Old Dec 18, 2012, 10:55 PM
hendrnk is offline
Find More Posts by hendrnk
An Aussie in Chicago
Joined Apr 2012
Originally Posted by VizBizTas View Post
Grrrrrr.....!!! Wonder if its a bad batch....!
What should I get instead?
I already have all the eagle tree stuff (but not the stabilizer)...
What are most people using in their SW's...?
Cheers
I will use the FY-31AP autopilot / stabilizer. I have tried it on a few planes and it works fine. So should work OK on the SKywalker as well. !
hendrnk is offline Find More Posts by hendrnk
Old Dec 18, 2012, 10:58 PM
VizBizTas is offline
Find More Posts by VizBizTas
Joined Sep 2012
Originally Posted by Gimmer View Post
I'm no apm expert but did you have Skywalker parameter file loaded?
Yes - all tested and I noted a change to all the PiDS etc...
VizBizTas is offline Find More Posts by VizBizTas
Old Dec 18, 2012, 11:06 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I use no stabilizer in the SW (it is self leveling), but can say that if you have the ET gear, you
might as well get the Guardian module. I'm using the standalone Guardian 2D/3D stabilizer
on my Skyhunter, and I'm pretty impressed with how well it works.
ian
Daemon is online now Find More Posts by Daemon
Old Dec 18, 2012, 11:11 PM
TNug is online now
Find More Posts by TNug
Waypoint Collector
TNug's Avatar
United States, NC, Raleigh
Joined Feb 2012
Sorry to hear that, Viz. I've been watching your build as I prepare for mine. I have all ET gear including the stabilization expander, but haven't flown it and so can't give you an opinion.
I'm no expert on autopilots either, but I've read multiple accounts of various brands having trouble with steep dives causing oscillations. When you dive in stabilize mode, the control corrections can put a lot of stress on your horns/linkages - as Ian mentioned. There's a vid of a guy using his ET guardian to pull out of high speed dives by switching to stabilize mode. A few minutes later, during level flight, it spirals into the ground. After examining the wreckage, he concluded his plastic control horn cracked from the stresses and eventually failed. See anything like that on your plane?
Were you flying slow and banking when the spiral occured? Any chance you stalled? That seems to be another theme for APM related crashes. You had an airspeed probe. Was your ET logging? Maybe check the log for your airspeed when the spin starts.
Get out the CA and hot water! Good luck.
TNug is online now Find More Posts by TNug
Old Dec 18, 2012, 11:33 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Cheers
I have the eagle tree stuff in my Skywalker, but I left the guardian on the shelf. The SW has enough natural stability that it returns to home just fine without any electronic stability help. It's not perfect because the heading will swing around by about 10 degrees or so, but it gets it home just fine like that.
sub
subsonic is offline Find More Posts by subsonic
Old Dec 19, 2012, 03:28 AM
marcin.gala is offline
Find More Posts by marcin.gala
marcin.gala's Avatar
Joined Jun 2010
My SW visit some places again.
Check for ending of that flight ,ice on lens and blind FPV landing.
FPV Carpet (8 min 23 sec)
No video troubles ,I worry more about my UHF !..haha..
marcin.gala is offline Find More Posts by marcin.gala
Old Dec 19, 2012, 04:08 AM
davico is offline
Find More Posts by davico
Canberra, Australia
I have a APM2.5 installed....
For the record, I've had an APM (v1.4 hardware) in my SW for over a year now and it has been working very well. I've done many autonomous flights of a few kilometers and lots of stabilize and fly-by-wire.
I found the skywalker param file to be too agressive for my plane (pitch and roll 'P' too high), and instead started with the default parameters (which in contrast are are very conservative) and increase the pids from there following the APM tuning guide in the wiki.
Be sure to post on the DIY Drones forum (in the "ArduPlane 2.x software" section) if you suspect a hardware/software problem or want advice, especially if you have logs. Don't give up!
As with any Autopilot, its best to proceed very cautiously when testing all of its features (get ready to take back manual control) until you are completely comfortable and confident with it.
Dave
PS. I also suggest disabling the airspeed sensor, at least initially (as does the wiki). I have mine logging (but not used for control) and have found the logs to be a bit erratic. You don't really need it provided you set a reasonable cruise throttle (40% or so is the default IIRC and is plenty for most SW setups).
davico is offline Find More Posts by davico
Old Dec 19, 2012, 04:59 AM
kstmark is offline
Find More Posts by kstmark
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
http://www.youtube.com/watch?v=jNPmpUN_zMc
3600m los without glitches!!!
Please tell us about your video setup
kstmark is offline Find More Posts by kstmark
Old Dec 19, 2012, 05:16 AM
raRaRa is offline
Find More Posts by raRaRa
Joined Nov 2010
That's peace of cake if you have good antennas :-)
Check out my 10km flight (barley any glitches).
Skywalker 1900mm, attempting to fly 10km (Flown with DragonLink) (9 min 9 sec)
I use a simple IBCrazy vee antenna and patch antenna on ground. I optimized the patch antenna for 1280MHz.
raRaRa is offline Find More Posts by raRaRa
Old Dec 19, 2012, 05:30 AM
kstmark is offline
Kostas
kstmark's Avatar
Greece
Joined Sep 2008
http://www.youtube.com/watch?v=y13XumOl2gs
I have the same antennas and now I have made a cloverleaf. It is much better when you turn. I am now building a helical. A bit large at 1.2ghz. I have also put a saw filter at my sunsky 800mw vrx but I haven't test it yet. Windy days.
I think that sunsky (bob) vtr hasn't good colors.
marcin.gala's video is perfect, it is like recording on the plane
Old Dec 19, 2012, 05:35 AM
Joined Jun 2010
it's 500mW video VTX ,recorded with DVRJapan on ground.
My whole setup on Skywalker don't have even one ferrite ring used
and that flight is done on simple rubber duck on VTX and 8dBi patch on ground.
Can see it anyway during flight ,dipole on left wing and rubber on right
raRaRa - I see You using Dragon Link !...I got huge troubles with mine UHF DL V2 ...!
Old Dec 19, 2012, 08:45 AM
hendrnk is offline
Joined Apr 2012
Quick question what are you using to control the camera panning. ?
Nice setup, looks so stable.
Old Dec 19, 2012, 08:50 AM
tom3holer is offline
Find More Posts by tom3holer
Cape Cod
tom3holer's Avatar
United States, MA, Barnstable
Joined Sep 2010
raRaRa,
Very nice video. What are you using for a Motor battery. Is it 2 5ah or 1 10ah?
Tom
tom3holer is offline Find More Posts by tom3holer
Old Dec 19, 2012, 08:55 AM
raRaRa is offline
Joined Nov 2010
Originally Posted by tom3holer View Post
raRaRa,
Tom
Thank you Tom.
I'm using 2x 5000mAh 4s
Old Dec 19, 2012, 09:28 AM
Joined Jun 2010
GWS sail servo 360 and using side slider on my T10 to control it..it's really smooth.
Just fit wiper as I was tired after flying blind
also can see my camera wires patent ,working great.
raRaRa - what antenna you used for that flight on DL TX ,also what on DL receiver ,how was your rssi all way up.
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
