.hobbyking.com/hobbyking/s...idProduct=7073
Current Prop: 9x6
Current Battery: 4S 4500 Lipo
Flying a little on the heavy side
Old Sep 23, 2010, 02:51 PM
Joined Mar 2008
Current Prop: 9x6
My SW uses a Scorpion 3020-890kv and I'm using a 4S battery. I think 1400kv is way high for a 4S battery. Look for one that is close to 890 to 1000kv.
Old Sep 23, 2010, 03:16 PM
rsowder is offline
Find More Posts by rsowder
rsowder's Avatar
San Francisco
Joined May 2009
Current Prop: 9x6
I am using that same motor with a 3S and it works great. Not sure how it would work with a 4S
rsowder is offline Find More Posts by rsowder
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
