Old Jul 30, 2010, 08:12 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Just measured the props and spinner... about 9 1/2 inches.
man2000me is offline Find More Posts by man2000me
Old Jul 30, 2010, 09:33 PM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
oh that's gonna be cutting it close, you might need to cut the boom a little to allow the prop to clear
ashdec87 is offline Find More Posts by ashdec87
Old Jul 30, 2010, 09:50 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Do you think the folder stuff will work with the motor mount? What do you think the climb out will be like?
Old Jul 30, 2010, 10:00 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
donno if it will work with the mount.. I think it should.
And climb should be very strong. Not vertical, but it will get you to where you need to go.
Old Jul 31, 2010, 02:30 AM
Bear_au is offline
Find More Posts by Bear_au
Bear_au's Avatar
Australia, NSW, Gledswood Hills
Joined Mar 2006
Hi guys
Well the wings are done it's just the fuse one thing I noticed was when I put the wings on the fuse and stabilizer on and just put the fuse together the fin is not level with the wings ? I know it is not a glued fuse yet but I had to twist the boom to get it level
Just as a matter of interest has anybody just ca'ed the fuse ( no twisting ) and found that their wings are not level? Or has it come out ok.
Might tape the fuse and see it that changes the out come.
Cheers
Bear au
Bear_au is offline Find More Posts by Bear_au
Old Jul 31, 2010, 07:43 AM
Dimitris76 is online now
Find More Posts by Dimitris76
United States, IN, Carmel
Another Skywalker made it to it's new home intact!
As you can see the box is in perfect crease free condition.
A nice surprise inside - no more broken EPS pieces rather abundant use of these air filled bags.
The carbon spars are nicely taped in the box - NO more dinged wings!
All in all it took 5 - yes FIVE days - from Hong Kong to Chicago. Not bad for an item shipped with the cheap option, instead of EMS!
Let the building commence!
Dimitris
Dimitris76 is online now Find More Posts by Dimitris76
Old Jul 31, 2010, 09:48 AM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Originally Posted by Bear_au View Post
Hi guys
Cheers
Bear au
Mine definitely is not level, but it flies fine.
Old Jul 31, 2010, 11:42 AM
Is this the suggested strapping tape?
http://www.staples.com/Scotch-Extrem...0631:SS1008135
Can I use this "Tough series" 3M transparent duct tape instead?
http://www.staples.com/Scotch-Transp...product_508638
Dimitris
Old Jul 31, 2010, 02:00 PM
Before the first one gets answered I am asking another question...
What's the story with the short Carbon fiber tubes in the accessory bag? And did you guys get only two sets of control horns and piano wires too?
Dimitris
Old Jul 31, 2010, 02:28 PM
MorrisM is offline
Find More Posts by MorrisM
MorrisM's Avatar
Oklahoma City
Joined May 2004
The carbon tubes are for the rubber bands that hold the wing on.
There should be 4 piano wire rods and 4 control horns.
MorrisM is offline Find More Posts by MorrisM
Old Jul 31, 2010, 02:45 PM
Well... my piano rods and horns are missing...
Thank you Morris
Old Jul 31, 2010, 04:22 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
ok I moved the vtx to the tail using a home made twisted wire with a toroid in it. Ground test is definitely improved, not perfect, but better. Only a flight test will tell if its cured of static.
Old Jul 31, 2010, 06:28 PM
Bear_au is offline
Bear_au's Avatar
Joined Mar 2006
Hi Dimitris76,
Had the same problem the hardware bag it's like a lucky dip, you can't be sure what you will get..
Hi Ash,
Good move putting the vtx back.. it will help but in close the vrx can get front end overload.. and there is still a lot of RF around.. Ferrite cores are your friend, but these must be wrapped well over X5 times better yet X10 and twisting wire DC lines, the Speedie is the biggest for RF.. and the cam itself.
Hope you did another range check after the vtx move could now be close to your planes rx ...
Well 3/4 finished the SW wing . I went a little further with the CF ribbon.
X2 reasons.
1) I had it in stock and the off cuts were the right size for another job.
2) wanted to run the support closer to the end of the aileron to give it less travel distortion under extreme condition.
May well replace ailerons with balsa later not sure yet will get it up and running and see if it would be worth doing
some photos.. I know we have seen them before but there is some info added that may help others..as this thread is really getting big
This mod has really made the wing VERY strong .. so remember there is a trade off here.... It will also be safer to reo' the CF rods and surrounding area that holds the wings to the fuse, as the energy that would have been taken up by the flexing outer wing section will now be transferred in towards the center to the wing joiners
BTW the servos are HS65 MG and will be all around.
Cheers
Bear_au ( Richard)
Old Jul 31, 2010, 07:03 PM
RaptorAP is offline
Find More Posts by RaptorAP
Gainesville, FL
Joined Nov 2005
Richard, I used ALOT of the crossweave tape as you put it on the underside of the wing, use as much as you feel comfortable with.. Ive pulled wing-stressing dives in FPV to line up for landing, it definitely does the job, no wing snapping!! Full-length of the wing tip to tip!!
RaptorAP is offline Find More Posts by RaptorAP
Old Jul 31, 2010, 08:48 PM
Guys once again,
if I use CF strips can I get away with transparent duct tape instead of that Extreme strapping tape?
Dimitris
Question Best plane for FPV while on vacation? patricklupo FPV Aircraft 24 Nov 23, 2014 03:56 PM
Cool FPV plane rescue with an FPV truck :-) AnthonyRC FPV Aircraft 17 Feb 24, 2008 10:45 PM
For Sale Skywalker plane and a bunch of extras moody07747 Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2006 09:34 PM
Discussion Aviator Skywalker RC plane given to me moody07747 Electric Plane Talk 46 Sep 12, 2006 11:45 AM
